Mig gas Bottle Questions
/ Mig gas Bottle Questions #1
toxicjeeper
N.B Canada
LS 5020c
The time has come where i need to produce cleaner looking welds. I know that my flux core wire welds are soild but they dont look very clean or wet.. The only reason i stuck with the flux core so long was because i received five 25 pounds rolls with my cv 300.
I have the gas hook-up on my LN-7 and just need a bottle. I posted an ad looking for a used bottle. Is there a date or any kind of markings i need to watch out for( like Propane tank. Anything older than 10 years and they wont exchange).. Thanks
Also i was hoping for a big bottle but i have a line on a medium one for 80 bucks.. roughly how much welding can I do on one of this bottles and are they expensive to fill?
/ Mig gas Bottle Questions #2
Hydrostatic test date is what you are looking for! It should be stamped into the bottle similar to a propane tank. Usually 10 yrs. (if steel) good thing is you can have it retested and re-stamped and keep on using unlike a propane tank.
I too have a medium tank and have gone thru a roll of wire plus before refilling
/ Mig gas Bottle Questions #3
I bought a large, and medium sized bottle for each of my welders, at my local welding supply house. I just exchange when they are empty, and no worry of not filling my bottle I take in. They don't fill there anyway, it is just a satellite store. I'm thinking it takes 2 bottles of gas, to use up a 35 lb. roll of wire. But then my old regulator was bad, and had a slight minor leak, so I may have been using more then normal. Still on the first bottle, since the new regulator...
And I'm thinking the last large bottle of 75/25 was close to $75.00, w/tax, and hazmat charge, etc....
/ Mig gas Bottle Questions #4
I am using 12-14 lb roll
See if you can run pure CO2 cheaper, a little more penetration/a little more spatter
/ Mig gas Bottle Questions #5
Works the came way here too. 80 cu ft bottle Argon/co2 was $35 last year.
/ Mig gas Bottle Questions #6
If buying used, you want to make sure that there is no store name on the top collar. If there is, it may be a rented tank. Most places will not exchange or fill tanks that are not theirs.
I bought mine from the LWS. It's a 4' high bottle, 128 cuft IIRC of C25. They said exchanges would be $25.
Ken
/ Mig gas Bottle Questions #7
I purchased a Holox 4' tall bottle years ago, maybe 10 years. I have practically used a small roll of .030 wire from that one bottle. Small is defined as a 10# roll. I exchanged the bottle at Sidney Lee (local supply shop) off the truck into the empties bin, rolled a fresh cyclinder into the truck and paid at the counter. No questions as they rolled the cylinder where it went. I think it was similar in price to Ken's price for a CO2/argon mix. Welder is just for occasional repairs and sometimes new creations which is why the slow rate of consumption.
/ Mig gas Bottle Questions #8
I recommend you go to your local welding supply and buy the biggest bottle they sell. It'll usually be a 160 -175 cf. It might cost a little more than a used bottle but you'll always be able to just exchange it for a full one. Refills on the large bottles cost just slightly more than refills on small bottles.
As for usage, it'll depend on what you're welding as to how much wire you'll burn per bottle. If you set your regulator to 15 cu.ft./hr you'll weld 10.6 hrs from a 160 cf bottle regardless of the wire size, wire speed or material thickness. That's actual arc on time so that's a lot of welding.
Thanks for all the feed back.. Does anybody dual sheild flux core wire using gas? Just wondering if the welds look any better or if there is any real benefit. I have all this flux core wire around and would like to use it up but need good looking welds for some stuff..
/ Mig gas Bottle Questions #10
that flux has to go somewhere. by using shielding gas it won't just disappear - you'll still have some mess to clean off the weld, so i don't think you'll want it for that. take the spool off, seal it up in plastic and shelf it until you have to do a job where you don't need a body shop finish. anytime you have to fix up a piece of machinery outdoors just put that on. i'm not sure with your setup, but on mine i just have to switch two wires under the hood to change polarity for gas/flux.
this has been discussed numerous times, but if you haven't already, make sure you talk to the people where you plan to exchange / refill the cylinder about their policy on customer owned cylinders. some places around here won't touch an owned cylinder unless you have paperwork proving it is not someone's lease tank, whether it has a stamped collar or not. generally the places here won't question a 60cf or smaller tank with a clean collar because many/most of them are customer owned, but when you get into the 120cf/240cf sizes it is generally assumed that they are leased and you may have to do some talking to get them to work with it.
as far as welding time, if you assume 20cf per hour consumption you can figure a ballpark time since you know you have a 60/80/120/240cf tank. i did a one year lease on a 120cf because i didn't know how long it would last, and it goes a long time. since i live a distance from a cylinder depot, i have been thinking about going with two 60cf tanks. it won't be as cost efficient, but that way i can run out of one tank and switch to the other, then exchange the empty at my next convenience, as opposed to having to spend an hour or more to exchange a tank, or worse - running out on a weekend or after hours.
i don't do it for a living, so having the trigger pulled for three straight hours to empty a small cylinder wouldn't be likely to happen in a day for me. i also don't believe in welding everything eight ways to sunday, so i probably deposit less weld than some. i've seen on a daily basis how much the capacity of a weld is, so i tend not to waste.
I borrowed my FIL's tank and tryed running gas with the flux just for my own amusement.. I could not get rid of the porosity in the weld. they did come out shiny after knocking the flux slag off but full of holes..I dont do this for a living either and this is the first time i have welded with gas so maybe i am missing something??:confused: I did like the fact that the welds ran quite a bit cooler compared to flux. I am gonna have to call and get pricing on a spool of soild core, smooth rollers and a tank before i go too much farther. AT least my machine came with a regulator:D But I dont want to spend a fortune..
/ Mig gas Bottle Questions #12
i'm not sure on the specific rollers for yours, but ebay and similar places usually have lots of drive rollers in the $20-$40 range. a 10lb spool of solid wire will be in the $25-$30 range, and around here the cheapest way to get a bottle home is a 1 year lease at $30-$50 for the year, and $30-$50 for the gas in the bottle. a 1 year lease isn't the most economical solution, but it is the cheapest way to get a bottle home, and also a good way to tell how much you will use without making a long term commitment right now.
figure $100-$150 anyways to get you started. no clue if your prices are close or not, but we're only a few hundred miles apart, separated by a border and some guys in funny hats :D
Yup Maine definitely isnt too far away..LOL..150 isnt bad. I guess a one year contract isn't as bad as i thought. Just so many thing i want/need for the shop.. gotta buy a mill soon too..This hobby/part time work is draining me..but would love to get into it full time and work out of my shop for a living..
/ Mig gas Bottle Questions #14
You can only buy the small bottles up here. Size 9 (1.5m3) in Air Liquide language.
Anything bigger is lease. Off the top of my head something like $40 was what i used to pay for a 22, could be wrong that was several years ago.
To buy a bottle new its something like $150 but that includes the first fill (again, its been a while since i bought mine). A fill is around $35. I never really looked.. just pay:laughing:
I have an account at AL so there is never any issues with swapping cylinders. Never get a question. Now if you just walked in off the street, i dont know if you'd have to prove ownership. I have gotten tanks stamped Praxair in exchange. I honestly dont think they consider it a big deal for the small tanks. At least between AL and prax. Who knows what would happen if you tried to introduce a foreign tank.
Also there is no issues with hydrostatic. Its just a straight exchange.
Praxair follows the same rules as far as ownership goes in my experience. Their costs are about the same too. It just comes down to who is closer.
One thing you do have to watch for is Hazmat/MSDS charges. AL works on a flat fee where others charge a percentage. AL has the cheapest MSDS charges in my experience. Not only will the charge apply to gas it applies to filler metal , grinding wheels as well. And its a per visit charge so it makes sense to stock up in one visit over several.
/ Mig gas Bottle Questions #15
What type of flux core / dual shield are you using? Some of them require up to 45 cfh of gas. Can you post some pictures?
Here is a vertical up with ESAB's 710X.
Thanks for the tips scooby. Those would be the two main companys here in Fredericton as well.. I may bite the bullet and buy a small tank and switch to soild core..
dang those look good compared to what i can do..LOL.. I was around 20cfh with my borrowed bottle and the flux core wire is genuie Lincoln brand. I will go grab a few pictures and check..
/ Mig gas Bottle Questions #17
I haven't run much dual shield in years, use to get a pretty steady diet of it at times.
Proper gas flow, and stick out, make all the difference in the world with dual shield. Some wires require 3/4-inch stick out.
dang bottle ran out of gas while i was laying a bead to take a picture..I need quite a bit more practice so i think i will just keep sluggin away with the flux core..The welds arnt the prettiest but they get the job done 90 percent of the time..
/ Mig gas Bottle Questions #20
If your using the same flux core wire for both gas shielded and self shielded, I think thats your problem.
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
