Hauling tractor with a car trailer?
/ Hauling tractor with a car trailer? #61
A picture is worth a thousand words:
rim
/ Hauling tractor with a car trailer? #64
007.jpgI dont have pictures of my ramps but they are all 2x2x1/4 angle and I dont have a problem with them bending or bowing. 4000 # should be like loading a tinkertoy on a trailer with 7000# and up gross weight. The only problem I have with loading is that it picks up the rear of the truck when loading if you dont block up the trailer which I dont do, just continue to drive up the ramps and it eventually comes to earth but ramps dont bow and this tractor weighs in excess of 8500#. My only complaint is that when loading the B26TLB the back hoe drags a bit so the ramps could be a bit longer.
/ Hauling tractor with a car trailer? #65
well, maybe so but you have to remember my tractor has a backhoe and with that attached the
CK20 with backhoe and front end loader weighs in at 4000 lbs. But you are probably thinking what makes that different than a car. The difference is the entire weight of the tractor is solely on the ramp as it has a much shorter wheel base then most cars that only usually accomodate one axle at a time unless maybe it gets compared with a YUGO. The trailer gross rating is 7000 lbs. and is adequate for the tractor.
All 4 tires of your tractor can fit on the ramps at one time ?, doesn't 'look' that short/long.
/ Hauling tractor with a car trailer? #68
View attachment 296384I dont have pictures of my ramps but they are all 2x2x1/4 angle and I dont have a problem with them bending or bowing. 4000 # should be like loading a tinkertoy on a trailer with 7000# and up gross weight. The only problem I have with loading is that it picks up the rear of the truck when loading if you dont block up the trailer which I dont do, just continue to drive up the ramps and it eventually comes to earth but ramps dont bow and this tractor weighs in excess of 8500#. My only complaint is that when loading the B26TLB the back hoe drags a bit so the ramps could be a bit longer.
My TLB manages to drag a bit also but I made some wood plates that space the bottom of the ramp up 3" lowering the angle. That took care of the drag. So far as lifting the front of the truck I always try and prevent that by slipping in a couple of jack stands beneath rear frame of trailer and I even chock the front of tires to keep from pushing the rig ahead as I load the trailer.
rim
rim
/ Hauling tractor with a car trailer? #69
now I see why his ramps bend. I wouldn't load anything latrger than a scut or rider mower with them.
I use heavy 2" angle for most of my ramps.. my '3rd' ramp for my trikes is 3" angle, as it gets a huge portion of the tractor weight till the rears get to the other ramps
i think that wood block arangement will be dangerous. at least the way it is mocked up.
solid timber cribbing.. maybee.. beter ramps.. deffinately.
my life is worth way to much to use 'just barely-maybee' ramps loading LARGE pieces of iron...
/ Hauling tractor with a car trailer? #73
You could also put the truck in 4wd to have "park" apply to the front wheels as well
Not sure that works with electronic 4wd, never tried it but I do know there is a 2 second delay before mine kicks into 4x4 after the motor is started...Maybe if the tow vehicle is left running while loading?...Who knows. I'm not trying that.
/ Hauling tractor with a car trailer? #74
Sounds like we better all be using our seat belts., at the very least.
rimshot
/ Hauling tractor with a car trailer? #75
It may not work with that, my trailer ramps have stands so I don't have to worry about it
/ Hauling tractor with a car trailer? #76
It works on my Fords and Nissan. There would be no way to load and unload the boats I do without it. Not sure about other brands.
Chris
/ Hauling tractor with a car trailer? #77
Chris
Are they running or shut off..That's the question.
/ Hauling tractor with a car trailer? #78
I never shut off on the ramp but my guess is they would since vacuum holds the hubs. So no running, no vacuum.
Chris
/ Hauling tractor with a car trailer? #79
Chris
I've never had mine slide on in the snow when parked on a slope running and in 4x4...So I assume that it's also loked in. My curiosity was whther the gears stay locked with the power off...I'll have to test that once..True no motor, no vacuum...But I still wonder if the gears remain engaged if the 4x4 was in when shut off.
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2014 WESTERN STAR 4900 SF SLEEPER (A60736)
2014 WESTERN STAR...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
