Looking for new /2" drive impact wrench
   / Looking for new /2" drive impact wrench #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Need avice and opinions.
I'm looking for feedback on a new lower dollar 1/2" drive impact wrench but a search gave me little to go on. I used to have a Campbell Hausfiield cheapie that I thought was not so good and traded up to a Harbor Freight "Earthquake". Oops. The Earthquake has plenty of power but the controls are so tight-fitted I need a small hammer to work the reverse switch. And the sockets go on hard and come off harder. I liked the "sloppier" fit of the CH. I don't use a wrench much so I figure to get another and maybe keep the Earthquake for special occasions. I have a 5 HP, 240 with 80 gallon tank compressor. Here are some wrenches I'm thinking about...or maybe I should keep the HF Earthquake and stop whining?
[ame=http://www.amazon.com/Campbell-Hausfeld-PL150296-2-Inch-Impact/dp/B0000CBJFE/ref=sr_1_2?s=hi&ie=UTF8&qid=1330346582&sr=1-2--can]Campbell Hausfeld PL150296 1/2-Inch Impact Wrench: Amazon.com: Home Improvement[/ame] buy for under $50 @ Amazon. Looks like what I used to have.
Shop Ingersoll Rand 0.5" 450 Ft./Lb. Air Tool Impact Wrench at Lowes.com This looks good and nice reviews.
Shop PORTER-CABLE 500 Ft./Lb. Air Tool Impact Wrench at Lowes.com ----Don't really want to spend this much.
I thought about an electric one and keep the Earthquake for serious but electrics are costly. I have a Makita 18V drill but their cordless impact is costly as well. Any advice here or anone own the above tools? Thank you in advance.
   / Looking for new /2" drive impact wrench #2
My experience with cheap impacts is they don't seem to keep their higher torque value very long. While looking at the Lowes site I might consider the 600ftlb model listed for about $180. I would also check out CP for current tools too.
   / Looking for new /2" drive impact wrench #3
The problem with not using it much is that the few times you do you probably want it to work really well. +1 for CP or IR. Definite no for CH.
I know years ago Sears used to sell CP - maybe that is a good source (sale)?
   / Looking for new /2" drive impact wrench #4
I have owned many impacts over the years while working as a mechanic snapon mac matco IR and some cheapies. The one I liked the most is the matco that has 650ft lbs but it cost more. I also own an Ingersol Rand right now that I love. Great power, controls easy to use and the sockets stay on, nothing worse then having a socket fly off when you aren't ready for it. The IR is alot like the one at Lowes but I got mine at NorthernTool.
   / Looking for new /2" drive impact wrench #5
Of the 3 you listed, I'd go with the Ingersoll. I have no experience with that particular model, but I have the IR 231H now myself. And of course, I used to repair/rebuild air tools and you'd have a hard time going wrong with Ingersoll.
   / Looking for new /2" drive impact wrench #6
The IR I have now ran 275.00 So if you don't use it much go with a cheap brand.
   / Looking for new /2" drive impact wrench #7
Look at I/R, good quality and won't break you.
   / Looking for new /2" drive impact wrench #9
I have a cheap CH here myself and its garbage.
The Gun that rode in the wrecker i used to drive was a IR TiMax composite, it was a beast. light and TONS of grunt. i never came across anything it wouldn't undo although i don't think i tried anything larger then a 1" Socket. that's what the service truck and the 1" impact were for.
That IR didn't care if it was 35*C in the sun or -20*C in snow, ice and dark. IR+air=Job done Period
Good socket fit and retention too
Air hoses hated the cold though lol SOOO stiff
IF i used the impact here at home more i'd be buying one. Frustrating Every time it fails to do its job.
   / Looking for new /2" drive impact wrench #10
Similar to the one I have for working on my semi but not as powerful , mine with a 1/2" hose is in the 900 lb. range and with 3/8" hose it is down to 500 to 600 lb. range , ( had to change the fitting even on the bottom of gun to accept the 1/2" but now no bottle neck ) :
Klutch Heavy-Duty Air Impact Wrench 1/2in. Drive | Air Impact Wrenches| Northern Tool + Equipment
They don't carry the model number I have anymore , been a couple of years since I purchased it , but when it will torque off 1" nuts off of rusted shocks on a semi , pretty dang good .
Fred H.
P.S. Mine is actually the same as their 3/4" drive impact but it is 1/2" drive . Same specs and everything else , just different size drive . Bought it 2+ years ago for Basically $100 , ( $99.99 + shipping of course )
   / Looking for new /2" drive impact wrench #11
I have an AirCat twin clutch and I like it. It's extremely quiet and you feel almost no "impacting" but it's just as powerful as what I would call the most powerful 1/2" impact I've ever used, the IR 2135 MAX. The IR is nice but it's too much money. It doesn't work well with torque sticks but that isn't an issue for me. I use to use it all the time but I got a Milwaukee 1/2" 18v cordless impact and it does 90% of my needs (not as powerful as the AirCat) and doesn't require air.
   / Looking for new /2" drive impact wrench #12
+1 for the IR
Mine is the 600ft/lb model usually on sale for $175+tax
Has not let me down yet but a warning!
It is air hungry! I needed to change my fittings from M style to T style to get the extra air volume required. I still need to use the on-off-on method with the trigger to get full torque from the gun.
The compressor is a 6.5hp 60 gal model on 220V but I have a dual air reel and maybe 75ft of line so no fault of the guns.
   / Looking for new /2" drive impact wrench #13
+1 for the IR
I had to upgrade to 1/2" air hose with 3/8" fittings and Milton "P" style connectors.
   / Looking for new /2" drive impact wrench #14
I got a DeWalt 1/2" Electric Impact wrench.
I haven't used a lot of impact wrenches, but it seemed to do reasonably well. It wasn't cheap.
   / Looking for new /2" drive impact wrench #15
I got a good deal on an Ampro 1/2 impact and so far on only a few times it couldn't break the nuts loose- stuck axle nuts on car and trucks
rated at 450ft lbs. it is a dual hammer but may be a little lite for some...
See one like it? on Amazon for $100 with free shipping
Can't go wrong with Ingersol
   / Looking for new /2" drive impact wrench #17
   / Looking for new /2" drive impact wrench #18
I have all IR air tools and never regretted any of them
   / Looking for new /2" drive impact wrench #19
I use the torque limiters, what kind of issues did you have? Does the more powerful gun negate the twist in the sticks? Thanks for pointing out the IR2135, I did not notice it when I was looking. The only problem I have is the price, I want a good gun, but I am just a tinkerer and use it to maintain my equipment.
   / Looking for new /2" drive impact wrench #20
when buying electric tools i allways go to the construction supply shop (the one that also sells to private individuals with no VAT number, under the Hitachi advertised price) and ask for their one-but cheapest model. When comparing the cheapest hobby tool for the one-but cheapest, for a couple of bucks extra you get double the quality. If you compare it to the next model above that, you wont get the quality increase for the money anymore, mostly added features that you dont need anyways.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2020 DRAGON ESP...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
207278 (A52708)
207278 (A52708)
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
