Oil & Fuel replacement of fuel pump
/ replacement of fuel pump #1
lowufo
warren maine
JD 300 industrial 1965-73 era
Hello Everyone
just replaced me starter that was toast with an after market unit. Problem is that the fuel pump won't go back into the block all the way ( about 1/4 " ) short of the block before the bottom of the pump hits the starter.Questions: 1. can I build the pump out from the block with gaskets and have the pump still work ? 2. can I grind a little of the bottom of the pump casing off to make it fit ? 3. Can I just replace it with an electric fuel pump ? If so any special pump needed ?
Thanks for all the advice
lowufo
/ replacement of fuel pump #2
If you move pump back away from block you'll also be moving it away from the camshaft lobe that operates the pump. Yes an electric fuel pump can be substituted for the manual pump. IIRC JD offers a plate to cover hole in the block.
what does IIRC JD stand for
Thanks !!!
L6060 Kubota For Sale
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
