ROPS LED Work Lights
/ ROPS LED Work Lights #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
I was not too happy with the one 55w halogen lamp on the rear of my new tractor, it was mounted on the left rear fender and seem to line up with the one foot diameter discharge chute on my blower. So I ordered five LED 27watt work lamps [ EBAY, $238USD ] and mounted four towards the top of my ROPS. I made and bolted two aluminum bars to the ROPS using 1/4-20 SS bolts, and wired the lamps to the existing work light circuit of the 5035. The circuit only has a 10 amp fuse, and the lights draw about 9 amps. The wiring is plenty big enough, so I will probably pop in a 15 amp fuse. The LED lamps are the 'flood' type, and each is about as bright as a car headlight.
/ ROPS LED Work Lights #2
For folks thinking about doing the same lighting ...
I would not put any lights on the ROPS of an open station tractor. When working at night the lights draw all the bugs to around your head.
/ ROPS LED Work Lights #3
I agree , except in my case , the only time I'll be on mine after dark will be clearing snow ( hope those bugs are all dead ) :thumbsup: These little tractors have limited places to put lights .
About the only time I would use them is in the winter.... I live a little above the 45th parallel...and it gets dark early up here. Plus, when you blow snow... you can never have enough flashing lights or other illumination to help the general public know that...some where in the big white cloud... you are in there... When the lake effect is blowing in... you can't hardly see to drive before you even turn the blower on ..... :)
/ ROPS LED Work Lights #5
Any chance you have a picture of the brackets you made?
I did not use a bracket.. I used two 3/8" by 1 1/4" aluminum bars. The bars are secured to the inside corner of the ROPS by drilling and tapping two 1/4-20 holes in the ROPS. My ROPS is 4" wide, and I drilled two holes in each bar so the 3/8" lamp mounting holes would be about 1" outside the edge of the ROPS. The first picture shows the mounting bars bolted to the ROPS. Inboard of the bars I bored 3/4" holes into the ROPS for the wire..which is enclosed in black split loom for protection. If you are squirmish about drilling into your ROPS, this is not for you. But me, I have never owned a tractor with a ROPS before...so to me...it is just a mounting and wiring attachment to the tractor.. Few holes are not going to weaken it that much anyway... and besides.. my better half would like to get her hands on all the life insurance...
Another thing... if you do this. Put a box [ LCD TV box is what I used under the collapsed down upper half of the ROPS ] under it to collect the chips. When you are done drilling, and before painting, stick your shop vacume hose [ I took the end connector off the corregated hose ] into one end of the ROPS... and blow the chips towards it with compressed air from the other end. That way you do not get all the chips down under your rear tires... [ my floor is wet too from snow blowing ]
/ ROPS LED Work Lights #7
I installed LED lights on my little skidsteer. They worked fine for about 10 hours of use, then they burned out. I can see blackened LEDs, so I know that at least the LEDs are burned, and likely the circuit board itself. The skidsteer has a magneto which is used to power an electric fuel pump and recharge the battery. The fuel pump has worked for years, so I doubt that the voltage greatly exceeds 12v. I'm trying to figure out why.
Most of these LED units are good up to 30 volts. I know that a normal incandesant bulb will not take an intermittent ground and will burn out quickly if you have one. But I have not heard that about LED units. Good luck.... Jerry
/ ROPS LED Work Lights #9
Something on the Skid Steer emitted a pulse probably that popped the PN junction in the LED (which is still a diode, it just emits light too) and then the 12 volts DC burned up the board and LED housing after the diodes went bad. Now this is just a guess but my best guess. Especially if you measured the charging voltage and it was not significantly over 14 volts. But a reverse pulse from a relay coil or solenoid on the line could have exceeded the Reverse Peak Inverse Voltage rating of the LED.
James K0UA
/ ROPS LED Work Lights #10
Dang I didn't even consider the Bug factor!
We don't get much real winter down here, We even get them pterodactyl skeeters that escape from LA swamps from time to time.
DS
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
BOBCAT T190 (A60736)
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
