Trailer Light Grounding
/ Trailer Light Grounding #1
MinnnesotaGuy84
Trailer light grounding seems like it ought to be straight forward but I'm stumped.
Here's what I know:
I had a guy at the shop test the cord coming off my truck and it it lit up his tester. I have new wiring throughout the trailer that worked when I wired it up, turn signals, brakes and running lights:everything working. Suddenly they stopped working, so after shineying up the tongue, I reattached the groundwire to ensure a good connection. Now I get dull brake lights but no turn signals.
I purchased a multi-meter and I have limited understanding of its use. I set it to ohms and touched both leads to the light sockets and got readings. Also I touched it to the connection of the ground on the tongue and got a reading. My readings have consistently been 0.9 to 1.1 when set on the lowest ohms setting on the multi meter.
Any ideas on where my problem is or other troubleshooting tips.l
/ Trailer Light Grounding #2
I think you are going to get continuity through the light because that is how the circuit works. Power through the light to ground. Your problem may be in the plug on the trailer. I had a similar problem with trailer lights and the pins were either bent or corroded in the plug. I changed it out and problem went away. Good luck, trailer wiring can be agrivating at times.
/ Trailer Light Grounding #3
I acts like a bad ground. Try voltage test as follows. Turn on the light. They are dim, right. This means that not all of the voltage is getting to the lights. Leave the lights on. Set your meter to Dc volts. Measure the voltage from the ground of the towing vehicle to the ground on the trailer. This should be very low, less than one volt. Check other parts of the circuit such as between the towng vehicle 12 volt line and the positive at the bulb. All light do not have to be on. Pull one bulb and check the Voltage between the center terminal and the towing vehicle 12 volts. I hope this helps.
/ Trailer Light Grounding #4
Am I the only one that wires a trailer by grounding back to the plug, and not using the frame as a ground? Yes the frame is attached to ground for the "return path of last resort" but the primary ground circuit is all wired, not counting on the frame.
/ Trailer Light Grounding #5
Had a bad ground on my 12 ft landscape trailer a few years back. the poor ground backfed the lighting circuit and fried the radio, antilock brake module, and blew the backup light fuse. (backup light circuit terminated at truck and doesn't even go to the trailer). I rewired the trailer and ran a ground wire from all the lights back to the plug.
/ Trailer Light Grounding #6
I agree that it will be the plug, could be damp that causes the problem, put a new one on:)
/ Trailer Light Grounding #7
I had a snowmobile/dump type trailer once that I had a real crazy light problem with. Even though I had a good strong 13 volts (Hummmm no load....) at all of the sockets ..... the bulbs would not light. After some serious head scratching I figured out that where the frame hinges for the dump was not carrying any CURRENT to fire the bulbs. I put a jumper from the tongue to the rest of the frame around the hinge and I had lights.
Lesson: Run a seperate ground. Also, get LED lights and never worry about corroded sockets again.
/ Trailer Light Grounding #8
Separate ground right back to the plug.
Solder and dielectric grease on all joints before heat shrinking them.
Never hurts to run a separate ground wire for the trailer brakes if it has them. Join it to the main ground at the front of trailer somewhere.
Fasten all wiring up out of harm's way when finished.....
There comes a time when it can be easier to re-wire than find the problem, especially if someone else did the original wiring job...
/ Trailer Light Grounding #9
most testers do not provide a realistic load.
I like lamps with at least 2 ground paths. frame and copper wire.
with frame and wire grounds tied at the coupler.
I like a good ground for the socket ont he truck, plus I add an aux ground wire with a QD plug at my bumper or GN/5th wheel hookup, that attaches to that common tied ground I have at the trailer. IE.. quite a bit of redundancy.. however.. turn signals don't make the brakes bump on and off.. :)
can't have too much ground where needed.. :)
soundguy
Here's what I know:
/ Trailer Light Grounding #11
I'm thinking it should of been set for voltage, the readings you got where most likely erroneous.
Easy mistake for first users.
Yep, and make sure it's set for 12 dc current
/ Trailer Light Grounding #12
Agree - I have boat, PWC, Car-Hauler, RV, and utility trailers and came to the same conclusion. If you want bright, reliable lights they need a direct copper connection back to the towing vehicle.
We all feel your pain as this is a common and frustrating problem. When your trailer lights are using the trailer chassis as a common ground corrosion between the light ground wire and frame is often the cause of these issues. If you don't want to run new wiring you will need to check and clean all of these connections. Hooking a spare battery directly to your trailer plug is also helpful in isolating the issue. Good Luck and Welcome to the forum MinnnesotaGuy84.
/ Trailer Light Grounding #15
i like both.. copper and clean frame connections. good redundancy..
/ Trailer Light Grounding #17
I often use a spare battery and hook my meter up to read DC current. Fast way to tell how many filaments, brake coils, etc are carrying current.
Amp draw????
/ Trailer Light Grounding #18
I've been wondering about the grounding thing since one of the lights on my trailer has been acting up too. One time it works great, the next time it doesn't work at all. Then, the time after that, it starts out dim and a little while down the road, it's fine. I made a frame and a wire connection in order to make as good a connection as I could but it's still screwing up. I'd been wondering if making double ground connections was good practice or not. I'll continue checking.
/ Trailer Light Grounding #19
Amp draw????
Sometimes using an ammeter is the best, most reliable way to shoot DC trouble.
I always use an analog ammeter to check AA AAA C D and 9 volt batteries. Just a careful quick tap and it leaves little doubt of the true capacity of a battery. Using the voltage scale can be misleading.
/ Trailer Light Grounding #20
When I used to do circuit prototyping I always monitored supply current. If it jumped up I shutdown immediately. Saved many a circuit that way.
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
KOMATSU FG25T-12 WAREHOUSE FORKLIFT (A64276)
KOMATSU FG25T-12...
1989 Corvette Convertible (A61574)
1989 Corvette...
