Buying Advice Buying a compact Tractor
/ Buying a compact Tractor #1
Airportbum365
Member
Penetanguishene Ontario
Ford LGT 14D and Mahindra E-max 25 TLB
Looking to buy a compact tractor
The first one i looked at was the kubota BX-25 since they are around the corner from me
but i am worried that the repair parts will be expensive. Are kubota parts expensive?
Is there a better compact tractor that is built in north america that is less expensive on parts?
Thanks Jason
/ Buying a compact Tractor #2
The smartest thing you can do is stay Japanese built compact. The quality and engineering they put into their tractors is incredible. Kubota, well taken care of will give you years of trouble free service.
/ Buying a compact Tractor #3
I agree. I own a john deere 1026r and it is great. It is assembled in the usa
/ Buying a compact Tractor #4
Ditto. CC/Yanmar here and trouble free for 18 months. I only shopped those built in Japan, and assembled here. Lots to choose from. Enjoy the process:)
/ Buying a compact Tractor #7
Airportbum365 said:
Are Kubota's parts the most expensive??
Thanks
No, that would be john deere, but not a lot more expensive. Honestly its not like a car. You don't spend thousands of dollars on it every few years as long as you keep clean fluids in it.
/ Buying a compact Tractor #8
I don't believe there is a "better built" tractor than Kubota in that size and parts are in line with others; other makes are in my opinion are often as good and you will not be spending much on parts for any if you don't abuse them and service regularly.
/ Buying a compact Tractor #10
I've got 29 years of trouble free service out of a Kubota B6200. Just replaced my water pump for the first time.
/ Buying a compact Tractor #11
*Is there a better compact tractor that is built in north america that is less expensive on parts?
Thanks Jason
*What gave you the missimpression that Kubota parts were more expensive than others?
*Are Kubota's parts the most expensive??
WilliamBos said:
Probably thinking that since Japanese car parts are expensive, that the same may apply to tractors.
I was just told to ask around to see how much
Roughly they would be
/ Buying a compact Tractor #14
If you buy a new CUT and take care of it, parts will not be a concern for some time. Tractors are sturdier than cars, and - operated by those who care about them - last practically forever. I've got a John Deere 3038e and find it perfect. Had a cared-for JD before - 35+ years old - and bought one part in 11 years.
Pick a tractor based on your needs, how it fits you (meaning you have to actually run it a bit), and the strength of your dealership. If you are really into parts, pick some common parts and compare them online. JD parts tend to be a touch more... Sometimes. Some Kubota parts top JD parts. But it isn't something to heavily influence your purchase.
/ Buying a compact Tractor #15
Just bought a 2007 JD 3520, ehydro with 300cx loader, and 72" belly mower. It has 800 hours and in pristine condition. I believe the other owner only used it to mow. I feel like I got a decent deal at $18k. What do you guys think? This is my first operable tractor I've ever owned and don't know a whole lot about tractors.
/ Buying a compact Tractor #16
I looked at a ton of small tractors before I went with a Kioti DK45. I don't think it is built in U.S.A but it is still very high quality from the floor mat to the steering wheel, hydraulics, everything. it is an awesome tractor and I would highly recommend. I test drove a lot of tractors before I went with the Kioti including kubota, new holland, case, deere, branson. The Kioti was the best in almost every way I could think of AND it was the least expensive. No kidding I am totally blown away by the tractor. I did get an amazing deal though from a guy that needed to get rid of it quick and my nearest Kioti dealer is 2 hours from me so thats why I got it so cheap. Still at a comparable price it is definitely worth looking at. I got my 2008 dk45 with 120 hours with loader and a scraper for 15,500. I don't think you'll beat that deal anywhere but it was easily better than a lot of tractors over 20,000.
/ Buying a compact Tractor #17
Thanks Jason
Hi Jason,
The BX is a nice unit and Kubota prices are not out of line with other manufacturers. A BX may be fine for you depending on your needs, but go bigger if you can. It's nice to have the power when you need it. My BX is nice, but not much power.
/ Buying a compact Tractor #19
Have had three Kubotas; After 11,000 hrs (yes eleven thousand) my 1983 B6100 started to fail, my 2005 B7510 has 2100 hrs and dispite rolling down the ramp into the river has had no issues save a draglink and pittman arm that stripped and wore, and my 2010 L3400 has 700 hrs. Other than the above repairs the only thing I have done to them is oil and filters and a battery on the 7510 and front tires on the 6100 before trading on the 7510. Can't speak to the other makes as I have owned none save an old International 414 twenty years ago. But if my Kubotas were lost tomorrow; I would likely buy another
/ Buying a compact Tractor #20
Do you mean the B series?
Yes, the "B" series. As I noted, the BX is nice for small jobs, but not much power as the work load gets more demanding. That's when you'd regret not having more HP and capacity. Despite the power issue, it's been a very reliable tractor. I still use it often for small stuff.
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
