Yanmar tug of war
/ Yanmar tug of war #1
winston1
Super Member
gilmer tx
Bobcat CT235
Looking for opinions. Here is the senerio. If you hooked a ym1500d and a ym2000 back to back with a chain which one would pull the other backwards? Of course both with no extra weight or implements. And yes, 4 wheel drive is engaged on the 1500 and both can or cannot engage the differential lock as long as they both do the same.
I know a gentleman tractor shopping and he is comparing the two. All other comparisons are out the window. Just want to know which one will win the tug of war. :D
/ Yanmar tug of war #2
Assuming that they are either both 2WD or 4WD and the tires are the same type the YM2000 will win because of the weight and a few more HP.
The YM2000 weighs 1664#, 164# more than the YM1500 weighs 1500#.
Now if the YM1500D is 4WD and the YM2000 is 2WD the the YM1500 will likely win because of more pull out of the 4 wheels. At least this is my call and I have never been wrong.........today... yet.:D
/ Yanmar tug of war #3
However, we didn't determine which tractor's path has that leaky garden hose from last season. :cool:
/ Yanmar tug of war #4
I can't say for sure, but I can guess tonight, and tell you some experimental results tomorrow!:D
My YM186D is about the same as the 1500, but with smaller tires. I own a YM2000. My 186 is very heavily ballasted, with wheel weights, water filled tires, and suitcase weights. The YM2000 has filled tires and very heavy cast iron wheel weights (About 180 lbs apiece). On smoother surfaces, the 4 wheel drive means the 186 will pull more. In softer terrain, like disking a field, the taller tires means the YM2000 rolls more easily, and will pull the same plow or disk deeper than the 186D can.
I haven't chained them together, but will now, and see. For your friends' purposes, my money would be on the YM1500D. I think the taller tires compared to mine will give it better traction in soft terrain, and the 4 wheel drive an advantage everywhere.
/ Yanmar tug of war #5
Sounds like a totally inane waste of expensive diesel fuel to me.
Reminds me of the 2 idiots that chained their pickups rear to rear and one guy pulled the body off the other.... How stupid.
Guess thats what seperates humans from animals... the ability to think stupid and act it out....:)
/ Yanmar tug of war #6
YM2000.
Both will raise the front off the ground as soon as the chain is pulled tight so 4x4 is irrelevant.
I don't know where that 1664 lbs for YM2000 came from. Maybe the early YM2000, the green one where the hood hinges at the rear.
My YM240 (YM2000) plus the U-Haul trailer it was on (trailer had a tag that said it was 2000 lbs empty), showed 4,950 lbs on a truck scale. Subtract the loader and oversize tires (not ballasted at the time) and it still has to weigh over 2k.
But ... trying this test in the real world is extremely dangerous. Chaining to an immovable object is one of the most dangerous things you can do with a tractor. Real world example: a friend told me that is exactly how his father became handicapped. As a diesel mechanic he tried to move a big trailer with locked brakes, using a little crawler. A D2 or something. The crawler simply walked around inside its tracks like a carnival ride and over backward on him.
/ Yanmar tug of war #7
Yeah. About 3 lifetimes ago I was a Peace Corps Volunteer. In training they said they learned by watching the first groups sent out that it was a mistake to issue vehicles (Wagoneers back then) to Volunteers no matter how remote their site was. Yep, one idiot destroyed a differential in a Wagoneer tug-of-war like that. Your Tax Dollars At Work. :D After the earliest days and partly based on that, nobody ever got a vehicle assigned to them. Let em ride public transit, and maybe wave as the NGO staffs go by in their white Land Cruisers.
That said, I once pulled a County dump truck out of a rough bouldery ford (stream crossing) with my own Wagoneer. It must have outweighed me 3:1. No problem!
/ Yanmar tug of war #10
on a loose surface i dont think either would go anywhere. if both were set off with a taut chain both i think would only dig holes or pop a wheelie if they gained traction. i think the HP equation is irrelevant.
/ Yanmar tug of war #11
When is this going to happen I would at least like a video of it! :laughing:
Brings back memory's of my youth when we tied 4wd pickups back to back in the parking lot some Friday nites when someone got boastful about his new tires or new truck etc. :D
I remember from that the first guy who looses traction loses the pull simple as that no matter how big he is. fwtw
/ Yanmar tug of war #12
I think the question is which tractor has the most pulling power, 18hp 4wd or 24 hp 2wd. What do you think?
/ Yanmar tug of war #14
Traction is key here my guess the 1500D wins put a fat guy on it and a skinny guy on the 2000 to make it fair. :D
/ Yanmar tug of war
You guys should have been comedians, or maybe you are. :D
At least there are opinions on both sides of this senerio. I didn't state my opinion, but I will go with the 1500d 4 wheel drive. I think the guy comparing the two for pulling ability may have to flip a coin. Of course if 284 chains his together we may know the answer. :licking:
Just another opinion, if tractors were chained together at drawbar height and on dirt I don't think either would rear up. I think they would do a good job of digging the ground up. :)
/ Yanmar tug of war #16
I think a ballasted one will easily win.
If neither are ballasted, they would rotate in circles around the center point like a giant redneck pirouette. .. or they will both wheelie and the two drivers will knock noggins.
/ Yanmar tug of war #18
Comedy aside - I strongly recommend Don't Do This because I once saw a tractor nearly go over backward on the operator. I was a little kid, I thought he was just being dramatic like a rearing horse in the cowboy movies. Then I saw the looks on the faces of the men helping him pull the fence wire. They all looked like they had just seen a man nearly die.
/ Yanmar tug of war #19
I had mine stand up a couple of times. Once pulling on a 6" pine sapling and once pulling a fair sized felled tree-maybe 12". Both of these times I was using the little hitch down low. Even in low 1, it walks up really fast and when the clutch is stomped it slams really hard. The brake should be stomped simultaneously with the clutch and then let down gently. All this happens when you ease into a 'fixed' object. If you run into it, you just break traction. At least with my soil. Ignorance quickly turns into experience.
/ Yanmar tug of war #20
I saw 2 knuckleheads actually try that once with row crop tractors. Both tractors just dug in right where they were when the chain got tight inspite of the fact that one tractor had a 50hp and 4000lb advantage over the other.
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
Ratchet Straps (A61569)
Ratchet Straps...
2009 Ford F-150 Crew Cab Pickup Truck (A61568)
2009 Ford F-150...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
