Top link confusion
/ Top link confusion #1
Kit2821
W.KY
Kubota mx5100
I'm slightly confused. The top link on my mx5100 has two different sized tie rod ends. The implement side is cat 2 and I'm guessing the smaller tie rod on the tractor side is cat 1?
Any insight?
When I bought a replacement top link the Kubota service rep said this is what you need., but obviously that isn't the case.
/ Top link confusion #2
Very common for 50-75HP tractors to have a cat 1 end at the tractor and a cat 2 end for the implement. :confused2: Why, that I can't answer. :ashamed:
I hope that you didn't have to pay to much for that replacement top link.
Thanks. Will be replacing the tie rod end.
..,just slightly confused with the service rep wouldn't think of that...oh well.
/ Top link confusion #4
The service rep probably doesn't know that they have different ends. :(
/ Top link confusion #5
Any insight?
Basically, your tractor is cat 1 & 2 compatible.
Use the small end at the tractor side, large end at implement side for cat 2 implements.
Use the large end w/bushing at the tractor side, small end at implement side for cat 1 implements. Of course, you could leave the small end at the tractor side and use the bushing at implement side for cat 1 stuff, but it was easier for me to use the bushing at the tractor side rather than deal with it every time I hooked up an implement.
Edit: Your tractor should have come with bushings for the top link and arms... if not, they are readily available at your dealer or a farm supply store.
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
iDrive TDS-2010H...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
2008 Volkswagen EOS (A61574)
2008 Volkswagen...
