Traction Logging with industrials
/ Logging with industrials #21
Here's my L3830 logging. For my uses... the industrials are best! :thumbsup:
/ Logging with industrials #22
When I got my Kioti DK45 in 2006, I ordered it with R4s (loaded). I was ready to accept the trade-off of slightly reduced traction for greater sidewall toughness and a bit gentler footprint on turf.
Without chains, the R4s can pack up with mud or slip in snow more than ag tires would, but I've adapted my use to these limitations...I'm guessing I also use the diff lock more often in the woods with the R4 tires than I would with ags.
If I were going to replace my tires, I'd probably go with R1s, but pay extra for ones with additional plies...these exist, but likely aren't what your dealer would offer as an alternative to R4s on a new tractor.
BOB
Thanks to all who have responded so far. Allow me to get a bit more detailed knowing I am narrowing the "field of experience" and may get less answers. I have included a picture of my terrain. I know how ags react as that is what I have now. Ags could negotiate this forest floor w/o chains but chained up made them more efficient and more effective in deeper snow. This is a rock strewn, leaf covered and debris laden environment. Is anyone with loaded industrials negotiating the same type of footing or have you found them hopeless without chains on when traveling on this type of surface?
/ Logging with industrials #24
Rock strewn, dips and holes and lightly snow covered I have navigated with my R4's unloaded but with 3900 lbs. The biggest issue I had was the log getting caught on some rock or making a turn and crabbing against another tree the R4's w/o chains would slip but I think R1 would too,
I dont have chains and probably will not get any because I dont run in the winter much anymore - just the fall.
You know what R1's do, and as RD Mcgregor said get R1's with a stiffer ply 6-8 ply.
You have to weigh it out - how much time is in the snow covered, then deep snow and if less than 10% of the time then R4's are fine.
Also, your JD chains - will they fit the Mahindra w/R1 or R4? You are going from a 20HP 750 to a 30HP 3016 if I recall correctly - i didnt check the tire sizes but thats one more thing to consider.
Thanks Carl
I value your input as you have experienced similar terrain. I just got back from the Mahindra dealer and looked at these tires side by side. There is no doubt in my mind that the R1's are traction masters over the R4's. I know I can skid with those in a foot of snow. I am very unsure that R4's can do that even with chains as I have no experience with the beasties. Where the R4's will shine is when I stop skidding wood which I estimate to be in about 5 years. You bring up a good point. The chains, if I get some extenders, will fit the Mahindra with ags. I would have to buy new chains for the industrials which are around $225 for 4 link which isn't too bad in my mind and thus not a stopping point. The Mahindra with loaded industrials will also be around 4000#'s. With ags, it will come in around 300 less pounds. Nothing else fits. My tooth bar, my debris tines will all have to be modified. I'm looking at both tractors not knowing which tires to choose. As I am going over all the pluses and minuses of not only the tires but the entire thought of getting a new tractor, my mind scrambles and goes into a recycling mode just like it did when I was a youngster in school confronting yet another learning situation. I need to step back because right now I don't even want a new tractor if it is causing this kind of consternation.
/ Logging with industrials #26
Arrow,
Paralysis analysis - too much thinking. I would focus on what you want and need. Also your 750 is 20HP and is a good tractor - would you not be served by looking/considering a bit bigger than the 29 HP 3016?
Also used JD's are around - here's a decent JD in my area 43 HP and 500 Hrs $21K - this would be a big step up IMO from your 750. John Deere 4120 4wd 43hp Tractor w/ Loader
Here are two Kubota's 08 Kubota L3240 and another one 2006 KUBOTA L4400, DIESEL 4X4, PRACTICALLY NEW!
I would keep your eyes out for a good used JD or Kubota machine and get 32-35HP range.
Tire type and chains can be changed, HP and functional capacity/capability cant.
Carl
/ Logging with industrials #27
I log with R4s way up in Canada in deep snow and no chains, only liquid ballast but my tractor is quite a bit bigger than the one you are looking at. Ground clearance may be an issue with R4 on those smaller units in the wood IMO.
Maybe you should consider a larger unit.... Mahindra, seriously?
You guys are trying to get me committed . LMAO. Seriously I appreciate your input. Yes, a larger tractor would be helpful but I have a tendency to "make do" and I'm only skidding 5 to eight cords per year and not for much longer. A big tractor would give me more range but I refuse to chase stems more than a quarter mile. Lets say I've become spoiled after my skidder days.
I think I am formulating a plan based on what you guys have been telling me. Diesel, I believe Kubota makes the best tractor and if I were a youngin, that's all I'd consider but the dealership near me is plagued with an attitude that prevents me (and perhaps others) from doing business. Also, I am not a "brand specific" guy and I feel all the tractor companies makes stuff that will work. Also under consideration is a price point. I am at 12K out the door, tires loaded with my JD as trade for the 3016. This tractor has twice the lift and weighs a thousand pounds more than my JD so I'm thinkin it should suffice. If I can do what I can with the JD (pictured), I'm guessin the 3016 will do it a bit better. It'd be considerably more for the tractor I really want (Mahindra 4010). Plus with minor alterations, much of what I have now will fit the 3016. The other advantage for the smaller tractor is that these woods are so dense, it sometimes becomes a pain just getting the JD through.
/ Logging with industrials #29
Arrow,
Have you considered putting your JD750 up for sale? It appears to be clean and well kept and I would thinkin between $7-8K would sell reasonably fast.
What's your dealer offering? I guess what I am getting at is if you can get a bit more selling private and get what you really want (the 4010) then thats the course I would take even if it means parting with a few more $ today will make you happier in the loong haul.
Arrow,
I have Carl. He's showing me 6K for it. The JD needs about a thousand bucks of new rears as these are the original tires and are cracked to smithereens. But I'm high jacking my own thread. I believe I have enough info from all the different posters to make a decision. Much of whatever efficiency industrials have for winter skidding has to do with both the size of the tractor and the size of the tire itself. Therefore I think this is a doable entity to run the 3016 with over sized tires they normally put on the 3616 hydro. If they are not sufficient, I'll chain them up.
/ Logging with industrials #31
Arrow,
Pete's Tires -Locations has locations in New England and Providence and you can get the 9.5x24 for $425 delivered plus $70 for new tubes. Mounting these is a half day - I have done many and its not hard. Loading them is more costly and why do that.. and for that matter sell it as is.
Since you are selling/trading I would show the potential buyer if they think the tires are a problem tell them $550 to replace both and advertise it for $7900 locally on CL and if they want to have new tires tell them $8400.
I would sell it as is and if you can get $7500 then you have cash to negotiate, or if financing, you are in a better position to negotiate. The dealer will put it on his lot and will ask $8K probably and if they want new tires he will "add it on".
/ Logging with industrials #32
R4's are good for certain things.
but will take my AG's / R1's if had a choice.
it is the "unknown" sudden muddy patch. that R4's will begin to spin and slide. vs R1's that will keep on digging in and rutting but will pull themselves right on through. been up axle deep and keep on going. while R4's would of had me stuck.
tire tread is a big factor. had to put new tires on the 555C TLB due to one tire dry rotted and cracked out the side wall a good portion of it. tread difference between new and old. i would say old had 70% tread left. it was a completely different machine with new rear tires on it. granted i still got myself stuck, and had to break out the FEL and backhoe to get my rear up to better ground. but to slight mud patches to wet grass were i use to slip the tires or simply slide side ways on a hill i would not with the new rear tires.
if i had R1's on the rear of the 555c TLB. there would be no doubt i would keep on going. BUT! the problem with the 555c TLB. is it is so heavy, and doing a lot of dirt work. just having R1's on rear. i would be doing more time spending clean up ruts than actual working the tractor. vs the R4's that yes do rut, but the ruts are so wide and not as deep that it is fairly easy to clean up the ruts.
on the old allis chalmers CA tractor i do have AGs / R1's on it and it is primarly only does finishing mowing. yes R1's can and do tear up the yard, when i make a sudden sharp turn. *coughs some* i like doing tight 360 donuts spins around trees in high gear while mowing. and if it just rained in last day or so. you can really see the tire impressions in the yard. and perhaps even a chunk of sod ripped up. if i was on a heavier tractor things would be worse for sure. but *shrugs*. just do not think R1's will tear up yard as soon as you roll them on to the yard. any tire will, including R4's will tear up the yard, and if it is to wet it is just plain to wet and muddy to drive anything on the yard. and you will need to just wait another day perhaps 2 to drive on yard without tearing things up, when doing anything major that involves more weight. from logging to moving dirt to other.
chains due make a large difference. and so does 4wd. so does an experienced operator more so operator use to the machine. prefer to have differential lock, and left/right rear steering brakes on opposite foot than the gas / go / hst pedal. 4wd is not always what it is cracked up to be.
ply rating. personally prefer a higher ply rating. granted higher ply rating means a much rougher ride. i do not remember the specifics of various ply ratings. and why's and why nots for this or that. but it was worth spending extra cash towards higher ply rating for me. i think a bigger thing for me was dealing with thorns, and higher ply rating meant thicker rubber of the tires. and in that less chance of a leak due to a thorn or nail or something else. and higher ply rating meant more weight capacity for the tires?
i truly hate skidding logs with chains wrapped around the log. i have torn up costly chains, and destroyed my yard, and had to re-attach chains, and re adjust were tractor was multi times to get chains unhooked from around logs. and still waiting to come across. "forgets there name" see attached image skid trees.png just a single chain between 3pt hitch draw bar, and this thing what ever it is called.
old gear manual transmission type might be more beneficial more so if it has a creeper gear for log skidding.
/ Logging with industrials #33
They are skidding tongs, But I also forgot the name, and I just went to Northern's website, and typed in logging, and luckily I found them... I have been thinking about using that exact setup, and I thought of taking an extra draw bar that I have, putting wheels on the two parts that attach to the lift arms, and chaining that under the opposite end of the log that is not attached to the tractor, so I can drag it out of the woods better, without leaving a rut on the way out. This is the link to a basic skidding tong: Northern Industrial Steel Skidding Tongs — 32in. Jaw Width | Log Skidding| Northern Tool + Equipment
i truly hate skidding logs with chains wrapped around the log. i have torn up costly chains, and destroyed my yard, and had to re-attach chains, and re adjust were tractor was multi times to get chains unhooked from around logs. and still waiting to come across. "forgets there name" see attached image View attachment 278935 just a single chain between 3pt hitch draw bar, and this thing what ever it is called.
/ Logging with industrials #34
I would buy it with R1s. Then 5 years from now buy a set of R4s and wheels. You might even be able to make a trade. Find some one that has R4s and wants R1s. Before going this route, I would make sure the swap could be made. That there are no internal gearing differences with the different types of tires.
I need to weigh out the fact that with a deal, the R4's would probably cost over a thousand or more with wheels. If I were trading, it would have to be brand specific as everyone seems to offer a different bolt pattern. I just need the R4's not to be horrendous to skid up stems. If they prove unable to produce the grunt I need, then I'd have to consider chains. Most of the guys having little or no problem with R4's seem to have larger heavier tractors than what the 3016 is. The tractor with loaded ags comes in at 3600# and with loaded 43x1600x20 inds it weighs 4000#. It would be interesting to find out what weight differential is needed to overcome the less traction with R4's over the lighter tractor shod with R1's. That in itself could be a deciding factor.
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
RAINBOW PUMPING UNIT (A63291)
RAINBOW PUMPING...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
Prime 604 Dirt Pan (A64047)
Prime 604 Dirt Pan...
