8" No-Name Chinese Chipper Grief and Slip Clutch
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #1
mikester
Elite Member
Canada
M59 TLB
The chipper flywheel was stopping and the engine wasn't bogging down...
I discovered that the secondary pulley driving the flywheel was spinning on the shaft. I assumed that the shaft key either fell out or disintegrated based on the metallic dust on the inside of the pulley. Looking at the parts diagram it doesn't show a key for the secondary pulley and it got me wondering if
1. the pulley designed to slip on the shaft as some sort of chinese safety feature?
2. somebody forgot to put the key into the drawing and the pulley was assembled without a key and retaining set-screw
The shaft is scored badly and has some evidence of bluing and the pulley hub is scored on the inside as well. There is no slop on the hub over the shaft. This is a no-name chinesium chipper with questionable build quality. Everything looks hand made - eg. the spare chipper blades are about 1/16" to 1/32" difference in length.
Ideally I would replace the shaft and hub but good luck finding parts that fit. I am not keen on disassembling everything and getting a machine shop to fabricate a new flywheel shaft.
My questions to the group:
1. Would you consider simply hammering the hub back onto the shaft with a key and set-screw and hope for the best?
2. Would you pull the shaft and have a machine shop fabricate a new one?
In either case I think I should be adding a slip clutch as a minimum. I've seen some viscous PTO couplers in the past but for the life of me I can't find anything useful on google search results. Does anyone here have something they'd recommend for my chipper application?
I figure the failure mode would be the shaft end holding the pulley would most likely shear off. The last thing I want to see is the 200 lbs flywheel suddenly stopping and destroying my tractor PTO.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #2
That must be some large chipper with a 200 lb flywheel....must be a commercial unit beyond my experience.
But good luck anyway.
Mike
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #3
Could you get a machine shop to drill the shaft and pully for a shear bolt? They may have a magnetic drill press that could finagle a way in so you don't have to completely disassemble to the shaft. On the other hand, if the pully slid off without retention how hard could it really be to pull the shaft completely:ninja:
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #4
Is it a tapered hub pulley? I can't imagine a driving shaft without a keyway. No set screw is going to drive a 200lb. flywheel. I suspect a sheer bolt won't either. Since you didn't post the parts drawing or any pics, it's hard to suggest a fix other than welding. Good luck.
Yes there's a tapered hub [12] that fits on the straight shaft [5], the pulley [13] is also tapered and fits on the hub. Pulley uses 5 belts.
The shaft [5] and hub [12] have a 1/2" keyway. The hub [5] also has a provision for a 6mm set screw to lock the key in place. I found it weird to see no key and no set screw on the chipper or in the drawing. Either the set screw wiggled out and then the key, or more likely, the manufacturer was saving money and never installed one.
The main pulley and drive shaft [17] connected to the PTO have a key in place [24] in real and in the drawing.
Trust me, I'd have to completely disassemble the machine to remove the pulley and fan assembly as the manufacturers were kind enough to make the fan shroud interior and fan inaccessible. The hub was spinning on the shaft and it was an SOB to remove the pulley due to lack of clearances between the hub and frame. The drawings and the as-built machine casually resemble each other. My impression of the build quality is that every machine is custom built one at a time by drunk workers using hand files on coat hangers for welding rod.
At least it has a cast 200 lbs fly wheel!
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #7
That looks very similar as design of my US made S&R Pro Chipper, as well as the old Machete chipper.
S&R Industries has closed their doors long ago I think...
I bought my S&R Pro Chip used in the 90's and it still works pretty good for us, but of course it would be nice to have adjustable speed hydraulic feed roller drive, instead of the original fixed speed mechanical feed.
Sounds like the key was left out of your Chinese version chipper!
PS.
I saw similar copies for sale locally for just over $1000 few years ago.
This is a photo taken around year 2000
  • S&R Pro Chip_Sales_Brochure.pdf
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #8
Here is another S&R that was offered for sale locally when I was still looking around.
And here is the original design Machete chipper:
I think all these units started with one general set of plans that have been modified depending on the manufacturer's capabilities.
I ended up ditching the mechanical feeder and installing a reversible hydraulic in-feed motor with speed control. Chips bouncing out of the chute would de-rail the mechanical feeder belt. The original PTO shaft to the feeder drum looked like it was butchered from a cheap socket set 1/2" swivels. POS all around, I will never buy any equipment made in china ever again. Getting harder to do these days....
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #10
The first parts drawing looked to be a Jinma (I had one) and sold it after 3 years for more than I paid for it. Now, I pile it up and roast all of it. Much easier. Little accelerant and a match is all that is required.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #11
I'd remove the pulley and dress the shaft and the inside of the taper where it rides on the shaft. Don't go overboard on the dressing. The taper part of the pulley should slide on the shaft with just a little drag. Insert a new key and install the pulley. Most taper pulleys should clamp down on the key. With the taper tight, the pulley, key and shaft should become one. Use Loctite on the taper bolts and tighten the taper, a little at a time, in a crisscross or star pattern. If cast iron, go about 20-25 ft./lbs. of torque.
The most likely cause of the initial problem was probably a loose taper. That should be a maintenance check item.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #12
Sure burning works but we need the wood-chips as a blueberry bush mulch!
It helps a lot with maintaining proper moisture and weed control.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #13
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #14
I think you get what you pay for, I am very pleased with my Woodland Mills WC88 chipper that is engineered in Canada and fabricated in China. It is was affordable and does all I ask of it and was a good choice as I wasn’t going to pay twice as much for a North American made unit.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #15
Is part #12 in the OP's diagram a tapered & split hub and pulley, and there's 2 or 3 of bolts/washers 10 and 11? That's a pretty common way to lock a pulley to a straight shaft especially on flail mowers and similar.
See: Bushed Pulleys: What you need to know before installation - UtterPower.com
I agree with the folks like Tinhack that you should clean up the keyway and shaft and install it properly. (also reminds me to check those bolts for tightness next time I work on my Woodmaxx chipper)
If the hub is on a tapered shaft (which I don't think is the case here according to the diagram) you can use valve lapping compound to lap the hub and the shaft so they have a close tight fit. I used to do that on certain motorcycle engines converted to road race use, where the ignition rotor was known to part ways with the crankshaft at the high rpms the engines got tuned for.
In this case the bore of the hub may be chewed up. You may be able to clean the bore some with files or something, and maybe use the same lapping trick by tightening the bolts until the pulley+hub turn with some drag. If the hub is too beat up inside, v-belt pulleys and tapered locking hubs of different types are common and easy to find from places like McMaster-Carr.
So are you saying the installation of hubs on a shaft without a key is normal?
The hub [12] is on a straight shaft [5]. The shaft is chewed up worse than the hub. I can find replacement hubs anywhere, the shaft is the problem as it's custom made.
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #17
Please check out the vendor mentioned in post #13 above!
Their replacement Jinma chipper main shaft may fit your chipper?
   / 8" No-Name Chinese Chipper Grief and Slip Clutch #18
If it's a tapered hub and pulley like I linked to it does not need a key. The hub locks on the shaft hard enough to transmit the torque. Unless it comes loose that is.
You can also check with Woodmaxx to see if their shaft is the same.
2010 CATERPILLAR 303.5C CR EXCAVATOR (A60429)
2010 CATERPILLAR...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A60432)
UNUSED RAYTREE...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
