B7100 Restore Project Has Begun
/ B7100 Restore Project Has Begun
WOW! that is a gorgeous engine. There is no greater satisfaction than rebuilding an engine and having it fire right up and "purr like a kitten". Not everybody can do that and you've got to give yourself a lot of credit. I like the pictures. I can almost smell the oil and feel the plastigauge! I hope I am as lucky as you are skilled when I get to heating up the glow plugs for the 1st time!
Ugh. Sorry about the gear noise. The rear is a little more daunting for me because I know its all about replacing not rebuilding. A full line of bearing separators and a little hydraulic press can be worth their weight. Hopefully you can find a simple "junkyard problem" = "one bad dog with a broken tooth".
HTML:
Did you have any metal on the sump screens?
- saw your note on the pipe thread - glad you have good resources.
Good luck. I will be watching with interest.
I Haven"t pulled the filter out yet. Spent Monday taking off all of the sheet metal and dash along with the dash components. Should be able to break it in two one night this week and start checking gears and bearings.
/ B7100 Restore Project Has Begun #42
I've been following this thread also. The engine looks awesome. Can't wait to see/hear the rest of it. At some point we'll want some sound to hear that "purr" :).
I have two videos, one while the last of the air was bleeding from the injection system and another after it smoothed out but I am having trouble getting the audio to transfer from my HTC phone to the computer. Will continue to work on getting audio. The tractor is stripped bare now and the gear boxes are open so it will be a while before it will be running again. Found four worn gears in the trans. last night. Lots of thin metal shavings in the sump screen. Will be breaking it in half and doing a trans rebuild now. Haven't priced any parts yet or checked availability. Kinda dreading to find out the prices after the shock of engine parts buying. Looking for the best quality and lowest priced rear axle hubs too if anyone has any suggestions.
Got the videos posted on YouTube under Kubota B7100 Rebuilt.
/ B7100 Restore Project Has Begun #46
Looks awesome, sounds awesome. I'm subscribed to this thread. Can't wait to see the rest. I wish I had this much talent. Thanks for sharing!
/ B7100 Restore Project Has Begun #47
You might want to take a close look at the front frame extension before things go back together. I found mine was cracked in half, the front axle was wobbling around. Cleaned and up welded all better now. Check the front axle tube assembly as the crack progressed the axle tube bushing showed extensive wear.
Enjoy your little tractor
I checked mine very close as I was cleaning and painting it. No sign of stress or cracks. The center pin has some front to back play but no side to side so I elected to wait and work on that later after the major repairs are finished. I had read a thread on TBN about a broken front B7100 frame a while back and that gave me insite to check mine real close while it was down. That may have been your thread that I checked out. Thanks for the information.
/ B7100 Restore Project Has Begun #49
Good to hear, that's one issue you do not need to worry about
Yes that earlier post must have been one of mine
I am enjoying your engine rebuild updates
My 7100 engine has 1,500hrs still running strong right now
How is your locking rear differential doing?
My locking lever stopped functioning a few years back - to date have not taken the thing apart, however it's on the list of to do items for this winter.
I did see several possible causes and ordered / received a box load of possible parts.
I see other posts regarding different engines. Did you consider putting in a different engine? My ZD326 has a 26Hp engine that I believe would drop right in. That beast is wonderful enough power for any job I ask of it.
Kubota's sure are nice machines
Keep posting the updates for us
Ken
Ken
My diff lock worked great during the engine break-in run. I ran the tractor for about 3 hrs and checked everything for operation before tearing the rest of it apart for restoring. I thought about using a D950 engine if I could not rebuild my D750 but fortunately it was rebuildable. I tend to lean toward original when rebuilding anything but still like to watch PIMP MY RIDE.
Well, got it broke down and a list of trans. parts together. Just as I expected the gear box parts are just as pricey as engine parts. I located a salvage trans for 850.00 with a 200.00 core plus shipping. The parts to renew mine will run about 600.00 so I am going to build it and hope for the best. I can't find any reason for the gear failure as of now. The oil was slightly tainted with typical tractor gear box condensation and all bearings feel good. The only thing that I can figure is that the machine was used a LOT with the FEL. The gears appear to have failed under extreme pressure. The shifter fork guide for the High Low was worn almost completely out which then wore the guide channel on the gear out. Began cleaning, sanding, and painting parts from the engine back. Will have to locate a hood due to damage on the front of mine around the head lights that can't be repaired. This is from many years of being banged on the FEL while opening and lack of a front grill guard.
/ B7100 Restore Project Has Begun #52
Great pictures once again.
Interesting are the differences between the HST and the Gear drive.
Both my 4x4 u-joints were bad and I had to rebuild both.
Keep up the good work.
My joints are good but the rear yoke at the transmission has some wear to the splines. The shaft splines are good.
/ B7100 Restore Project Has Begun #57
sent PM about B7100 being parted out.
look at that website under:
KUBOTA B7100 Dismantled Machines
Number of Matches: 9
This Page: 1 of 1
Well, the project is in limp mode right now due to limited funds this time of year after paying property taxes, home insurance, auto insurance, and $600.00 a month health insurance. Been sanding and painting a few parts between re plumbing the entire house to get rid of all type L copper pipe which develops at least one pin hole per year. Just got home from a road trip to Nesquehoning Pa. to do a final inspection on a 3000 gal tanker at the KME factory for my fire dept. Didn't see a single Kubota tractor during the entire trip.
/ B7100 Restore Project Has Begun #59
One sweet International!!:thumbsup:
Yea, I wanted to drive it the 550 miles back home but the dealer has to deliver it. Oh well, I'll get plenty of short trips in it when it gets put into service.
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C06M033754 (A65563)
2006 Mack CV713...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
3-Pt Disk (A66285)
3-Pt Disk (A66285)
