AZ ranch
   / AZ ranch
I met with my foundation guy and they expect to start on Tuesday. Finally something is going to happen. Woo Hoo!
   / AZ ranch #362
I've been following this thread for awhile now. Good to read that you got your permit. I look forward to following the updates as you build the log home. Everything you've done so far looks really good. It is a shame you've been delayed so long and put to excessive extra expense by the so called public servants.
Mr. HE:cool:
   / AZ ranch
This morning the concrete contractor came out and set the stakes and painted lines for the foundation. Then this afternoon he dropped off his backhoe. Tomorrow morning they start digging. Woo Hoo. It is finally starting to happen. This is more exciting than Christmas as a kid.
   / AZ ranch
So my concrete guy was asking about my floor joists, so he could be sure he had the minimum crawl space. I told him the bracket was 9 1/2 inches so they must be 2x10s. After looking at the plans, he said that the 9 1/2 TJI was not the bracket but the joist. I didn't feel too stupid.
So is this 9 1/2 TJI 110 as good as a 2x12? He said they are just as strong but less than half the weight. I guess the county must think they are strong enough or they would have drilled me.
I guess my more important question is - is 9 1/2 inches enough space for insulation? I was thinking 12.
   / AZ ranch #366
What type of insulation are you using? It's better have an R-value target and work to that, rather than fill some number of inches.
   / AZ ranch
I want a minimum of R-30. I guess I can do that with 9 1/2 inches.
   / AZ ranch #368
   / AZ ranch
First day and the first delay? I love it. The "expansive" clay was estimated to be 2 to 2.5 feet deep. It is 4 feet deep. So now my footers have to be 48 inches deep instead of 30. Another day of backhoe work and probably a few hundred more block.
   / AZ ranch
Looking at the bright side now you can have a crawl space with lots of overhead and room to work in. Rick
Well, I would LOVE to have a 6 foot crawl space (4 from removed dirt and 2 from block above ground).
I'm debating that now. I have to consider;
the availability of the backhoe,
the additional cost of removing the dirt (30 x 30 x 4 ft),
how much it delays the concrete guy and what his schedule availability is,
if the engineer says the integrity of the walls and footers will be affected,
and most important of all, will the County say anything or require anything additional.
   / AZ ranch #372
Did you have some test holes drilled first at the site?
   / AZ ranch #373
Application fee was $400 and Septic was $265 for the county. Then their nitpicking caused me to spend $2500 on the engineer and $2000 for a soils test.
Now the rest of the building permit fee is about $1500, the Road Use fee is about $3500, and then fees for Solar permit, and other misc items. They get you coming and going.
Wasn't there any way to meet at the county first to understand all of their requirements? I guess you were acting as your own GC, huh? Construction and home building is a little different from bookkeeping & accounting. You probably have eaten up any gen'l contractor fee you thought you saved.
   / AZ ranch #374
Now that was just plain mean. Life is way too short to be mean.
MoKelly
   / AZ ranch
I had test holes dug a year and a half ago but since then we moved the build site about 300 feet, so we picked an area with more clay unfortunately. No biggie. The digging is all finished and the soils engineer signed off. We're good to go.
Eaten up my savings on contractor fees? No way. Not even a fraction. Besides, there's probably not a contractor in the state who could build this style nearly as inexpensively as I can. I've built before and have no problem managing the project, even if I'm not up-to-date on all building practices.
This is my labor of love. The building process is just as important to me as the finished project.
   / AZ ranch
Actually, saving money was not even a major consideration in deciding not to have a GC. I just want to do this myself. I wouldn't even let a GC be in charge even if it didn't cost me anything at all. :)
   / AZ ranch #377
Bo, I understand completely about no GC and labors of love...there's always naysayers out there and I know they roll of your back like water off a duck. The best part of doing it yourself/ supervising is that you know how it was done and to your standards. If there are mistakes or short comings YOU know about them up front vs. finding out about them down the road. As far as saving money, if it doesn't occur upfront I'm sure it will overtime because of your intimate knowledge of how the structure and systems were designed and built when it comes for maintenance or retrofit. There will always be things we would have liked to different...when and if that time comes you will be well armed. Great build, thanks for sharing.
   / AZ ranch #378
MoKelly
Yeah that was a low blow ....not true either....around here Gen. Contractores charge 10 to 15% on total cost of construction...that's why I did my own...that and I also wanted to hire all the subs, look 'em in the eye ...it worked out just fine...no major mistakes ...some minor ones we caught and corrected but that happens to the most experienced builder.....
Lookin' good Bo....keep at it...:thumbsup:
   / AZ ranch
No worries. It would take a lot more than that to rain on my parade. I'm building my dream and having a heck of a ride while doing it!
   / AZ ranch #380
Just go read through the "Building a house in 90 days" and see a fine example of what you get with a GC.
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
