Metal building condensation (help please)!
   / Metal building condensation (help please)! #41
I have built three steel sided buildings with and without insulation. My friend built two. FWIW the first year there seemed to be moisture inside then after that no problem. Not sure we had anything of the scale you are describing. Anyhow maybe it will lighten up.
moisture will work its way out of concrete for a year or two, but the first 3-6 months is the worst
How long has the building been up?
   / Metal building condensation (help please)! #42
Some bad advice in the thread. Venting completely defeats the purpose of insulation and will not solve condensation on things like the slab and large metal objects like table saws or milling machines, tractors etc, and it can make it worse. Venting only helps when you have source of moisture inside the building (most shops don't have significant sources inside)
You need to heat it without introducing more moisture, just above the dew point (doesn't take much, 5 f above the outside air temp will work), or you need to dehumidify it to below the dew point. Fans, not outside venting, will help objects in the building stay closer to the air temperature so you don't need to heat or dehumidify as much.
My shop is fully insulated, it is up against the metal, between the purlins and sheet metal. It is the foil faced, bout an 1" of some fill, then the thick white vapor barrier.
Rain is not the problem. No leaks in the rain.
The barn has been done 2 months, so alot could be coming out of the slab.
I got the building from Alabama Steel in Montgomery, they were very good to work with. My father in law, here in Elba (hays concrete) did the slab.
No heaters in there of any sort, except what heat the 12 8ft flouros and two 400w low bays put off. Which isn't much.
So, do you think a couple large fans circulating air inside would help?
   / Metal building condensation (help please)! #44
I don't understand anything that you just said.
Are you saying that air flow on the underside of the metal roof will not stop the condensation?
What does a table saw have to do with condensation?
What does the concrete slab have to do with how much moisture the air can hold?
Eddie
   / Metal building condensation (help please)! #45
Agreed. Good intentions but still bad advise.
The concrete will dry eventually. I don't know where you live but you need to insulate(R10 isn't much around here), create a vapour barrier. The spray foam works well for this but not cheap. You get what you pay for. Most of your moisture is likely coming from the outside, so don't bring in more air. It is counter productive.
Heating even only a few degrees will help. You could use an HRV but you'll need to add additional heat on the intake. I don't like this approach as I don't think you get enough of a return on the install(Not very efficient).
Once your properly insulated and sealed, then you can buy a good pump out dehumidifier. It will save your tools, cars and building.
Good dehumidifiers aren't cheap but they work very well and they last.
- LGR 3500i
   / Metal building condensation (help please)! #46
-His roof is insulated, and yes, airflow from providing vents won't stop condensation.
-Table saw is representative of metal object in shop, could be wrenches, etc, the larger the mass the better "dehumidifer" it becomes when you let wet air into the shop.
-The concrete slab is mentioned because it is one of the huge things that get soaking wet when you start pumping outside wet air into a cold shop. Today after a cold spell it warmed up and rained today, the undercut below by shop door has standing water from the wet air blowing over the cold slab. It forms a condensing surface.
If I opened my shop doors up the entire shop would be soaked. Running a fan helps heat the slab up faster, but it can't change in temp fast enough to prevent condensation from forming on it.
Eddie, what is the climate like where you're at? Humid, dry, warm, cold? I'm talking about a wet climate with heating, not air conditioning.
Eddie
   / Metal building condensation (help please)! #47
Ventilation? I have two 3 sided (3 closed sides) machinery sheds, one is 70'x24' deep, and another one that is a "lean to" shed attached to the side of a bigger bldg., it is also 3 sided, 64'x22 deep. They both will drip from the roof metal when conditions are right. I would cut in some gable end vents (each end) and call it done. This is an easy and cheap DIY job. After that you may need to look into the closed cell spray foam directly on the under side of the metal.
As I was writing this I thought about this, there might be another solution, heavy on the labor side but light on the material expense.... pull off the metal roof, add 1/2" osb and tar paper it. Add new roof purlins and put the steel back on. This is called a "cold roof" and should deffinetly fix it. A synthetic "shark bite" type felt substitute would be prefered. Hows that for a crazy answer!
   / Metal building condensation (help please)! #48
Your thick whit vapor barrier is not a good seal. Think reverse Tyvek on outside house for drafts. Eliminate air to metal with vapor barrier may save a lot of bucks. Wood firring runners to tyvek to so no metal contact on other side of barrier (transmition of cold).
Think of cold bathroom window and cheap but well sealed plastic over it. Tools will still get damp on humid warm day and inside is cold but it will stop rainning on you.
Gary
   / Metal building condensation (help please)! #49
Awful lot of work to revapour barrier a building when it won't solve the problem of the wheelers and tools getting wet.
   / Metal building condensation (help please)! #50
We had a pole barn built last year with 2" of insulation and a concrete floor. At first there was alot of condensation but after we sealed the concrete most of it went away. We put a piece of piece of plastic on the floor and the next day removed it and it was dry underneath. Before the sealer was put on it would be sopping wet. We also installed an agricultural fan and insulated the doors. Now the only thing we get is dust because the tractor brings in mud, the mud dries and we're left with dust.
Our place is in Westen Washington on a river and gets losts of drizzle and stays damp(outside) all the time except of the 10 days of summer we get.
If nothing else I think you will see a hugh difference after you seal the concrete. We sure did.
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51244)
UNUSED FUTURE 20'...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
