Preferred Style Of Tire Chains?
   / Preferred Style Of Tire Chains? #21
Nice. Which version of the Trygg chains did you get? It looks like they have the same sort of lineup as Tellesfdal. I used a 4 1/2" grinder with a thin cut off wheel to trim a couple of links off of them, it seamed to be the easiest way. Not sure if you'll need to, some of the Trygg chains used removable links. I found that the best way to install my chains were to jack the tire off the ground a few inches. From the rear of the tractor I just place the end of the chain on the tire then spin the tire so it drags the chain into the tire. I stop when the end of the chain is about half way up the back, 3/9 o'clock position. I then connect the center two chains, as snug as I can get them by hand without fighting with the chain. Then the sides, the sides will tighten the entire chain. My directions say leave them sort of loose but I run them snug and have never needed springs or anything like that.
   / Preferred Style Of Tire Chains? #22
Anybody have any trouble with sticks and branches getting caught in the chain then when the branch comes around busts up the fenders, cab etc...? I work my l4740 in the woods a fair amount and would like some chains but do not want the damage.
   / Preferred Style Of Tire Chains? #23
That can happen.
Gordon, thanks for sending those pictures. Your post came at about the time I was outside putting the chains on! My chains are very similar, and your method of installing is pretty much the same as Trygg recommends. They have a video on their website, too. They say, and I did, run a piece of rope around the rim and attach the hooks of the chain ends to it, then drive forward. An alternate method is to hang the rope over the upper tread lugs. I hung the chains on both tires at the same time, and had my wife pull forward while I helped arrange the chains on the tires. Worked great. I was going to jack up one wheel at a time and rotate the chain on, but driving them on was easier.
This particular style is what Trygg calls "Flexi", and by that they mean that it's easy to adjust the length and the side chains. The last two "sections" are attached with S hooks and shackles, making them easily removable. There are three places in the side chains where they have detachable links so you can shorten the diameter of the chains when they're on the tire. The whole idea is to be able to tailor the chains to fit the tire no matter whether the tire is brand new or worn down, or to handle size variations between tire manufacturers.
When they were rolled on they were longer than necessary, so I removed one section, then shortened the sidechains by one link in each of the three places, front and back. They seem pretty good now, but might need some fine tuning after driving around a bit. I didn't put tensioners on yet, but think I'll probably do something in that regard, maybe some rubber tiedown straps.
Crazyal, I didn't have to remove any of the links that weren't already detachable. Where I shortened by one link I left it dangle. On the cam-hooks that hook the sidechains together, you could gather the extra links and hitch them with the hook arm. If I had to cut them I would use that grinder cut-off wheel method. I saw that in a video. The great thing about having widened out the wheels is you don't have to worry about a link or two flopping. Now to go climb some snowy hills! Also, they're predicting a possible wintry mix, so I may get to crunch up some ice.
As far as getting roots or sticks caught in the chains in the summer, that's a definite possibility, something to watch out for, just like the possibility of getting a branch through the radiator, etc.
   / Preferred Style Of Tire Chains? #25
Whenever discussions of chains come up, there is always talk about chains falling between lugs and becoming what? less effective? Basically I think this is an old wives tale for several reasons. 1. Chains are sometimes put on too tightly. As a result, they cannot "work" themselves into the largest benefit for traction when the tire comes around and the chains meet ground. 2. With looser chains, it does not matter a wit what they look like on top of the tire, its how they engage the ground on the bottom. 3. Even with tight chains which look like they are sitting between grooves, I have never failed to see the chain imprint on the ground whether it'd be snow or dirt. I've got the simplest type of chains on my ag tires (4 link ladder) and even these have turned my tractor into a different machine traction wise.
   / Preferred Style Of Tire Chains? #26
Happens all the time to me. Not saying its impossible but nothing like this has ever harmed the tractor. I find the branch or twig gives way and disengages before any real damage can occur. Most of my damage has been because of running over stuff unavoidably when in the woods.
   / Preferred Style Of Tire Chains? #27
Loose chains are not an option on my DK35 with R4's. The rims are one piece so the width is not adjustable. I had to pound the cross-hooks flatter to get clearance to the vertical fender support. My neighbour gave me a set of ordinary ladder chains that perhaps left a few marks on the ground. But most of the links were hidden between the lugs and there was little improvement in traction.
I purchased DUO's for the rear and converted thee free 4-link ladders to 2-link ladders for the front. The ladders work fine on the front because the lugs are not as deep as the rear tires.
   / Preferred Style Of Tire Chains? #28
No offense, but your chains are riding on top of your ag tires lugs. Heck, the chains look like they are taller than the lugs on your tires. I really dont think tight or loose would make a difference for your application. My R-1's are 11.2-24 on my fronts and the lugs are much deeper than yours (less than 300 hours on them) and if I had a standard 4 link set-up, I think the lugs would hide the chain the majority of the times. If I had them loose, there wouldn't be any pressure pushing the chain into the snow/ice and therefore no traction. Hence why I went with the Duo-grip V-bar style. They made a big improvement on the ice, but I think I can modify them to be closer spaced and get more links on the ground per rotation instead of the gaps that I have now. The V-bars also need to be somewhat tight to make sure that the "V" faces the ground and doesn't roll into the tired tread negating the grip.
   / Preferred Style Of Tire Chains? #29
No offense taken. I don't mind a good discussion with opposing view points delivered as gentlemen; that's how people learn. Now I'm going to oppose you. Here are pictures of same tractor with new tires with not 3 hrs on them. The fronts do not have 10 hrs on them. My chains are loose and are able to sort of seek their own level. They are what strike the earth first and whether they are here or there, loose or tight, they will always provide more traction. I cannot agree on your theory about chains needing to be tight to provide optimum traction because chains will only go so far before they dig in even if they are loose. What helped you on ice was the v-bars. If you cannot run your chains a little loose for clearance problems, then you may run into the trouble you are describing but it is not a standard,be all axiom for chains to always attempt to state: "these chains are no good because they ride between the lugs" in my experience. If I believed that, I would not have bought the simplest chains which have aided my traction immensely and have cost under $300. So now we are at a point of disagreement based on our own experiences. What might be the differential as to why this happens sometimes and not all the time? My fronts are small and in comparison ratio, so is the chain yet the same thing is happening with them as what's going on with the rears so I am not certain tire size and lug depth are what provides this differential. I'm thinking tight fitment is the culprit. Lug angle may be another but my old tires were a lesser angle and the chain still came to rest on top of lugs at traction point. It seems no matter what the tire there appears to always be the ability of chain traction even with simple ladder chain. As a matter of fact, ladder chain may be the better solution than duo grips.
   / Preferred Style Of Tire Chains? #30
I'm doing the same thing with my DUO's (i.e. reducing gaps) RedNeckRacin. Here's a link to a thread I started about modifying them:
http://www.tractorbynet.com/forums/attachments/268885-duo-chains-planned-modifications.html
I ordered the eight DUO patterns Monday and they should arrive next week.
EDIT: ADDED THIS AFTER LOOKING AT THE FIRST PHOTO IN THE REFERENCED LINK:
Arrow, the first photo in the referenced thread shows a couple of plain cross chains I added to try to fill in the gap of my DUO's. Although the plain cross chains are sitting on the lugs you can see how they will thread themselves into the lugs once used. However, I agree that if mounting the chains loosely on my tractor was an option they would not fall in the lugs and would be effective.
   / Preferred Style Of Tire Chains? #31
I dunno Ken, I think you would have gripped just fine with the way you have it. It does not look any different from mine orientation wise and mine grip like King Kong on the Empire State building. Even if they were between lugs, my opinion is that they would still help as the lugs on your type of tire are rather shallow and thus the chain would always make ground contact. To me the proof of the pudding is the tread pattern shown on the ground. I always have "chain indentations" whether it'd be snow or dirt. I think the advantage of the 2 link ladder chains is you would get a bit better ride as you are attempting with additional cross chains. I'm not a fan of duo's because of their spacing and do not think they offer any advantage at all for lugged tires. So why do they exist you ask? I think mostly for customer's concerns rather than actuality. Our skidders had something like duos only on a much bigger scale. They are called ring chains where the rings actually aided traction as the connecting links. Of course lug spacing was large enough where your splayed hand couldn't touch from one lug to another and the ring connectors were 10 inches in diameter. I think tire chains for compact tractors kind of carried this theme over to much smaller tires and this seems irrelevant to me at the compact tractor scale. If mid connectors for tire chains allowed one to ride on the "chain" part all the time, this to me is an effective design. This is the type of design skidder chains are as well as the Nordic type chains for smaller tires.
Good luck with your tire chains and i hope they operate the way you want.
Lou
   / Preferred Style Of Tire Chains? #32
Yes, very true. However, your R1 tires appear to have a fair amount of wear on them. The more worn they are the better the chains work. I had an old Ford 9N with very worn R1 tires and my chains worked great for years. I finally got brand new tires and suddenly my chains didn't work nearly as well as the cross chains were down in between those nice new deep cleats.
   / Preferred Style Of Tire Chains? #33
I suspect tire size and lug design is also a factor. My new 13.6x28 R1 tires had lugs which appear to be much deeper than your new tires and my lugs weren't quite so pitched - a bit more horizontal. As a result, my cross chains disappeared completely between the lugs and only touched the ground now and then. Yours however seem like they would work fine.
   / Preferred Style Of Tire Chains? #34
See post no. 29
   / Preferred Style Of Tire Chains? #35
What type chain? If they're duos, I think you have more of a chance for this to happen than ladder chain especially if the ladders are 2 link. These chains always seem to be able to "cross over " lugs at some point. There seems to be just too big a space between cross links on duos. i think another factor could be the size of the chain diameter itself. Mine at 3/8" are substantial for my tire size. For tires your size perhaps they should make the chain with 7/16th or even half inch links.
   / Preferred Style Of Tire Chains? #36
Lou
Lou, I did try some very worn, 9/32" 4-link v-bar ladders my neighbour gave me. Here is the photo of those chains:
Although they are on the lugs in the photo, upon use they completely disappeared between the lugs and were ineffective.
I modified those chains to 2-link ladders this year and they are very good for the shallower front tire lugs. Here is a photo:
My DUO chains with regular chain cross links I used to fill the gap are the same diameter as yours--i.e. 3/8". In my previously posted photo showing these newly installed cross links it looked like they would ride over the lugs. But they don't--mostly settle in the lugs. Here are two photos taken today, showing them down in the lugs:
There is very little (non-DUO) chain protruding above the lugs. The photos also show the DUO's do an effective job of keeping chain above the lugs.
I considered 2-link ladder chains before ordering the DUO's. Regular links cost $730 and square link (which I preferred) cost $1,050. My DUO's cost $320. Choices for my 43x16-20 are VERY limited and further complicated by non-adjustable rims and tight horizontal clearance to the fender support.
As you stated, DUO's are rough due to the gap between patterns. I am confident my modification, which eliminates the 2-link gap between DUO patterns (I'm adding 4 patterns to the existing 7 patterns), will mitigate the roughness while further improving traction. And the total cost will be $506 (original $320 + $196 for additional patterns).
I think the best chain for my use would be the Tellefsdal, Aguiline or Trygg patterns mentioned by others in previous posts. Their only disadvantage is the cost.
Cheers
   / Preferred Style Of Tire Chains? #37
Cheers
Great pictures Ken!. It is most unfortunate you cannot run these without the tensioners as this might solve the traction grip problems. You are right about the limited selection for this tire size. I looked at this when I was about to pull the trigger on a Mahindra 3016. The dealer was willing to swap tires from the 3616 next to it and these were the 43x16's. I went home to look for chains and there was not much selection. When he wanted $500 more for the tractor with these, I balked at the deal so I put new rears on the my old 750 and continued to use my old chains. I was a bit worried with the new tires and these chains but the chains react just as they did on my old set. Mine are loose and traction is excellent with them. I also think the Nordic chains are the best but I think you can manipulate what you have to produce good traction.
I think we are looking for different things traction wise. You are wanting grip on ice so it is important the chain rides proud on your lugs. I'm looking for increased woods traction when logging so my chains always come to bear in this regard. This is a great discussion as it is bringing out all the mostly unspoken details of tire chains for our tractors.
   / Preferred Style Of Tire Chains? #38
This is a pretty interesting discussion.
To add my way of thinking, and I have no proof of this, when the chains are working hardest they have a lot of force on them. This force will move them to a position where there is less force on them if it can. In this new position they are doing less work because the force on them is less. Once there they will tend to stay because if they move the force gets greater and pushes them back to where they were. Loose chains move easier but are easier on the tires. To make loose chains most effective the design has to be such that the cross links can't hide between the lugs. Loose chains are better in mud because they "shake" them selves out so don't load up as much as tight chains. Just my two cents.
The great thing about the Trygg chains in the "H" pattern is, besides all those ice studs, the chains form two continuous bands around the diameter of the tire. There is always chain on the ground for grip, and the ride is smooth. In their installation video they show that when the chains are properly adjusted you should be able to pull them away from the tread about a fist's worth. I got mine adjusted like that or just a tad tighter, and it's looking like I don't need tensioners.
I took a test drive in some deep snow and was having some trouble turning, so I borrowed the chains from my pickup for the front tires, four link ladders. I asked my Kubota dealer what he though about chains on all four tires, and he suggested just putting a chain on one front wheel in addition to the rears, and that would help keep the gears from binding up. Anybody ever tried that, or have an opinion?
   / Preferred Style Of Tire Chains? #40
Chaining up one front tire doesnt make much sense to me but maybe it is a good idea I have never tried it. The dealers are reluctant to say chain fronts because of the relative weakness of the front drive components compared to the rear. If you are slipping and the front catches before the rear it puts a lot of shock on the front drive. With only one chain this wouldn't happen brcause the other side would slip. The one chain would help on ice, helping prevent side to side slipping. But it would be like 2WD because the free tire would get all the power. Not sure about steering in deep snow ?? Might help. I have to use my steering breaks constantly in snow but I realize thats not so easy on an HST tractor.
If you search you will see opinions both ways on chaining up both fronts. I can't recall anyone running one chain. If you try it let us know how it works. It seems there are quite a few that do chain their fronts.
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
UNUSED SDLANCH SDLC2030FT-20'X30' CARPORT (A60432)
UNUSED SDLANCH...
2023 RTVXG-850 SideKick (A61306)
2023 RTVXG-850...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2021 Deere 331G (A53317)
2021 Deere 331G...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
