4 1/2" Angle Grinders - How Many??
/ 4 1/2" Angle Grinders - How Many?? #81
I was looking at this :2-Tool Combo Kit-HR2475X4 at The Home Depot
at H/Depot the other day,thought about buying it. I thought it was a good deal.
I don't own an angle grinder rite now need one. What keeped me from gettin it is/was I didnt need hammer drill.I got one bad a@@ Bosch Bulldog.
Boone
/ 4 1/2" Angle Grinders - How Many?? #82
The lock nut has two sides to it, try turning it around so the flat side hits
With the bottom washer on, through nut will not reach the shaft. Without it can not screw the nut down enough to tighten the disk.
Sanding disks curl up or roll up very soon after the sealed package is opened. Soaking them in water lets them unroll and a little weight helps. They are water proof and work wet as good as dry. Don't last as long as a flap wheel, but are very aggressive, 24 & 36 grit.
See Picture
Something that seems common is the flanges that keep the lower washer from turning on the shaft are much 2 short of shallow. On the Porter Cable it often slips on to the round and really locks up. Big Pain.
/ 4 1/2" Angle Grinders - How Many?? #84
I own 4. (2) 4" makitas that were my dad's,1 cheaper line Dewalt, and a 4 yr old Ridgid. I was told that Metabo made Ridgids grinders. Does anyone know if that is true.
/ 4 1/2" Angle Grinders - How Many?? #85
I researched and looked at numerous 4.5" grinders last fall. We've got Metabo's at work, tried them. Liked the Dewalt 10A model for my probable weekend only use. Put it on my Christmas list last year. Got 3 of them! Took 2 back, figuring "don't need more than one". Wrong! I wished I would have kept all of them. Three would be ideal for my purposes: 1) cutoff wheel 2) grinding disc 3) wire wheel.
Oh, BTW, the Dewalt is a nice tool. Can't say anything bad about it and I've cut a fair amount of metal with it (for a non-pro). Probably go through 4-5 cutoff wheels on a typical weekend use when I'm in "project mode". I don't use my oxy-acetylene torch as much either. Just hope it holds up over time. Will probably add it to my Christmas list again this year.
/ 4 1/2" Angle Grinders - How Many?? #86
... On the Porter Cable it often slips on to the round and really locks up. Big Pain.
I had one of the cheapies lock up good. It wasn't a HF one. It was some hardware store brand. I had to disassemble the head and put it in a vice and use a pipe wrench to get the lock nut off. Still use it weekly, though.
Dodge Charger (A56859)
UNUSED WOLVERINE QC6-26-15G 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61567)
ABI 80-ASRT-074...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
