What caused this
/ What caused this #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
For any experienced welders on the forum this is the side of a Quadrafire 5700 wood stove. The other side also has a crack like this in the same location. This is a weld seam on the inside of the stove where they welded the air tube manifold so it is cracked right through. Obviously heat created the crack but my question refers to what can do this on 1/4" steel at a weld joint such as a deep weld or something to that effect? The manifold is made with tube iron with one end capped off and drilled for the lateral secondary burn heat tubes running across the top. The other end is open to an air inlet flap. The next question is what is the proper way to fix this?
/ What caused this #2
Is the crack beside that little weld were the red is?
/ What caused this #3
I'd shoot them an email. & pics. I'd say it's due to expansion issues with heating/cooling cycles, but that is a guess. They may have issues with this model. Post this over at hearth.com, that link I sent you the other day.
/ What caused this #4
I don't really know what caused it. Most likely too much stress in that location when hot.
I'd drill a hole at each end of the cracks, grind a groove in the cracks. Punch a key hole in the groove with some 6010 for the root pass, and cap it off with some 3/32-inch 7018.
/ What caused this #5
Weld it up like SA said, but do it when is at half the normal running temperature. That way it will see only half as much stress when hot.
And only half as much stress when cold.
/ What caused this #6
Ditto, especially grinding a hole at the end of the crack on both ends. I'd probably use MIG though for heat and speed control. It would not hurt to weld it when the stove is hot.
/ What caused this #8
A mig weld is not shallow penetrating unless you make it so. That is a myth. And it's more of an issue with a technique. If you try to "paint" on a weld over the seam, nothing is going to work. The metal in that unit is not all that thick...maybe a 1/4". A little grinding out a groove and fill it up. In fact, that is the method of choice it appears to weld the stove from the manufacturer. It's likely from a creation of a large HAZ combined with shrink swell issues as it is. Stick would likely increase the HAZ. Stick would work. But it's not necessary.
/ What caused this #10
I agree that a big high amperage MIG will penetrate, but as Ghenges said, those little 110V MIG machines just lay the metal on top and aren't much better bonded than Bondo.
/ What caused this #11
HEY! Lets not be running down those 120-volt Mig machines! I just bought one. :laughing:
/ What caused this #12
A shallow penetrating Mig weld is likely what facilitated the crack in the first place.
The original weld didn't get hot enough. Left a nonconformity(different grain sizes) with the parent metal that became evident when a hot fire was lit.:)
/ What caused this
Come to find out, they certainly do have issues. The stove has a lifetime warranty but from what I am reading, all they have to say is "you over fired the stove voiding the warranty". I personally do not think anything like this should be happening to a wood stove or if it does, do not make up some cockamamy excuse not to fix it.
/ What caused this #14
Oh, well yeah it is definitely your fault! Did you not read the small print in the warranty where it says you are only suppose to look at the stove, not to ever use it?:rolleyes:
Reminds me of a time I knocked a brand new 4-pound hammer off some stagging that belonged to my partner. Cracked the wooden handle. I said I would go to Sears and get him a new one. Once in the store I was informed Sears only guarantees the steel part! When I showed them that the words Craftsman were on the handle, they still wouldn't replace the hammer. Once I expressed my displeasure with Sears I got new one.:D
/ What caused this #15
Sounds like most lifetime warranties, only good for life of the product so when it breaks or wears out, that was the life of it so no more warranty. Reminds me of the restaurant that advertised all you can eat for $5 so when the customer wanted more, they said you need to give me another $5. That plate full WAS ALL YOU CAN EAT FOR $5
/ What caused this #19
I think that's what they used on these "welds" for the forklift attachment hooks on this bucket.
Versus my "weld".
I'm hoping mine holds up a little better.
Brian
/ What caused this #20
You know what works really well? Go to the store you bought it from, mumbling about getting all their business addresses, etc for the small claims action you're going to take, because they are the local representative of the manufacturer.
Actually, the manufacturer is probably trying to bluff you. Ask them to define what over firing is, have them show you in the manual where this is discussed, warned against and defined; and ask them how they prove you over fired it.
Do it all by letter.
They'll wilt
2021 Ford Mustang Mach-E SUV (A61574)
2021 Ford Mustang...
2005 International 4300 Rollback (A62613)
2005 International...
2022 Ford Expedition SUV (A61574)
2022 Ford...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
Jack Daniels Mini Decorative Truck (A61574)
Jack Daniels Mini...
