Gas type m2
/ Gas type m2 #1
EMB5530
Gold Member
Kansas
5530 Mahindra 4x4
I did little searching on TBN, but did not see much about welding gasses for MIG.
I have done a little amount of wire welding(enough to be considered dangerous):) but I am used to stick welding. I have just purchased a wire welder.(after years of wanting to get one, or a TIG:D) I was wondering if there are many negatives to using m2 gas for my steel welding(and also stainless). The main reason is: the company I work for keeps this around(and also a buddie who lives very close) so if I need an exchange even on Sundays I can just go get one of theirs and pay to have them refill mine during the week while I am working wherever I am during that week(construction life:mad:). I have also noticed it lays a much cleaner bead(but it sounds a lot different than I am used to. How is the penetration diff is the weld any stronger/weaker? So what are the negatives? If any. And so on...
Thanks to all for any info
Eric
/ Gas type m2
Have any of yall used m2 before to know what I mean by sounds different:confused:
It dont sound like the bacon cooking like im used to.
More like a hiss instead
/ Gas type m2 #3
OK, I'll bite what is m2 gas? I Googled it, and nothing came up. So enlighten me please.
/ Gas type m2 #4
I have never even heard of m2. What company sells it? It might just be a stores name for something like 75-25.
/ Gas type m2
90% argon 10% c02
linweld is the main supplier
/ Gas type m2 #9
/ Gas type m2 #10
90/10:laughing:
/ Gas type m2 #12
She's fast, and deposits lots of iron. That picture was .045 wire on 1/4 inch flatbar. With .035 wire no problem making a honest 3/8 inch fillet weld traveling very fast.
Here is an .035 Lincoln L-56 wire.
/ Gas type m2 #13
Also probably called C10 (for 10% CO2). M2 must be a particular brand name
/ Gas type m2 #14
90/10 is the minumum mix to effectively do Spray Transfer on mig. ( Unless you want to mess with Praxair Stargon 77/20/3 which is 3% 02 it Gets you close to Spray but is a dated mix) 90/10 costs a little more than 75/25 but worth it in Spatter Reduction and you don't have to deal with the Oxidizers that Stargon has in it. You don't have to Spray with it you can run it short arc too. The big deal with high argon mixes up to 98/2 is that they are Pulse Friendly. If you have a pulse power supply, You would be doing it an injustice by running less than 90% Argon. When you get into Stainless, You will enjoy 98/2 or a mix with a little helium. For the most part, 90/10 trumps 75/25 for a little more $ and much less spatter. Bad news is it's not available in small cyllinders. Oh well.
/ Gas type m2
Thankyou for the info:thumbsup:
/ Gas type m2 #17
Can you run it out of position also?
Yeah, It's the machine and wire more so than the gas for out of possition welding. ( i don't like out of possition welding. :) ) unless it's Aluminum on twin pulse. All you stick guys are the out of possition kings.
/ Gas type m2 #19
Havent you guys seen the razor commercial. Just use the right blade when you shave and it will turn your world upside down. I suppose you have to weld the top first before you shave.:laughing:
2014 FREIGHTLINER CORONADO 122 SD (A67714)
2014 FREIGHTLINER...
2011 DRAGON  4 AXLE CRUDE TRAILER (A67714)
2011 DRAGON 4...
84" Smooth Shell Kit (A68134)
84" Smooth Shell...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65057)
(INOP) 2013 MACK...
2025 32in Tilt Bucket Mini Excavator Attachment (A66734)
2025 32in Tilt...
