Tinhack
Elite Member
- Joined
- Jul 3, 2020
- Messages
- 3,524
- Location
- Lytle, TX
- Tractor
- Ford 3910, John Deere 420C, Kubota G32XKS, IH 2606, Bad Boy Maverick-60"
I'd remove the pulley and dress the shaft and the inside of the taper where it rides on the shaft. Don't go overboard on the dressing. The taper part of the pulley should slide on the shaft with just a little drag. Insert a new key and install the pulley. Most taper pulleys should clamp down on the key. With the taper tight, the pulley, key and shaft should become one. Use Loctite on the taper bolts and tighten the taper, a little at a time, in a crisscross or star pattern. If cast iron, go about 20-25 ft./lbs. of torque.
The most likely cause of the initial problem was probably a loose taper. That should be a maintenance check item.
