Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 4,051
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Saturday AM - could not figure out why irrigation didnt run... Hmm took cap off well and can hear the pump running even tho I thought there was no water being drawn, so dropped a stone to check the water level - 15 seconds or about 350' is static level - this is lowest I have ever seen.
Long story short wife left the valve open on 200' of manual drip irrigation for 20 hrs Fri-Sat AM.
So solved that problem but lingering issue now is the pump likely ran dry when I thought we had in excess of 10 GPM flow in the well. (don't have a low pressure cutoff switch installed but will by tomorrow!)
My question is determining the static water level using the stone drop method. As close as I can tell by my searches is its about 24' per second so @ 8 seconds = 192' to the water level. Is this accurate - what do you water well guys/gals say?
The well is 6" casing, 410' deep, pump is 1.5HP 10GS15 Goulds set at 375' +- so my next step this AM was to monitor the static depth when irrgation was running. At the beginning of the cycle the water level (by my stone drop test) was 5 sec or about 120' to static water level. At the end of the cycle, 13 sec or 300', then 30 minutes later after the end of the irrigation cycle the level was 8 seconds or 190'.
What this told me was the recovery (300'-190=110x1.5 Gal) rate in 30 minutes was roughly 165 gallons or 5.5 GPM is the flow rate of the well.
What will skew the numbers is if my estimate of 24' per second is accurate on the stone drop test..
A little more detail on the well is when it was drilled (thru 400' granite) it produced 1.5 GPM, so we had it hydrofracked and after the fracking it was reported "over 10GPM". So the other question is can or does a hydrofracked well "close up"? Can it be fracked again?
Thanks in advance..
Thanks in advance..
