new trailer
/ new trailer #1
donn12
Great Falls Virginia
B2920 TLB turfs and loaded ags
18ft Holmes 7k trailer, brakes on one axle
lift assist rear gates
frame mounted tie downs
the truck got Tembrens SES rear supports (big heavy duty bump stops that eliminate most rear sag) and a prodigy 2 controller. I bought a maxbrake controller but i did not receive the right master cylinder adapter.
I know I'll get a lecture because I didn't get an equipment trailer but this is what I wanted. The tractor will go to the mother in laws (2 miles down the road) once in a while and not much else other than going to pick up new toys etc. I bought the straps from Amazon and they work very well with the tie downs I had built in.
/ new trailer
the lift gate springs are great. Very easy to close and to open I can just let it drop. I dont have any problem using the rear gates with one hand even when they are connected to make one big gate.
/ new trailer #3
Looks good...and if it works for you and it is what you wanted...do not let the "lecturer's" get to you.
Now you will have neighbors and friends asking you to haul stuff for them
/ new trailer #4
Nice.
I am like you and like the landscape type trailer. Mine is a 18' by 82" wide 7K trailer with brakes on one axle also. I have no mesh around the side, just the rail, and slide in ramps that slide in from the rear. I could not have a fold up gate.
Like said above, if it works for you then its perfect. I know mine is perfect for me.
Funny thing is about my trailer is my last trailer was a 25+5 25K Goose Neck. I hated the GN andn hated the dove tail even more. People wonder why I went from a 30' 25K trailer to a 18' 7K trailer all the time, but its what was needed.
Just saying, buy what you need. Not what others think you need.
Chris
/ new trailer #5
Nice trailer. looks like it should function well for you. I would only suggest two things. one look at your tractor owners manual proper tie down points. I know its only a couple miles but you never know when your gonna have to slam on the brakes or swerve to miss a deer and I like to know that my load is completely secured. also might consider some type of overlay on the ramp sections as the expanded metal will stretch from the tractor weight over time and become unsightly. not that it will affect the usefulness of the trailer, just the appearance. Maybe Im just too picky. either way congrats it looks great.
/ new trailer #6
That trailer is EXACTLY what I'm looking for...I need an 82" width ..Need a multi purpose unit like that. Having a difficult time with the place that sells units like that around here.
I also want the gate and no ramps, I don't like them due to the stuff that I load. Can't see where the tires are while loading/unloading and due to where I live, I can't get a spotter....I've used ramps more times than I care to admit, but loading and unloading a classic car gives me more pucker factor than I want.
If you don't mind, what did you give for that.
/ new trailer #7
Why not just drive the tractor the 2-miles?
If the trailer suits your needs and is what you want, then you bought the right trailer.
/ new trailer #8
Good looking trailer! :thumbsup:
I personally would want brakes on both axles but it doesn't look like your hauling much so there shouldn't be any problem at all. You certainly got the right truck for the job. ;)
/ new trailer
This trailer s 6'10" floor plus another 10" on each side for the fenders. The rear tires stick out further than the truck and on my winding road you have to watch it to make sure it is in the right spot. I don't know if it would work for a car because the ramp reinforcements aren't far enough apart for a larger car. I really like this type of trailer because you can throw a bunch of small stuff in and not worry about it
I paid 3300 (3500 with the gate lift, tie downs and spare), which I thought was highway robbery at first. After shopping around it seemed that all the trailers like this that aren't built as well, or no mesh sides were 2600-3000. All the used ones I found looked like junk or were 2200 - 2500 and didn't have the right ramps etc. I also drove to Front Royal which is about an hour away from DC to save $400. I bought it from Crimm's Trailer and they were great. I called a bunch of places that didn't know much about the trailers and I would rather deal with a pro. Everyone else had to check on the lift assist that Crimm's told me about. Its the best 140 I ve ever spent!
As far as tie downs I am using the rear axle and the front loader arms. I will check the book but the loader arm seems right. The straps I bought have loops with hooks so they can loop around axles etc.
/ new trailer
Timswi
from my own pics maybe the ramp reinforcements are far enough apart. I can measure them later if you want.
/ new trailer #11
You do not want to tie down to the front end loader. You need to find a spot on the tractor itself. The FEL, even though attached, is considered a implement and not part of the tractor itself to the law men.
I actually took out 2 bolts in my tractors front end and got 5/8" lifting rings rated at 4,400# each.
Chris
/ new trailer #12
The best way to tie down a B-series is put a clevis on the drawbar and run a strap through it on the back. On the front you can run a strap behind the hood guard or through the frame. If you want to tie down the loader, poke a strap trough the cross tube on the loader and tie it down that way.
Trailer looks good BTW. It's hard to find landscape trailers of decent quality.
/ new trailer #13
Chris
That is what I use on my JD 2305. Except I use 1/2" because it is all I could find. Where did you find the 5/8" lifting rings?
/ new trailer #14
Donn, nice trailer!-- I have one suggestion that I did on my new trailer. I was at Lowes maybe it was home depot? I found some outdoor stain that was on sale $8.00 a gallon. Well I filled up an old pump sprayer and sprayed the wood floor on the trailer. I did this 9yrs ago on my 5x12 UTV trailer and the wood is still in good shape!! I figured for the $8 it wouldnt hurt any. Dang 2x12 treated wood is high dollar now a days.. Besides I am the only guy I know that has a stained brown trailer- looks pretty good!:D:cool:
AndyG
/ new trailer #15
Phone company. My buddy works there and he was installing large cabinets on neighborhoods for U-Verse TV and they take them out when set. He gave me about 25 of them. I have used them for a little bit of everything.
Chris
/ new trailer
Chris
Other than possible tickets is there any danger to using the loader?
I was worried about the loader bending if I got into an accident but with all four corners tied down it seemed like it wouldn't move unless the trailer overturned.
/ new trailer #17
Not sure but its not good practice. Find another way to secure it better.
Chris
/ new trailer #18
I like that trailer! :thumbsup:
What's the difference between an "equipment trailer" & what you got?
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
17395SFL (A61568)
17395SFL (A61568)
2019 International DuraStar 4300 26ft. Reefer Box Truck (A61573)
2019 International...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
