Unlimited hot water
/ Unlimited hot water #41
I can address a lot of the questions from experience in our house:
We have a Bosch propane on-demand water heater in our new house, 1.5 years old. It works great! We love it. In the first 6 months our propane use was only about 60 gallons, but we are off-the-grid and have a large propane stove/oven, gas clothes dryer, and backup propane forced-air heat, too. That seems to be great efficiency, with a 2700 sq ft house, 2 adults, 2 kids.
( One thing that probably helped our efficiency a lot is that I preheat the water first with the water coils in the woodstove which go to a heat exchanger in a 500 gallon holding tank under the house. The water in that 500 gallon tank then acts as a heat reserve to preheat water coming from the well (maybe 45 deg in winter). My goal is to feed the on-demand heater with nearly 100 deg preheated water so it only has to heat the last 20 degrees. Our experience shows that if we use water that is preheated close to the 120 deg set point of the water heater, it may cycle on/off or not start up at all. )
I haven't done the vinegar treatment to the Bosch yet, but it will be fairly easy because of the valves under the heater that the OP mentioned. We do have very hard water, and have a salt-free water softener which seems to work great for mineral deposits on the faucets.
On our heater, the air intake and exhaust are the same metal pipe -- it's a pipe within a pipe. The inner pipe is exhaust and outer is intake. The exhaust gas is quite cool because of the counter-current heat exchange principle.
Marcus
Edit: Also, we have not experienced much of the hot-cold-hot sandwich that many people worry about. All the pipes in our house are copper, so it takes a little longer to get the hot water to the right temp, but the heat stored in the metal pipes tempers the cold water that comes in-between from turning the hot water back on again.
/ Unlimited hot water #42
We installed a Bosch hot water heater in our new 2 story home in the country about 7 yrs ago. We're on a well and have propane. Our initial problem with the unit was that it took forever for the water to warm up and when we tried to adjust the temp it would shut down. When I called a local (60 miles round trip) service rep listed by the company, he seemed to know little about our unit and the visit was a waste of his time and ours. I then called the company and was directed to remove the front panel and reverse a couple of wire clips on some copper tubing (why didn't the service rep know this?). We've had hot water ever since but have to run the water, and well pump, several minutes before it turns hot. Then it's too hot and if we turn it down too far it will go cold and needs to be reset. In washing dishes and clothes we again don't always know if it's cold or hot unless we check. My wife wants to pull the unit and have a tank installed but then we're out $1,000.00 +/- on our initial investment. Wish we had "hot water on demand". Has anyone had similar problems with the Bosch, Aqua Star? Any opinions or solutions?
/ Unlimited hot water #43
If you want to pre-heat the water why not install a wild loop with a small circulater as I did. Then you always have hot water as soon as you turn on the faucet and the tank gets the advantage of the warmer water returning to it instead of 40 degree water.
Are you refering to those systems where you put a 'bypass' at the faucets and run a recirc pump so you always have hot water at the facets?
/ Unlimited hot water #45
Pre-heating the water! What a grand idea. Wish we could do the same. Running hot water to our second story is a waste of alot of water and then the unit will sometimes shut down mid-shower. We have also found it to our advantage to leave the water running somewhere when we go to the garage to reset the unit. Wish we had shopped around and checked the consumer guides before we made our purchase.
/ Unlimited hot water #46
I've heard of that before but know little about plumbing and of what it would take to revamp my unit. Warming the water before it gets to my heater sounds like the way to go. Is there a tech report I can refer to for all of the details and supplies?
/ Unlimited hot water #47
AQ 250 SX LP is my model number.
/ Unlimited hot water #49
There is a manual for your unit at http://www.houseneeds.com/shop/manuals/bosch_250sxmanual.pdf
I would check the troubleshooting steps on pages 24-25.
Is there an error message that shows up when it shuts down?
Your symptoms sound like you may be getting a A9 error which is "Temperature limiter opened circuit (overheat)" form the burner not throttling down when the water flow goes down.
Thanks
Aaron Z
2020 John Deere 8R 280 (A60462)
2020 John Deere 8R...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
