Buying Advice M5640SU
/ M5640SU
I had rears loaded and it was still alittle light,couple more hundred of wheel weights would be good. I had a 700lb box blade on back
Sorry for all the questions. If that tractor will lift 2400# with only 700 lbs of ballast, I may be good to go.
Without the box blade attached, and just loaded tires, if you scooped a bucket of something like crusher run, what would happen. Would the rear just get light or would they lift off the ground ? I'm guessing but I would think that the bucket is about 1/3 yard so maybe 700-800# of stone??
Bill
/ M5640SU #22
bill you need loaded rear tires and the cast centers i scoop my drainage ditches out the water runs out of the bucket the rear dont lift at all its a mixs of sand and top soil
/ M5640SU
I just wanted to add that pretty much any Kubota is gonna make a fine tractor 4wd or not. I doesn't sound like you need 4wd like I do so I think the 5640 2wd would do well for you. That's why Kubota offers both.
I like Kubota. I wish they were a little heavier, but that can be corrected with wheel weights or ballast. For the most part IMHO they are well designed and built. As far as the color goes, no one can say they didn't see me.
I hope that's a brush fire in back of your tractor and not a test for the blah blah insurance company.
Bill
/ M5640SU
If it's a 1/3 yard it would be almost 600# of water if you filled it. I would think sand mix would be even more. If I get 4x4 bales 600# is about what they weigh. So that's good news. Any smart people out there that would agree or disagree with my math.
Now, if your really smart, what would it weigh on the Moon?
(Sorry, getting a little punchy.)
/ M5640SU #25
Bill
I load round bales 4x5 around 900-1000lbs with just loaded tires nothing on back without any problems.. The issue when you get around the ton mark is the rears slipping and I could run in 4x4 to help out with traction. I felt comfortable picking my artic cat prowler up with the forks and driving up my gooseneck to load them at same time,with nothing on 3point(guessing 1200lbs). I also widened mine out some for stability,the 5040 was a very stout tractor,that never gave me any troubles.
/ M5640SU
Thank you all very much for your input. You have all been a great help. These things don't often have loaders on them when I'm looking at the dealers, so first hand knowledge really helps me out.
If anyone would like to send money, that would be nice too. (No, don't do it! I'm only kidding!)
Best, Bill
/ M5640SU #27
kubota%205040.jpg only picture have on blackberry,rest on laptop at office.
/ M5640SU #28
Well OK, I'll bite. How did you set it down once you got it up on the trailer?
/ M5640SU #30
Gotcha. Pardon my bifocals, it looked a bit wide to me.
/ M5640SU #31
Tires set on trailer with about 6inches front and back and I strap it down in a X pattern.
/ M5640SU #32
We have an M8540 with loaded tires and it still needs 4WD to effectively use the FEL; yes, on flat land with sufficient ballast on the back a person can get by, farmers did it here for many, many years and I have driven them. Many compensated by adding dual wheels, as mentioned, workable, but far from optimal.
I agree 100% with you same experience with my m8540. Loaded tires and ~1500 lbs of ballast on the 3pt the in 2wd the loaders effective capacity is barely just the loader and empty bucket as i can't back into my barn in 2wd up the gravel drive that has about 2.5 feet of elevation change in 60 feet of drive without massive wheel spin. But seriously 1000- 1500 lbs is probably max i can move around in 2wd. Or Maybee a 1/3 of an 84" bucket of clay
To the OP you could probably max out the 3pt lift capacity with ballast and still have trouble maxing out the loader on anything other than pavement with a 2wd. I am convinced you would be disappointed with the 2wd i know i am with mine as i often use 4wd with nothing on the loader. I know money is tight i waited 8 years before i could afford the tractor i wanted
The lowes guy was impressed i could lift a 2600 lb pallet. I offloaded 2 3000 lb pallets of decorative stone for my neighbor had to grab the pallet long ways 42" rather than the 36" that was pushing it with only a little over 1000 lbs on the 3 pt the rear tires were not doing much in that case
/ M5640SU
Not that I doubt anyones facts or experence, but there has to be more involved here. Is the tractor loader combination that different between the 5140 and the 8540?
Using the 8540: "Loaded tires and ~1500 lbs of ballast on the 3pt the in 2wd the loaders effective capacity is barely just the loader and empty bucket. "
Using the 5140, lifting 2400lbs; "I had rears loaded and it was still alittle light,couple more hundred of wheel weights would be good. I had a 700lb box blade on back " Foreman says
"I load round bales 4x5 around 900-1000lbs with just loaded tires nothing on back without any problems.. The issue when you get around the ton mark is the rears slipping and I could run in 4x4 to help out with traction."
Note; AROUND THE TON MARK, with no counterweight.
On the 8540 it needs 1500lbs to counterbalance the loader bucket, yet a 5140 can lift 2400 lbs w/700lbs ballast? The photo of the 5140 has him lifting a 1200# ATV with no ballast! How is this possable?
Based on this I would think that if you picked 2400# with only 700# of ballast on a 8540, it would stand on its nose. There must be something very different in the design of these two machines. Maybe a different anchor point of the loader relative to the WB?:confused:
Bill
/ M5640SU #34
My tractor in picture just had loaded rears,picking up the prowler. Here are some with the 7040 without loaded tires unloading my feed one pallet is 2,000 and the other is 2400lbs
My other 7040 has loaded rears and it handles them way better...
/ M5640SU #35
Bill
Bill
I think you missed the point of my message when i said effective capacity. If all i can do is lift up a load and not move it's not effective.
All of these guys have 4wd if they had 2wd they would not be moving 2400 lbs pallets or utvs. At least in reverse. On anything other than purely flat ground and not wet ground. In 4wd you can move stuff with the rear tires floating in the air. Just because you can lift it does not mean you can move it in 2wd. If all or most of the weight of the tractor is shifted to the front wheels good luck moving in 2wd.
In 2wd i can very easily spin my tires with nothing in the bucket on even a slight incline.
In the attached picture i have an 8ft piece of swamp oak that measured 36" at the small end and about 48" across the y i have no rear ballast as i had to pull out of a tight spot earlier that day. This log wet weighed in excess of 3300 lbs i had no trouble moving it in 4wd. My rears tires were almost off the ground just look at the picture. The rear wheels bounced off the ground upon lowering the loader and stopping to abruptly.
Without 3pt weight my tractor weighs in at about 10000 lbs.
TripleR basically said the same thing about the value of 4wd with a loader
The dynamics of the m8540 are not really much different from the M5140. M8540 weighs another 1000 pounds base machine weight. And the loader lifts 1000 lbs more 800 mm ahead of pivot to full height.
/ M5640SU
View attachment 305205View attachment 305206
My other 7040 has loaded rears and it handles them way better...[/QUOTE]
Impressive! One picture is truly worth a thousand words.
Now after lowering the load if you needed to travel up a slope, I imagine you would need 4wd, or ballast. Yes?
Just the weight of the cab must help some.
Are those bags empty?:laughing:
/ M5640SU #37
Bill I should have elaborated this with nothing on the 3 pt on Nearly flat ground. And that pallet of shingles weighs about 2700 lbs. I only had my empty carry all on the back which only weighs about 500 lbs max
/ M5640SU #38
Its really nice to have the 4x4 when you need it. The more weight you can put on the rear tires the better off you are with just 2wd,and even then your going to have trouble now and then. I just went down to move some hay for a neighbor who has a older 60hp international 2wd with loader,and I was able to move them without using my 4wd with just the difference is my tires are loaded. Well I had my radio going also...
/ M5640SU
Bill
I have had similar situations with my L3240 ( with much lighter loads of course) I can pick up a 4x4 round bale with no counterweight. The rear is light and I cannot go up a grade without 4wd. So I do understand your point. However, if I hang 800# on the 3PH I can climb the grade in 2wd.
"To the OP you could probably max out the 3pt lift capacity with ballast and still have trouble maxing out the loader on anything other than pavement with a 2wd."
Is it your experence that if I had a 3,300# counterweight on the 3PH and maxed out the loader @ 2,500# that the tractors wheels would spin on anything but pavement?
I may be wrong but I wouldn't think that Kubota would want to install a loader that would nullify the maximum counterweight.
Something to think about; If you lift 3,300lbs with your loader, and the rears are off the ground, you have 3,300# + 10,000# all on your front axle.:eek:
Best, Bill
/ M5640SU
I guess The big question is, not whether 4WD is better. I think that's a given, but whether a properly ballasted 2WD will work.
The fact of the matter is I cannot now, or most likely in the future, afford a tractor that will lift 2500# AND 4wd.
If a 2wd is not going to work except in ideal conditions, then I'm better off with the smaller L series that I now own and move smaller loads.
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
2022 John Deere 5055E (A60462)
2022 John Deere...
2016 Ford Transit Van, VIN # 1FTYE1ZG8GKB07239 (A61165)
2016 Ford Transit...
