Cannot Find Part Number For JD3520 Grease Fitting
   / Cannot Find Part Number For JD3520 Grease Fitting #11
i bet jd doesn't make zerks but uses off the shelf fittings
   / Cannot Find Part Number For JD3520 Grease Fitting #13
You still need to look in the snow blower catalog. Only they do not show a breakdown of the drive shaft. Key #10 is the drive shaft, LVA14109 $405. Not keyed is AN278257 cross and bearing assembly $72. I am not sure what you get with that.
Understood. We're speaking the same language now. All the diagrams I see for AN278257 do not show a lube fitting. I'll figure something out. Thanks for all your time.
   / Cannot Find Part Number For JD3520 Grease Fitting #15
Go to the 3520 parts catalog, then Implements, then 2108 59" two stage snow blower
Thanks for the heads up. I was unaware to access some equipment one had to first access the tractor parts catalog. Thanks again,Jim
Kuhn Knight 8124 Slinger Manure Spreader (A59814)
Kuhn Knight 8124...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
2022 Ram 2500 (A55973)
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
