OP
steveessie
Member
I would use a 2X and gorilla glue (the expanding type) on both sides of the break. Cut the lumber of same width as existing and long enough to go past the splits on both ends at least 4". Squeeze glue on the 2 brace pieces on one side. Using c clamps to clamp both sides in place and then run several screw through both sides. So that when u are finished the original board will be sandwiched between the 2 new repair boards. If u have never used gorilla glue, don't run a thick bead or it will squeeze out and make a mess. I would either put c'broad or something under the repair to catch any drips.
It would be nearly impossible to do it on both sides unless you took off the side metal walls, correct?
