tkappeler
That sounds good with the metal studs and all. I haven't seen homes done with pre-cast walls and wondered how the interior finishing works. In my climate, I would add insulation between the studs most likely.
What do you have planned for exposed exterior portion of the basement walls?
Nothing initially but it will ultimately get the same stone facade as the fireplace.
I see you are using Superior Walls. I knew a builder that used those a bit around here. The crews struggled a lot with getting everything level enough to be satisfactory. I would double check that the top of wall is flat and fully level before cutting them loose. You will need to drywall over the exposed foam too as it is not fire rated, but it sounds like you plane to finish the space anyways.
Nice to see progress!
How long ago was that? I would guess that is more related to the installation crew and not the product. They were used 2 miles up the road this past summer. I will have to contact the builder there and ask about his experience. Thanks for the heads up!!
