Baby Grand
Elite Member
- Joined
- Nov 12, 2007
- Messages
- 4,663
- Location
- Windsor, CT.
- Tractor
- Kubotas: L3240GST B2320HST B5100D & G5200H
Tie those shoelaces but good!
Be aware that you might be infringing on a patent held by Rube Goldberg. . .
I plan to have the shaft below the trailer bed...
Judging by your profile picture I assume you mean to not let anything get caught in the turning shaft. I'm the type that over engineers everything, safety is first. I plan to have the shaft below the trailer bed and covers over the pulleys and belts, and a cap over the PTO output.
Thanks for all of the great ideas, the plan in my head is getting clearer. Iplayfarmer - I like the thought of middle placement of heavier items, especially water, maybe two smaller water tanks (one on each side near the wheels). If I could accomplish two seperate shaft speeds that would certainly be benificial but I cant think of a way to do so without additional equipment. The plan thus far is to run the transmission in reverse to achieve 540 RPM shaft speed, the great thing about the transmission is I can shift into 3 different forward gears which (combined with an engine speed change) would allow me to have 3 different torque "settings" and the engine speed could be reduced depending on the workload. The PTO drive definately needs to spin in the proper direction but all the other devices could be designed to run in the opposite direction. I cant think of many situations where I would need PTO and another device running at the same time other than a hydraulic pump. Engaging each device is still a problem, but you may be onto something with the serpentine belt. The air compressor I'm looking at is actually a piston A/C compressor from a 70's volvo which has an oil sump for lubrication rather than oil in the lines like most compressers, the off road guys use these a lot and the output is very impressive. with that setup I could use a conventional belt drive electricly activated clutch. The welder/generator I plan to use is a little too big to run this way though. BUT i could always add a high output alternator and use an inverter for power tools :thumbsup:.
Day- I know your post was simply humor and I see how it may sound to some like a crazy idea. Rube Goldberg devices are amazing in my opinion. I think this idea is the opposite though. Having an electric or gas motor for every device seems a lot more complicated to me, not to mention extension cords everywhere and having to load up and move everything to where you need it. That old 6 cylinder is 44 years old and will see 44 more with the right care. A well designed system using industrial grade components will outlive all those little 10 horsepower engines and small electric motors on multiple peices of equipment.
Short Game- I dont like cats anyway :laughing:. I'm pondering the mid traverse mount engine. Thank you for the idea. Up until now I envisioned a the forward facing engine/transmission above deck with a Harley Davidson style beltdrive passing through the floor to the pulley on the lineshaft. They make a high performance upgrade system that I believe would handle the 6 cylinder with no problems. Have shop will travel, thats my now slogan :laughing:.
