Willl
Elite Member
I'm still waiting for the 'metric' clock.
How 'bout a metric calendar ?
My experience with Buick, and GM in general, has been the exact opposite. In 1982, when I was in high school, my dad bought my mom a Buick Skylark. To say that this car was an utter complete POS would be an understatement. Every aspect of ownership -- including initial quality, warranty service, total cost of ownership, and finally the end disposition -- was disastrous.So far the three Buicks we ever owned were the most reliable and cheapest cars to maintain.
In the first six months of it's service life, this car spent *at least* 4 weeks total in a bay at the dealer. Most of the problems were clear manufacturing issues; for example, the dash cover came unglued, which left an ugly protrusion extending down into the instrument cluster. The dealer took the dash apart and fixed it. A week later the silicone glue they used failed, and the problem was back. The dealer said that this was because the car had been parked in the sun. (!) This problem was never satisfactorily fixed and the end result -- in addition to everyone getting in the car asking "what's up with that?" -- was that the dash rattled to no end from all the times being taken apart.
Over the very limited life of this vehicle, there was no end to the problems -- cosmetic, electrical, and mechanical. The camshaft sensor failed at around 30K miles, stranding my mom and brother on the side of the highway. The driver's side window leaked water into the passenger compartment; the dealer had at least 5 shots at fixing this but the problem always returned.
The transaxle seal starting leaking around 50K miles, and as you are aware replacing same is a very expensive fix. My dad elected not to fix it and simply add a pint a month of fluid. Then the camshaft BROKE at about 80K miles, which left the vehicle DOA and a lot of metal chips scattered about the engine internals. The local dealer wanted a silly amount of money to fix it, on the order of half the cost of a new car. My dad looked around for an engine for weeks (this was pre-internet, and you had to call junkyards), finally found one, and had a local mechanic swap the engine. He sold the car the next week.
My dad had been a US Steel employee and it killed him but he swore off GM forever based on this.
I graduated engineering school and got a good job; against my dad's advice I purchased a new vehicle (my first, in fact) from a GM offshoot called Saturn. Months later I was back at the dealer asking them where all the engine oil was going. They had me run a "oil consumption test" -- they filled it, i came back in 3K miles, they checked it. It was quart low. "This is normal consumption rate", they said.
I said, "Suppose, just for a moment, that I used synthetic oil -- and used an OCI of 9K miles -- are you saying that I would have to add almost 3 quarts of make-up oil during that interval?"
They said, "Yes, that is the case. For this reason, we recommend that you use less expensive petroleum-based oil."
I said, "Really." :confused2:
The Saturn DOHC engine was of course afflicted with poor valve seat seals and consumed oil faster than a diesel engine. Saturn did not want to fix the problem for two years, and they finally acquiesced after a subsequent "oil consumption test" failed. In the meantime I had been going through a quart of oil every 3K miles on a NEW CAR. Then the dealer changed the valve stem seals and reported in the process that there was tremendous carbon buildup on the valves and in the combustion chamber.
Me <-- not surprised by this.
I had to get the heads and valves reground/reseated, and the piston tops cleaned at my expense, because the dealer would not cover this "extra" costs. I could also mention the engine mount that failed, etc etc etc all before 50K miles. I was not unhappy to see the back of that car being driven away by it's new owner.
GM, it's workers, it's dealers, and the UAW can all go sit on a cactus as far as I am concerned.
Oh, right, and then later as a taxpayer I got to bail them out of a situation they got themselves into. I almost forgot that part...
Wrooster
Oh boy did you step in it now!I do have 2 other buddies who are american mind you, who will only buy toyota trucks. Both had 4-5 year old tacomas and the frame on both trucks looked like swiss cheese. Put them on a lift and wheelbase gets closer if you know what I mean. So yea thats a high quaility product right
Beginning in March 2008, Toyota notified owners of 1995 to 2000 Tacoma's that the rust warranty on the frame would be extended from 3 years, 36,000 miles to 15 years, unlimited mileage.
If the vehicle cannot be repaired, Toyota will repurchase it for 1.5 times the Kelly Blue Book price. The number of vehicles covered by the warranty extension is 813,000 but Toyota alleges:
"The majority of vehicles nationwide will not experience this condition; it should occur only in a limited number of vehicles operated
in areas with significant snow accumulation combined with extensive road salt usage and visiting owner's vehicles from these areas."
NEW YORK, Aug 19 (Reuters) - General Motors Co (GM.N) is seeking to dismiss a lawsuit over a suspension problem on more than 400,000 Chevrolet Impalas from the 2007 and 2008 model years, saying it should not be responsible for repairs because the flaw predated its bankruptcy.
The lawsuit, filed on June 29 by Donna Trusky of Blakely, Pennsylvania, contended that her Impala suffered from faulty rear spindle rods, causing her rear tires to wear out after just 6,000 miles. [ID:nN1E7650CT]
Seeking class-action status and alleging breach of warranty, the lawsuit demands that GM fix the rods, saying that it had done so on Impala police vehicles.
But in a recent filing with the U.S. District Court in Detroit, GM noted that the cars were made by its predecessor General Motors Corp, now called Motors Liquidation Co or "Old GM," before its 2009 bankruptcy and federal bailout.
The current company, called "New GM," said it did not assume responsibility under the reorganization to fix the Impala problem, but only to make repairs "subject to conditions and limitations" in express written warranties. In essence, the automaker said, Trusky sued the wrong entity.
"New GM's warranty obligations for vehicles sold by Old GM are limited to the express terms and conditions in the Old GM written warranties on a going-forward basis," wrote Benjamin Jeffers, a lawyer for GM. "New GM did not assume responsibility for Old GM's design choices, conduct, or alleged breaches of liability under the warranty."
I just read a story about Buick while back. GM wanted to ax the brand but Chinese protested. Buick was the favorite car of the emperor. Buick is quite popular car in China.
And David Hasselhoff is a popular singer in Germany.
Therefore, it must be a good product.
Wrooster
Are you an American? Do you not like your country? Are you not proud of the things we produce? Just wondering!![]()
Sorry to pop everyone's bubble (no pun intended) but it isn't what we will buy but what the rest of the world will buy and from whom. We cannot exist as an economic power by producing stuff for our own self consumption. We need to produce products that the rest of the world wants, just like we do with certain ag food products. The consumers of the world will not be in the US. The rest of the world needs to pay our wages now through purchases of products made in the USA. Too bad, that means that they will also dictate somewhat how much we get paid.
Wrooster
I see a lot of good points being made. Things are a little different now. I grew up on Chevy cars and trucks and Ford trucks. I have a 69 Camaro that needs restored when I get to it. I'm also looking for a good running unmolested 12v Cummins to put in my old 97 Chevy 1 ton dually. I also love and collect old Cub Cadets.
I grew up with GM too; but that S-10 pickup I had cured me of that illness.
I would be silly to see someone restore a honda civic or a tundra or collect mahindra tractors unless you were japanese.
Actually there is a healthy community of Americans buying up old Datsun's (not just 240Z's) and restoring them. Most are from when Datsun/Nissan first entered the USA market, or are unique models peculiar to Japan at the time.
To me a car or truck isn't just transportation. It's a reflection of my personality. It's a silly thing I like to call pride. I have to admit I would look pretty silly wearing my camo gear pulling up in a toyota!
All vehicles reflect an owner's personality; but why would you look silly wearing camo gear in a Toyota? Now if you wore a dress with fishnet stockings and 4" heels in any vehicle, I'd be laughing my butt off. :laughing:
There are a few confusing things I notice from time to time. My buddy is a retired Navy chief. He has never owned or will own a foreign vehicle. I see American veterans who risked their lives for this country and come home to buy a toyota and plaster it with american flag stickers.I also know of a few biker clubs and if you show up on any jap bike it will stripped and left in pieces. I have another buddy who is a farmer who provides food for America but he let his wife buy a honda pilot.
So are you condoning what the biker clubs do? Whether you or any of us like it or not, we live in a global economy. Would you buy a Chrysler product since Fiat (Italian) has a large stake in the company now? What about when Daimler (German) owned them? If GM went belly up as they should have, would you still buy a GM product after the Chinese picked up the pieces as an easy way to enter the USA market?
America builds quality products in my mind. Growing up all of dads cars and trucks and all of mine have been very reliable.
Yes, America has and does build quality products; but it's also turned out some atrocious crap too. Do I like Chinese made stuff? Not in the least, and I avoid it as much as realistically possible.
I do have 2 other buddies who are american mind you, who will only buy toyota trucks. Both had 4-5 year old tacomas and the frame on both trucks looked like swiss cheese. Put them on a lift and wheelbase gets closer if you know what I mean. So yea thats a high quaility product right :confused2:there!
:confused2:
Yep, plenty of American branded vehicles have done that too, along with German, French, British, Italian makes. Ever one makes a dud now and then, some more so than others.
I Getting ready to buy another car for my wife and save the Durango for our daughters and not sure what direction we'll take this time, but I can tell you fuel economy is on the mind. We'll take a look at them all.
Not true at all... I had to learn the metric system in Calfornia back in the 1960's and it is legal to use the metric system in the US and has been for decades.
I work for a company that develops and makes control systems. We have to do a all projects either in SI (official name for metric) or English depending on the customer. It is a mess. Even though there are only two countries that still use English system (USA and Fiji I think) there are a lot of legacy English system installation all over the world. In example if old refinery in a country converted to SI is upgraded it might be done in English system.
There are countries that use both 110V/60 Hz and 220V/50Hz systems and every imaginable type of outlets depending who built the specific equipment or a hotel. Go figure that one.
I like to support the local True Value Hardware around the corner as much as I can. We still buy a lot of stuff at Home Depot and Lowes though because of the extended hours and convenience. What I really wish is that the government didn't have so many restrictions on selling meat and milk that you can't buy steaks, milk, and drumsticks from your local farmer. Our government has put the small farmer out of business unfortunately. Now we buy "fresh" vegetables from South America. I have trouble making sense of some things.pjbci said:Buy American and more importantly buy local. Stay out of walmart, home depot, lowes, and God forgive me for saying but stay outta tractor supply. These corporate giants dont need your help goobling up local owned businesses.
Obed said:Our government has put the small farmer out of business unfortunately. Now we buy "fresh" vegetables from South America. I have trouble making sense of some things.
Obed
