Need welder advice...
/ Need welder advice... #1
dntfxr
north Louisiana
Ford, LS
I'm looking to pick up another welder for the shop. All I have right now is a little Lincoln 110v mig which is fine for lighter stuff but I would like to get another machine for heavier fabrication and repair, up to 1/2" but mostly 1/4" -3/8" materials. I found an older Miller dialarc250 whiteface machine in very good shape with 50' leads for 500$. Or for a little more money I can buy a brand new Thunderbolt or similar machine. I've never used either but I think I'd prefer the dialarc, I hear they're pretty bulletproof.
I also like the idea of playing around with Tig. Is it very expensive to set these up for Tig, or would o do better to look into another machine for that? I did find a Lincoln Squarewave175 for 800$ a few hrs from here. Reality is Stick welding will do 90% of what I need but I do like the
versatility of Tig.
Anyone have experience with these machines or have any suggestions?
Thanks
/ Need welder advice... #2
versatility of Tig.
Thanks
Depends on wether you want new/used/plug-in/engine drive/duty cycle. 1/2 inch material; if you are like me you want to use 5/32 rod at up to 180/200A. Shop only or some field work? Duty cycle; most engine drives are 100%, low cost plug-ins are 20%. That has to do with how long you maintain the arc and duration of steady work. If plug in do you have capability to provide 60-100A single phase power. Incidential work you can probably get by with the 20% and 60 Amp power supply. Some of my projects are extensive enough that 20%is a pain to wait for it cool down and come back on. I have a AC/DC 225A 20% and find I need a higher duty cycle. Now we are talking a lot more money, even for a used one. The 20s are a dime a dozen on the used market. I only paid $50 for mine . I can burn up a bunch of them for the price of a 100%.
Tig; way to go if you do a lot of work on thin material, stainless, aliminum, or other exotic alloys even copper and bronze. The shielding gases are very expensive, even more so for the small cylinders. You have to have a lot of work to use the lower cost big cylinders. Even a small cylinder cost $200+filling. 20CF of argon/co2 mix is around $70. Each material requires a different gas blend. Using tig for thick material takes many passes and is slower than Oxy-Acet welding, which I am equipted to do also and good at. 1/4" material I do in one pass.
Most arc welders of all types you can get a mig set up. Costs as much as the welder on the lower end. Keep the mig you have for light work
Need all these parameters answered before I could start to recommend.
Ron
Thanks for the response. As I stated, the welder is for the shop so I don't need a engine drive. 20% duty cycle would get old, and I think the thunderbolt is around that. I don't mind used if it's built to last and like I said the ac/dc stick would probably do 90% of what I need. The 175 squarewave can weld stick too so it's not like I would have to run shielding gas all the time. But the tig option would be nice for some projects. Does anyone have any opinions of those particular machines and if the price seems good? Also does anyone know how much it would cost to set up the regular non-HF Dialarc for tig?
Thanks
/ Need welder advice... #4
Thanks
Shop around the welding suppliers and the net. Try Northern Steel's on line catalog. They have a wide range of stuff to compare. Used depends on condition and what you know about the seller and/or his machine. Auctions are bad as a lot of junk gets unloaded there and you cannot try it out. Remember the austioneer works for the seller. The welding supply outfits taht rent equipment and turn it over every 5 years or so at about 1/2 price or less and thwey maintain stuff well. UI agree stay with the 75-100% stuff for your use. You will find the TIG set up is pretty spendy for casual use. Depends on your finances.
Ron
/ Need welder advice... #5
I took a quick look on ebay, this was the first torch I came across, there might be better deals on there. The cost of renting / buying a bottle of argon will very depending on your LWS. I just had my 250 cf bottle of Argon filled for $55.00. But you should be able to get into Tig for around $200.00 less the bottle.
You'll need a flow meter, air cooled Tig torch, power lug, (torch in ebay add has one) and some tungsten, and filler rod. I've Tig welded off CC stick machines since Christ was a corporal. Of course you won't have the luxury of a foot pedal, but xray quality Tig welds are made everyday with scratch start Tig torches.;)
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
WP17FV-25R TIG Torch Complete Welding Outfit Air Cooled | eBay
/ Need welder advice... #6
versatility of Tig.
Thanks
Is the Dial Arc 250 the HF modle or just the Dial Arc. If it's the HF modle you an add a foot control to it. I see them used a lot for a couple hundred. Tig Torch will be a hundred too. Check with Welding Supply Distributors. They always have used stuff around.
Thanks for the links and suggestions guys. This particular Dial arc I found isn't the HF version unfortunately. I wish it were because it looks to be in excellent shape in a non- industrial shop. HF would also allow for lift start tig also right? Would I do better to hold out for HF? I'll check with the local Airgas and the other big welding supply here to see what is available in used machines also.
/ Need welder advice... #8
HF is very nice for helping to get started with DC Tig, but not really needed. HF is a must for AC Tig!
Thanks Sheild Arc, AC Tig is required for aluminum right? I may just keep looking and research some more.
/ Need welder advice... #10
Well it's not necessarily required, you can weld aluminum with DCEN and helium, now that's old school at it's best!:laughing:
Here's a picture of a weld I did on DCEN with 100% helium.
That's a good looking weld to my eye. Does helium with DCEN use the same basic equipment as regular argon tig? I guess for the limited times I'd need to weld aluminum I could always just use stick instead...
/ Need welder advice... #12
Same basic equipment. Just with helium generally you crank up the cfh. The plus side with DCEN w/ helium you can do the same thing as AC w/ argon with about half the amps. But you don't get the cleaning action with DCEN w/ helium as you do with AC w/ argon. Another down side to DCEN w/ helium is there is a very, very small zone that the arc will start!
/ Need welder advice... #13
The HF modle has high frequency start for tig. Step down on the foot pedal and the arc jumps to the base metal establishing the arc. The bad thing about the Old technology Aluminum tig units is that they had to use pure tungsten that you would create a Ball on the end. This causes a large heat effected zone and erratic arc. The new units use 2% tungsten ground to a point. That makes a small heat effected zone and enables you to weld thicker material with less amps. There is more to it but that is a fair explaination. The Dial Arc will last for ever due to it's heavy transformer make up. If you want to do Aluminum tig and stick on a budget, Look at one of the Everlast units on here. That may be better than a 30 year old Dial Arc.
Thanks for the info guys. I'm going to hold off on the old Dialarc for now. I'm sure I can locate a HF one if I decide to go that route. I'm not in any hurry to buy so in the meantime I'll research the everlast units. It looks like they have several that would meet my wants, a couple including plasma cutters which would be nice too. I also may run across a deal on another old transformer that is too good to pass up.
I guess I'm biased toward the big old transformers, I just remember them being so much easier to weld with vs a regular crackerbox. For those with experience with both, how does the arc compare between a good old transformer and a say a new everlast inverter unit, using stick? Using tig?
Thanks so much for the help, I really value the experience and suggestions you guys offer.
/ Need welder advice... #15
I guess I'm biased toward the big old inverters, i just remember them being so much easier to weld with vs a regular crackerbox. For those with experience with both, how does the arc compare between a good old transformer and a say a new everlast inverter unit, using stick? Using tig? Thanks so much for the help, I really value the experience and suggestions you guys offer.
I'm old school, didn't believe in inverters. Few years ago one of the members here arranged for some of us to go to Miller's testing facility. We were allowed to play with everything Miller had on the market, even engine drives! I got my hands on a Dynasty 300 and fell in love, if I could have got it on the plane with me I would have brought it home right then. Soon as I got home I ordered one. Last year after reading Mark's, (Everlast) comments he convinced me he is a very knowledgeable weldor, I called him and had a long conversation with him. I took a chance and bought a PowerArc 200 from him, yep another inverter! I'm very impressed with that little machine!
So right about now you're thinking so who are you to judge. Welp I think I have some of the best welders ever built, I have 5 SA-200s, (Shorthoods, Red Faces). A Miller 330A/BP. A Linde VI-206. A Lincoln Invertec v350-Pro with another one on the way, hopefully be here today. And of course the Dynasty 300. Been welding for over 40-years, but mostly with engine drives. I've been around the block enough times to know what I like in a welding machine, and these inverters are very impressive! It's amazing the control they have over the puddle. In my opinion very little welding skill is needed now a days with these inverters, they do it all for you!
/ Need welder advice... #16
I saw one guy on welding web wanting to weld aluminum with a tig rig on an ac tombstone, is there anyway this would work? or is he clueless?
Thanks again sheild arc, I can tell you have good experience in the field and I appreciate the help.
I need to go back and edit that last post, I meant to say "old transformers" not "old inverters" in that first sentence of the second paragraph. That's what I get for posting before I've had my coffee lol! I think you knew what o meant though.
I guess I could just give up on AC and tig for now and go with the PA200, seems like a good little unit. I wonder how the bigger Everlast tig and multi units are too...
/ Need welder advice... #18
I'm not familiar with the Tombstone at all, I know them by sight, but honestly can't say I've ever run one. My gut says if you ever got it to work, you wouldn't have anything! First thing you need is a high frequency box. Last I heard they were over $700.00 to start with. You have to have high freq to maintain the arc while changing cycles. And a foot pedal is almost a must, aluminum changes so much while making a weld you need some way to control the amps.
I knew what you meant:laughing:. I know Mark is a salesman, but I believe he is truly an honest man, and will be straight up with you. But hey, take Mark out of it, join this forum and ask people who own Everlast Tig machines.;)
Everlast Power Equipment Forum
/ Need welder advice... #19
You forgot one little detail for the hobbyist looking to DCEN TIG Alum with He...
"Add a crapload of amps. More than your house probably has." :)
/ Need welder advice... #20
All my welders and plasma are on 65-amp breakers, haven't thrown a breaker yet. Now the Miller 330A/BP was on a 95-amp breaker, but it was capable of 460-amps output:cool:. It has been retired, and setting way in the back of the barn. The Miller Dynasty 300 did that machine in.:D
2013 PROFAB 200BBL CRUDE TANKER (A67714)
2013 PROFAB 200BBL...
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A68183)
Pemberton Inc...
Bush Hog BH16-2 (A64911)
Bush Hog BH16-2...
Ez-Go Electric Golf Cart (A64912)
Ez-Go Electric...
