Do you think it is possible???
/ Do you think it is possible??? #1
horticattleman
South Central Louisiana
CT335
I have a tiller for a 425 but have never really used it. Do you think it is possible to convert it to a ditch filler????
/ Do you think it is possible??? #2
Sure. Just replace the tines with left & right hand augers.
/ Do you think it is possible??? #3
Why not just make a V shaped pusher blade and weld it to a QA plate. Shape the blade so it leaves a small mound over the trench. or leave the back of the V open for the hill effect. Could also have a wheel behind the V to compress the dirt into the trench
4 steps ahead of you. I have made that already as well as a flat angles one with a shoe and they work pretty well, except in S. Louisiana we have some soils that are very clay type and once the spoil sits exposed for more than a few hours it becomes hard. We use small cultivators to break it up buty its time consuming.
Can I buy just the auger spindles? Guess thats a Kieth question huh?
/ Do you think it is possible??? #6
I don't know if Keith will be the best resource for that question. He knows his PT parts, but this is a little off the wall.
I've seen such augers in both agricultural and industrial settings. I'd start looking at agri-supply.com and mcmaster.com
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
