New Home Begins
/ New Home Begins #1
tkappeler
Platinum Member
Hainesport, NJ
TYM T293
Settled on the new 3.5 acre property on Friday. It's been abandoned and vacant for 12+ years. The home will come down when demolition permits are issued. In the meantime, site work begins including tree removal and cleaning up what is just this side of an episode if "Hoarding". These are BEFORE any work had begun
/ New Home Begins #2
Congratulations on your new property. Now, that is an ugly house. Good luck with your project.
/ New Home Begins #3
Wow, that is a nasty house. Lots of clean up ahead!
Good luck, and congrats on the property.
/ New Home Begins
All exterior cleanup is complete. The two trailers are empty and into a 30 yard dumpster. Tree removal underway. Pictures will follow.
I have one tree that has an approx 1' diameter hornet/yellowjacket/wasp nest up about 30'. Any suggestions on how to cut it down and avoid the critters? Cut and run?
It is too high up to spray with anything. I have no water source out here.
/ New Home Begins
Already logged 20+ hours on the new T293. Sweet. I can't imagine doing this my hand.
/ New Home Begins #6
Well they must have liked to throw somethings away because there seem to be a lot of trash cans about. If you have no water source, how are you going to have a house there?
/ New Home Begins
The well won't be installed until much later.
/ New Home Begins #10
Congratulations on your new property; lots of work, but lots of potential too.:thumbsup:
/ New Home Begins #12
Congrats Tom. I Look forward to following your progress.
You might consider resizing you pictures smaller before uploading them. Your first pictures are very large and don't display very well using a mobile device (slowwww to the point of unusable). I typically resize my pictures to 640x480 before uploading them to my thread on TBN. Makes for friendlier viewing. Just a thought.
I have one tree that has an approx 1' diameter hornet/yellowjacket/wasp nest up about 30'. Any suggestions on how to cut it down and avoid the critters? Cut and run? It is too high up to spray with anything. I have no water source out here.
That kind of hornet is very agressive. I once wrecked a tractor after I bush hogged a 2 foot tall sapling with a hornets nest on it.
Does that tree need to come down now? Personally I would wait, if possible, until winter when the hornets leave the nest. There is no way I would cut down a tree with a hornet's nest that size in it. You might be able to get away with it but you might get nailed before you get the tree down.
As a kid, I would throw rocks at hornets nests from far enough away to keep from getting stung. You can knock the nest off the tree with one or two well aimed rocks. The hornets will leave the nest once it is on the ground. We would occassionally find a hornet's nest in one of the trees in our apple orchard. You could just say good-bye to the apples in that tree.
Obed
/ New Home Begins #13
You might be able to knock the hornets nest down using a shotgut but be prepared to run.
/ New Home Begins
haha ... in NJ? Maybe that would work in TN, but here, I'd be arrested before the sound reverberation is gone. Townhouse development 1/4 mile away (out the back of the property).
/ New Home Begins #15
Congradulatins on getting the property. I would do a night assult on the hornets if you have to have the tree removed otherwise I would just leave them. I would not try to cut it all at once and I would warm the saw up first away from the tree. As soon as they feel the vibrations they will come say hello. Good luck.
v/r
Mike
/ New Home Begins #16
I wouldn't try this method with a nest as big as yours.
/ New Home Begins
Before the TYM was delivered, several trees were cut down and the wood left. Better to wait for the tractor to do the heavy lifting instead of us.
Cleared out two trailers in one afternoon and filled a 30 yard dumpster.
/ New Home Begins #18
Interesting site. Will be fun to watch your progress!
/ New Home Begins
Uncovered the trailer that we emptied. Placed a craigslist ad for scrap value only. Not road ready. Free to whoever can haul it away. 26 emails in the first two hours! :eek:
It is in far worse shape than it may appear here.
