MiG welder: how thick can it weld?
/ MiG welder: how thick can it weld? #41
I still dont get it with the folks here saying how thick their XXX machine will weld and what thickness it wont weld. That is like saying how big a pile of dirt can you move with your BX Kubota tractor compared to a Grand L without qualifying it with any time limit. A 110volt machine can weld any thickness material made if you have the time to make many, many passes. Even with a 220v or 480V machine you need to limit the size of the fillet weld pass because at some point, regardless of the power the weld will start to cold lap and not tie into the existing weld or basemetal. Generally speaking the larger the machine, the higher amperage you can run which equates to higher wire speed and/or bigger diameter wire so you have faster deposition rate. But given the time and multi-pass welds,with your 110 volt, you can eventually weld the same thickness as a big industrial machine, you just may miss your next vacation because you havent finished welding but dont worry, you will eventually get to the finish line. Just like the tortoise and the Hare race, you can do is slow or fast but in the end both of you end up at the same place.
/ MiG welder: how thick can it weld? #42
i do alot of metal work, but mostly decorative. I have a 110 volt mig welder (with gas). AND a 220 volt stick welder for heavier metals.
I chose the 110 over the 220 for one reason only. I have 30 acres and need to do repairs at alot of different areas on the place. i have 110 outlets all over the place, but not much 220. Im an electrician, so i guess i could place 220 all over, but why. the repairs i do are mostly thin horse panels, and the 110 volt mig works wonders on these.
personally, anything over 3/16" that i work on, i use the stick welder. Some day ill break down (probably right before i retire) and buy a nice Miller 220 mig welder that ive been eying. but if i do it now....my wife tells me ill be living in the heated tack room:laughing: :p
especially after just buying the tractor. Ill just have to bide my time and wear her down. then oneday the miller will be all mine.:cool:
/ MiG welder: how thick can it weld? #43
In my experience welding thick steel with a small machine doesn't work well because it's too much of a heat sink and the base metal just doesn't melt. I am guessing it takes 150-200 amps to approach the point where you could overcome the conductivity rate enough to effectively weld an "infinite" piece of steel.
/ MiG welder: how thick can it weld? #44
Last year I had to repair the Z-bar of a NH LW130B (3-yard wheel loader). It was made with 1 1/2" plate that broke in half. I would never have considered using a 110v machine for this, even if I had all of the time in the world. Even my 8000W motor/generator and LN-25 wire feeder with .035" wire was probably a little small. I ground everything to a nice bevel, preheated with a torch, and used a helium gas mix to get the bead to penetrate and lay down. There was still 2 days of welding involved, plus over a day of grinding and fitting. As it was, it took 4 days to do the repair, including removing the broken parts and reinstalling. That 4 days of labor and consumables, was still cheaper than the $7000 replacement cost plus shipping.
I guess it could be done, I can only imagine how long it would have taken. I would have hated to have missed our Hawaiian vacation last year.
Brian
/ MiG welder: how thick can it weld? #45
I have a 220 lincoln tombstone ac/dc get some 6011 1/8 rod some 7018 3/16 and you'll be all set. I have a 180 amp mig also and there is no comparison between the two.It's like "a 2 ton bottle jack will lift your car and a 966 cat will lift your house".Each unit has its place i guess. remember opinions are like arm pit's everyone has one and not all are good.
/ MiG welder: how thick can it weld? #47
Shield arc,
Thats a nice Lincoln in your pic.
/ MiG welder: how thick can it weld? #48
Hi, I never welded but I'm thinking to give it a try. The point is that I know nothing more that what I could find in the pages of the various manufacturer of welding machines. I will use the welder on tractor related equipment and therefore on 1/2 inch of iron or more.
I was initially considering a stick welder now I'm thinking of a MIG welder. My question is: a MIG welder rated for 1/8 or 3/16 thick iron will weld a thicker iron? Will eventually the weld be good? I'm not so much interested in speed of welding since it will be more of a hobby.
Also, which are the difference between a Miller and an equivalent Hobart (I believe they manufactured by the same company).
thank you very much.
Hello, Sevilla. I do a lot of welding (self-employed, so not really 'professionally' so I'm not citing scripture here) and here's what I have learned. I use two Miller wire welders (a 'matic 210 and 212) for most of my work, but I also have and swear by my Hobart Stickmate LX AC/DC. With the wire welders I weld from 1/8" to 1/4" mild steel. No problems, even not at the max output from either one. Caveat: nobody x-rays my welds or checks that they meet any standards at all other than the products I make don't fall apart on the hiway or the farm. You can get a 'matic 212 or equivalent for about $1,800 MSRP (less is easily done, but not a whole lot, maybe $1,500?). You need a bottle of shield gas and I recommend the lube pads. You can get an AC/DC Hobart Stickmate LX (I think that's still the current model) for about $500 MSRP and less at Tractor Supply or elsewhere. No gas. You can buy all kinds of rods to weld cast iron (useful on tractor equipment sometimes), aluminum (I've done it), mild steel, and stainless steel. You can also get hard surfacing electrodes which is useful for impact parts and ground-engaging areas of implements. You can weld more than 15 feet from the welder easily with longer leads.
With wire you get good travel speeds and good weld appearance (hint: buy the anti-spatter spray) but it helps if the metal is clean; paint and moderate rust can be a problem. But you're going to need to control the wind/breezes so they don't blow your shield gas way (unless you use flux-core). You can't weld more than about 15-18 feet from the machine becuase, as I see, that's about the longest gun lead they make (without push-pull). You can weld mild steel easily, right out of the box. You can weld stainless steel, and maybe other materials (other than aluminum) without having special accessories but you'll have to change the wire for each different material (a time-consuming process). For aluminum you'll need different shield gas and a spool gun or push-pull.
With stick you get good travel speeds and variable apperance depending on the electrode. You will need to remove the flux slag from the welds for appearance and to eliminate voids where water can trap to form rust. You can weld all kinds of materials and do different tasks easily, just change the electrode/settings. Aluminum, stainless, hard-surfacing, cast, no sweat. Outdoors, windy, 100 feet from the welder, no problem.
If you're going to buy one welder, buy a stick welder and learn to use it. 6011 and 6010 rods for general purpose mild steel work. Buy an AC/DC unit, not just AC as some rods (6010/7018) require/recommend DC. Use quick connects to make moving things around easier so you're not dragging leads at the same time you're moving the welder. Learn which polarity the rods are recommended/designed for.
What I see, personally, different in the seemingly-identical Miller vs Hobart welders is that the AC/DC verrsion of the Hobart claims, IIRC, a maximum output of 160/225 amps, DC/AC respectively, and the Miller claims 150/215 or so amps, DC/AC respectively. Also, you can buy your Hobart from Tractor Supply right off the shelf instead of the Miller which means you have to go to a welding supply store (or somewhere online).
Not that it's much of a question anymore, but buy a good auto-darkening helmet that has variable shades and a "grind" setting. I use the "grind" setting for all my Oxy/acetylene work and love it. Hobart makes one...a someting VXP or some such. Tractor Supply used to carry them but I don't think so anymore. I had a Jackson 3N1 before and it was okay but at about 400 bucks it was not as good a bang-for-the-buck deal as the last VXP (or whatever that model was...wish I could remember for sure) I got for $150 from Tractor Supply.
Oh, and wear long-sleeves...arc welding will give you a nasty sunburn.
--HC
/ MiG welder: how thick can it weld? #49
/ MiG welder: how thick can it weld? #50
Jeff, you burning those 7018 on ac? 3/16 7018 rod should be run at between 200 and 275. My Lincoln ac/dc only goes to 225 on ac and 125 on dc. While 7018 (low hydrogen rods) give decent results ac, you will get more splatter and less penetration than if run dc+. 7018 run dc+ will give the most penetration and least splatter. That's why I stick with 1/8 inch 7018, they run between 110 and 165 and I always use dc+ with them.
IMO, 6011 are probably the most versatile rod made.
/ MiG welder: how thick can it weld? #51
Well i may have spoke out of turn it may also be 1/8 rod but i thought it was larger i get great results in any case.
/ MiG welder: how thick can it weld? #52
Low duty cycle will kill that theory. I use my 110 alot, I do understand what you are saying. The same as a 5 horse motor will drive your truck, with enough gearing, do you want to do that. No but you could.
/ MiG welder: how thick can it weld? #53
Don't get me wrong, I certainly wasn't questioning your ability or knowledge. You can get decent results running the 3/16 7018 on AC but best results will be had DC+ and like I said, my welder doesn't put out that high an amperage on DC. Maybe you had it backward, 3/16 6011 and 1/8 7018? In my experience, I see very little difference running 6011 AC or DC+ (maybe slightly less splatter on DC); however, DC- doesn't give as deep a penetration. If I have good clean metal or have the time to clean it up I'll grab 7018 every time but just to make a quick repair on less than favorable metal condition I will use 6011. When working with thin sheet metal I'll often use 6013.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Wooden table 16 foot (A61569)
Wooden table 16...
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
