Oil & Fuel replacement of fuel pump
/ replacement of fuel pump #1
lowufo
warren maine
JD 300 industrial 1965-73 era
Hello Everyone
just replaced me starter that was toast with an after market unit. Problem is that the fuel pump won't go back into the block all the way ( about 1/4 " ) short of the block before the bottom of the pump hits the starter.Questions: 1. can I build the pump out from the block with gaskets and have the pump still work ? 2. can I grind a little of the bottom of the pump casing off to make it fit ? 3. Can I just replace it with an electric fuel pump ? If so any special pump needed ?
Thanks for all the advice
lowufo
/ replacement of fuel pump #2
If you move pump back away from block you'll also be moving it away from the camshaft lobe that operates the pump. Yes an electric fuel pump can be substituted for the manual pump. IIRC JD offers a plate to cover hole in the block.
what does IIRC JD stand for
Thanks !!!
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
