John Deere 260 skidloader hydraulics
/ John Deere 260 skidloader hydraulics #1
yanmars
I am posting this in several JD sites here for assistance. My brother has a 260 skidloader and was told it has high and low flow hydraulics. He needs high flow, is there a lever to change/adjust the same? Thanks
/ John Deere 260 skidloader hydraulics #2
No lever, if it is truly a high flow machine there will be 5 coupler tips on the unit. Two of them will be std size, two of them will be very large and the last will be a small coupler used as a case drain that many high flow att require. If the machine only has two of the std sized couplers it is not a high flow unit. std flow rate 21 gpm, high flow 33 gpm, the intended att must also have a high flow rated motor to utilize the higher rate.
/ John Deere 260 skidloader hydraulics #3
Oops, also should have stated there is a rocker switch on the console as well for the high flow function if it exists. Would be second switch out to the left of the instrament panel.
Thanks
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
KUBOTA L3940 TRACTOR (A64277)
KUBOTA L3940...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
