Oil & Fuel replacement of fuel pump
/ replacement of fuel pump #1
lowufo
warren maine
JD 300 industrial 1965-73 era
Hello Everyone
just replaced me starter that was toast with an after market unit. Problem is that the fuel pump won't go back into the block all the way ( about 1/4 " ) short of the block before the bottom of the pump hits the starter.Questions: 1. can I build the pump out from the block with gaskets and have the pump still work ? 2. can I grind a little of the bottom of the pump casing off to make it fit ? 3. Can I just replace it with an electric fuel pump ? If so any special pump needed ?
Thanks for all the advice
lowufo
/ replacement of fuel pump #2
If you move pump back away from block you'll also be moving it away from the camshaft lobe that operates the pump. Yes an electric fuel pump can be substituted for the manual pump. IIRC JD offers a plate to cover hole in the block.
what does IIRC JD stand for
Thanks !!!
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
FUEL TANK (A63745)
FUEL TANK (A63745)
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59910)
2025 TEXAS PRIDE...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
iDrive TDS-2010H...
2014 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2014 REITNOUER...
