Best Garage Lighting
/ Best Garage Lighting #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
Our Monitor Barn addition is expected to be done this April. Part of the first floor will be three bays including one for my new JD 4720. The ceiling is about eleven feet high and the garage is 24' X 30'.
I want to have energy efficient lighting that is good enough to maintain my vehicles, read manuals....
I would love to have anyone's recommendations and experiences with garage lighting.
/ Best Garage Lighting #2
What I learned about lighting my machine shed over the past month or two, is that it takes a bunch more fixtures than I had expected.
It's a 24X27 space. Trusses are open and set at 11' H. Walls are just the backside of the steel siding, so white and reflective.
I wasn't looking for blinding bright space, but I wanted it where I can see what I'm doing and would only need task light in close.
I ended up using three 4' T8 fixtures in the central area and then I built 45deg mounts for two 8' T8 fixtures on the side walls. I also have one more 4' fixture over my workbench. All in, 16 4' T8 bulbs. It's good enough, but if I was wanting to really light the place up, I'd say it would take 2X what I put up. The 8' fixtures with 4 4' bulbs are much more cost effective on the buy side and don't require as much wire to be pulled. I think I paid $40 for the 4' and maybe $58 for the 8' fixture. I ran 12 gauge mc lite throughout.
Right now, with everything lit, I'm burning 512 watts. Which isn't spinning the meter all that much.
YMMV
Nice looking building, by the way. Very nice details.
/ Best Garage Lighting #3
I would go with T-5 if going with fluorescent. Cost more but lots of light.
/ Best Garage Lighting #4
I like the 4 bulb T8 with two ballasts... this way there is the option to turn on 2 or 4 bulbs per fixture.
Don't overlook the light spectrum of the bulbs... it will make a big difference if you spend a lot of time under the light.
/ Best Garage Lighting #5
Go to a electric supply store ( not Lowes or Home Depot ) give them the size including ceiling height. They will do a layout using t-5 and t-8 fixtures and compare the upfront costs vs energy savings. Unless your going to run these lights 10 hrs a day, 7 days a week t-8's are going to be the most cost efective. There is nothing the matter with a t-8 fixture. I've installed hundreds of them. good luck, eddy622611
/ Best Garage Lighting #6
There is a free lighting calculator at
Visual - Lighting Design Software Engineered for Productivity
The biggest challenge is to determine what light fixtures you want to use and what the lighting level is. I have a shop where I do finish work including looking for blemishes and color matching. What I use for a fixture is "SB-4-32" (stands for square basket, 4 bulbs, 32 watts meaning T8s which are readily available) and for Iluminance I've come across a figure of 50 footcandles for a minimum for that type of work and 75 has been recommended for folks as they get older. In my vehicle bay where I work on vehicles, it can be much less than that. I don't have figures for that side but I like lots of light and plan to use 25 or 30 footcandles and same fixtures.
/ Best Garage Lighting #7
I hung all my fixtures on chains so they could be moved if not quite in the right place. An added bonus is that they are going to be installed in my new shop when I build it next year. They have already been used in four previous garages. I install a pull chain switch on each fixture and have a wall switch controlling all outlets. That way I was able to turn them all on or off at once if needed but able to turn off any that weren't needed.
/ Best Garage Lighting #8
I have 4-qty 6-bulb T5 fixtures set at 15' in my 40'x60' shop. I love the bright white lighting this produces; there is plenty of light. Each 6-bulb fixture draws 54 watts. I paid $240 per fixture plus my time and materials to install.
It is amazingly efficient since I'd swear the 54 watts was equivalent to 400-1000 watts of incandescent depending on reflectors.
I highly recommend that if you use 4 or 6 bulb fixtures to dual switch them so that you can turn on 2 (switch 1 by itself), 4 (switch 2 by itself), or 6 bulbs (switch 1 and 2 together) at a time which is easy to do with these fixtures. The versatilty of awesome even if it does require an extra circuit (cost of conductor).
/ Best Garage Lighting #9
I also use 2 tube T-8 fixtures for lighting in my garage. You can get them at Walmart, Lowes, Home Depot etc. If the garage is not heated check the light fixture box to see if it says for cold start use. The first few I bought and installed weren't cold start and had a hard time lighting up in the cold. I ended up using them in the basement where there is some heat and got the cold start ones that work great in the garage. My pole barn addition is 16' x 32' and I put 8 - 4' fixtures on chains and 2 more by the work bench.
/ Best Garage Lighting #10
Good point about the cold temperature operation. I'd imagine Vermont gets a few cold days. A regular ballast may not even start, and even a cold start ballast may take a while for the light to come up to full power. I have a mix of bulbs in my garage. I have an incandesant near the door for immediate light, a bank of flourescent tubes over the table saw (doubles as a workbench), and I have single 200 watt equivalent CFL over the bay where I do most of my mechanic work. I got the CFL as a promotional gift from a guy that supplies lights to my employer. That has made a world of difference on that side of the garage. I didn't realize how dark it was over there until I got that light in there. In the cold it takes a good 45 seconds or so to warm up to full light, but it really is nice once it's up and running.
/ Best Garage Lighting #11
Yes, the cold start ones I bought work great. Temps in my garage these past few weeks have been 30-40 degrees and the lights start up right away. The regular ballast T12 fixtures did not. I also use a CFL for my grinder lamp.
/ Best Garage Lighting #12
This new installation may be an opportunity to run the numbers on LED lamps.
Don't try to illuminate the whole place bright enough for a hospital operating theater. Go with a lower level of illumination for general lighting to support safe navigation and use task lighting to brighten areas where you actually do work requiring sharp vision.
For visual comfort try to not have more than a 3 to 1 ratio of brightness in your field of view. If you wanted 100 foot candles at bench top height for "run of the mill" task lighting you'd want at least 30 or more for general ambient lighting. For detail work requiring high visual acuity you would want extra light on the subject of interest beyond 100.
In my 24 x 36 wood shop (10 ft ceilings) I have 3 strings of monopole high output fluorescent which exceeds my ambient lighting needs. They are separately switched. In addition I have 3 each twin tube shop lights ( 4 footers) for task lighting over my cabinet saw, lathe, and workbench. I have other clamp-on lights, tripod mounted halogen work lights in single and double fixtures, and magnetically attachable LED lamps.
Sharing much of an interior wall with my wood shop is my metal shop (21 x 51.) It has 4 each 8 ft monopole fluorescents (high output suitable for cold locations) and a dual tube shop light on a swing arm to service my 10 inch grinder and a 14 inch abrasive cutoff saw. I frequently use tripod mounted work lights as task lights.
As time passes I will probably add more shop lights to both shops and a few fairly narrow beam spot lights aimed at specific machines from a distance away.
I like a lot of light on anything intricate but don't want to pay to light everything to the same level, just the areas that need it when tley need it.
Oh, by the way... my first engineering job for the Government (1984) was as energy conservation officer for SUBASE San Diego where lighting design was an important part of my work, mostly retrofit but some new design including ball fields, dining facilities, O-club, torpedo maint facilities and so forth.
Pat
/ Best Garage Lighting #13
Ecoslik,
The fixtures you're using are not 54 total watts - they're 6 Lamp T5 Fbays.. Each lamp is a 54w T5 HO lamp... Your total energy usage per fixture (depending on brand) is about 350 watts... Including lamp wattage and ballast loss factor.
The T5 fixtures will operate great in anything from 20-90 degree heat. If you get outside those ranges, the quality of light goes down.. If you get above 100 degrees, then light output drops substantially. As does lamp and ballast life.. I sell about 200 of these fixtures per month right now.. They're the neatest thing going.
I sell this stuff for a living.. By far, the best bet (cost and useability) is 2 lamp 8' HO strips.. They use T12 F96T12CWHO lamps.. start wonderfully down to about -15 degrees, and the hotter it gets, the brighter they are.
LED is still not cost effective.. Give it a couple more years and the LED drivers will be affordable, to allow for widespread lighting..
As someone said, Color temperature has a lot of effect on ones eyes, and PERCEIVED lumen output.. It's measured in Kelvin.. a 5000k lamp will APPEAR miuch brighter than a 3500k... But it's not so..
Please PM or email me if you have any questions.. I'd be glad to do a layout for you using a few different fixtures, and let you know your options !!
Daniel Cooper
dcooper @ cedtyler dot com.
/ Best Garage Lighting #14
I know nothing about lights but man your barn is nice!! great design...I wish I would have built something with an upgraded trim design...
/ Best Garage Lighting #15
I have mentioned these giant CFL's before on TBN, and no one showed any interest.
A 300 watt equivalent uses only 65 watts. They are rated to start at -20F, (many tube fixtures can't come close to that). They never hum, they don't flicker, they can be had in several different color temperatures, they're made to be used base up, and their cheap. One bulb, and one porcelain socket are under $20 at HD.
They take a few minutes to reach full brightness, (like any florescent). But, they start at about the same amount of light as a 100 watt bulb. So, your not in the dark waiting.
There are now 400 watt equivalent units available at electrical supply stores.
I HATE ordinary CFL bulbs, and do not have any in my house. However, after seeing these giant CFL's tested at the airport in hangars for 2 years, I tried them.
I have 10 of the TCP brand, HD, 300 watt bulbs in my shop, and for only $200, it's so bright I don't ever run all of them at once.
The only draw back I can see is they are about 10" long. So, if you have a low ceiling, you may end up bumping into them.
/ Best Garage Lighting #16
.... this is kind of a silly picture, but it shows the difference between this 'High Bay' fixture vs. an old fashioned 8', twin tube floro just above it.
I am seduced by light, so even tho' this fancy fixture was like $180 a couple of years ago, it is a helluva improvement when doing things like detailing where you want daylight-at-night in the garage. This is mounted in the upper corner so I can bounce the light off the side of the car.
DTCooper would know more than my technical judgement: "I jes' like'm."
Jim
/ Best Garage Lighting #17
Per what ray66v said i would look in the direction he mentioned. I have seen plant growers move in this direction because they can get great illumination at a lower watt usage. What growers do is: (a) mount them horizontally with dual opposing bulbs and (b) use high reflective metal surfaces as the backing. In many ways this is what you want to do....Gary
Late add - Maybe something like these would be a good solution ... http://www.buylightfixtures.com/canopy-fluorescent-12x12-surface-mount-fixture.aspx .
/ Best Garage Lighting #18
Our Morton is 60' x 72' with 12' sidewalls. The light fixtures of our choice are 4' with four T5 bulbs in each...........EXCELLENT LIGHT !!! Would buy the same thing again in a heartbeat.
/ Best Garage Lighting #19
I agree, T5's are the way to go. I had my shop estimated at a light store for t8's and t5's, only needed 4 t5's for a 28x42 footprint. I would have needed 18 or more t8's. Add in my time to wire and the pain of swapping out burned bulbs made this a no brainer. I was a skeptic until I threw the light switch. It's very nice to have all the light you need.
/ Best Garage Lighting #20
Don't know if you made a choice yet so here is my Morton barn. We used 8 8' fixtures, 4 T8 32W 6500K bulbs per fixture. Each side is on a separate switch, 3 way switches at each end of the barn. There is also a 13W flourescent nightlight on a photocell at one end. The 6500K bulbs are listed as daylight bulbs and are commercial grade. Residential bulbs are 2000K - 3000K and are a softer light.
