Canopy Moved some logs today
/ Moved some logs today #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
A street corner about two miles from my house is being widened, and many trees are being taken out to make room for it. The trees have been tagged forever, and about a year ago, I chatted with the homeowner on the corner and asked him if he would let me know when they started taking them down so I could try to get the wood for my stove. I heat with 100% wood in the winter, and burn about 2-3 cords each winter, so I can use all I can get. Mostly, I figured I'd never hear from the guy again, but surprise, surprise! Out of the blue, I get a call from the guy, nearly a year later. He's talked to the tree service and they've neatly piled the logs, about 10-15' sections, just waiting for me to come get them!
My normal procedure is to cut the logs into 22" rounds (the right length for my stove) and then hand-wrestle them onto my trailer or into my truck. But my chainsaw blades have both kind of bit the dust and it'll take a few days to order another one. But I hate to leave good wood laying around, especially after the guy went out of his way for me, so I drove my tractor over to the site and tried loading up my trailer with un-cut logs.
Above is my improvised ballast, to try to counterbalance the extra weight on the FEL. I dumped some heavy rounds into the box blade.
Here's one of the smaller logs, picked up in the bucket. I loaded about three of these logs, and a few smaller (maybe 8" x 10' long) ones before I finally ran up on one that gave me pause. It was 16" on the large end, 12" on the small end, and 15' long. The Internet says it was about 1100 lbs. The loader easily lifted it, but the ground was uneven, sloped, and very muddy, and I just didn't trust myself to make the final move of raising it up 5' in the air to clear the trailer's side rail. I ended up borrowing the homeowner's saw, cutting up half the log into rounds, and carrying the other half home in the bucket.
I will also call this a trial-by-fire of the bucket hooks that I welded on. They held, which is really the least I could ask of them. Woo hoo!
Fun, yes, but there were a few scary moments too. Those big long logs sticking out in uneven ground! I gotta build a real ballast box before I try anything like that again!
/ Moved some logs today #4
Nice job. Best wishes regarding getting new chains for your chainsaw. That was nice that the owner loaned you his chainsaw.:thumbsup:
/ Moved some logs today #5
A heavier counterweight will definitely help, but you may want to consider a forklift attachment. With forks, it's a lot less scary to lift bigger logs. Once you get the load raised, and angle the forks up all the way, it somewhat locks the log into place at the junction between the forks, and the back plate. That seems to really cut down on wobbling, and swaying. R,
I did find myself wishing for forks at one point, but for a slightly different reason: ease of loading/unloading. Once the log was chained to the bucket, it was pretty secure, but getting it chained and unchained was a real pain. Having to fish the chain under the log, having to de-tension the chains to unhook, and so forth. If I would have had pallet forks, it would have been easy to pick the log up, tilt back like you say, and then slide the log off onto the trailer right where I wanted it. I even think that forks attached to the front of the bucket would have been helpful, since the load rode close to the bucket once it was picked up.
/ Moved some logs today #7
You did the right thing by slicing the logs into smaller pieces for safety. I would suggest that cutting them in half, you could load and stack the half logs in your trailer, instead of rounds, sort of like a mini-log hauler. But you would need to figure a way to get them out of the trailer if it's not a dump-type.
Another safety thing to be aware of when lifting a log in the bucket is the risk of it rolling backwards onto the tractor and the operator. Using those chains was another good decision.
When we first started clearing trees at our place, there was lots of that kind of timber to be moved. Adding a toothbar put a "lip" on the bucket, which helped get under logs like that, but we've since had good results with some clamp-on forks. Not as nice as real QA forks, of course, but way better than just using the bucket.
Good job, Joshua. Please everyone be safe with stuff like this.
/ Moved some logs today #8
Where there is a will there is a way. Must have been fun driving a couple miles with your load. A heavy 15' log on uneven ground would be trouble no matter what. Good job. As mentioned the thing to watch when you have to lift logs high that are chained on the bucket is that they don't role back on you. Sometimes I hang them under the bucket if there is enough lift room. They are easier to unhook in the trailer.
/ Moved some logs today #9
Nice free wood.....why does it take several days to get new chains for your saw?? No local saw shops??
I have had trouble looking up the exact specs for this saw's chain, so I just order the OEM chain by mail.
/ Moved some logs today #11
You should be able to find an Oregon chain for it. Try this saw chain lookup guide
OREGON® Hand Held Chain Saw Replacement Parts
or bring your saw or an old chain into a shop that sells saws as a dealer ( not home depot or ace hardware ) they will give you a standard Oregon number to use. Then your good to go on your own from then on.
/ Moved some logs today #12
Got it.....around here.....we just take the old chain in to the saw shop.....they make me up a new chain in about 5 minutes. One advantage to living in a logging town. Good luck!:thumbsup:
/ Moved some logs today #13
Forks are really king when it comes to big logs, I will never be without them.
/ Moved some logs today #14
Yes, forks are real handy. Until (if ever) I get a real set, I cobbled up a set of slip-on forks based on a design by someone here on TBN (sorry, I forget who). They work really well, I just have to be careful not to roll the log back onto me and the tractor. And to the OP - great find on the wood, and fine looking tractor too. :thumbsup:
Just about a week later, and I estimate I have cut and moved about two to two-and-a-half cord of wood, when it's finally split. Cutting the logs into rounds on site and moving them one truck-load at a time seems to be about 1/3 faster than moving them with the tractor, not even counting transportation time between home and the site. I'm doing one or two short-bed loads a day, depending on how much stamina I have.
The picture doesn't really do it justice, but it'll give you some idea.
/ Moved some logs today #16
After using my fork lift attachment to load logs I decided a grapple works much better. I have much better control picking up and putting the log or whatever else where I want it. With the grapple I just drive up, open the grapple, rotate the bucket, close the grapple, and lift.
If I did it right you can see the grapple in the attached photo. It is a simple one I bought off eBay. It has proven to be a very useful attachment.
/ Moved some logs today #17
Free wood - any way you can get it is good :thumbsup:
I would agree, with a 2 mile trip your truck is the best bet. Plus it is all blocked up when you get home.
jmckelvey, I have a similar grapple on my bucket and.you are right they are very useful
/ Moved some logs today #18
I built a log fork a couple of years ago for my quick attach. I made it with the forks 75 inches on center because I buck my wood to fifteen inches. If I pick up the log in a way that my fifteen inch cut misses one fork, then it misses the other fork too. I do my bucking on the fork. I cut most of the way through on the fork and finish the cut with the log on the ground. I have a bad back and can't do much of the bucking bent over.
My build thread is here: http://www.tractorbynet.com/forums/build-yourself/213676-log-forks.html
I'm about two cords through the pile. Here's the second one.
Split every lick of it by hand so far, because... well, I guess I'm just a glutton for punishment. I do like swinging that maul--CRACK! The pile is getting smaller and smaller. As soon as it's gone, I'll go back and get some more. Y'all should see the stack of logs that the excavator made. I couldn't really even begin to guess, but I'd say there must be at least twenty cord in there.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter with PTO (A61166)
New/Unused...
2015 FREIGHTLINER CASCADIA ROAD TRACTOR (A62130)
2015 FREIGHTLINER...
2015 GMC Sierra 1500 SLT Crew Cab Pickup Truck (A61568)
2015 GMC Sierra...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
