Local Sanctuary
/ Local Sanctuary #1
lakngulf
Lake Martin Alabama
Kioti CK30
I am fortunate to live next door to 1600 undeveloped acres on the Lake. My next door neighbor to the east is a 10 minute boat ride. I have a corn bucket next to my house to give the deer a quick snack and some safety. These guys showed up recently
This one has already lost one side
/ Local Sanctuary #2
Nice body on those deer! Never seen a feed "bucket" like that either.
/ Local Sanctuary #3
Nor have I ever seen a feeder like this. How does it work?
/ Local Sanctuary
Hole in bottom of bucket is slightly larger than the rope. Rope is attached to a board at top of bucket. When deer shake the rope, the corn falls out. Or when it is really windy the corn will fall out. I have had this particular one (which is actually a metal trash can) for 10 - 12 years.
/ Local Sanctuary
Our deer in Alabama do not typically have big bodies, just normal. I thought these were larger than I have seen in the area. Maybe they are just full of corn.
/ Local Sanctuary #7
Thanks, learned something new (again) today. How'd you teach the deer to shake the rope?
/ Local Sanctuary
It is fun to watch how different deer will get the corn to fall. Check this out:
Some deer actually bite the rope and swing it, others stick their mouth right at the hole in the bucket.
/ Local Sanctuary #9
yeah thats neet i will be trying the trash can deal, i;m surprized they still got ther horns this late nice pics
/ Local Sanctuary
The 2x4 board is right at the top of the can, held there with screws from outside in.
The rope has to be replaced often. The squirrels and racoons fray it in a hurry
When I buy new rope, I get extra and wrap a good bit around the 2x4. When the current rope has a frayed end, I just cut it off, and unroll some from board.
/ Local Sanctuary #11
I've seen them in 5 gal. bucket with a "flapper" like that, a friend of mine bought one back in the late 80's, had hard time keeping it filled it was so small.
/ Local Sanctuary
I made some out of 5 gal plastic buckets, but they do not last as long. One more note, the tie for the rope can also be a pvc pipe. Cut holes in both sides at top bucket, slide in piece of pvc, place elbows or something on the end of pvc.
And I am not sure how well this would work in remote areas that were not visited often, because there is a limit to amount of corn the bucket will hold. My trash can will hold 50 lbs, however.
/ Local Sanctuary #13
Saves having to refill every few days! I bet you could do the same thing with a 55 gallon drum. Do you have B bear there where you are?? Just wondering, they can be quite destructive.
/ Local Sanctuary
Do not have bears in the area, but I have been amazed at what raccoons can do to a bucket.
/ Local Sanctuary
THEY'RE BACK
This time I threw out some corn in the woods near my house, I thought for the turkeys. I threw out a half bucket full among the leaves, next day it was gone. Threw out some more, same story. So I put the camera on the spot to see who was eating it. Here are the results
/ Local Sanctuary #16
Do the deer not shed antlers in the winter down there?
/ Local Sanctuary #17
Nice pictures....thanks for sharing.:thumbsup:
/ Local Sanctuary
Yes, they do shed. One of the pictures earlier in the thread showed one that had lost one side. I googled the timeframe for Alabama and several sites indicated well into March before they shed. As a matter of fact, Alabama Conservation Dept is considering extending hunting season on into February for some counties in south Alabama because they have scientific evidence that the rut in some areas extend well into February.
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
Water Pump with Engine (A65640)
Water Pump with...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
