Not enough tractor or bad strategy?
/ Not enough tractor or bad strategy? #61
Don't cut your tractor short here. My old JD 650 would handle 2 feet of snow rather well with a 5.5 ft blade, engine was 17 HP but weighed about the same as the newer JD 2720. Miss the 650 but not the 8 speed manual transmission or the no power steering.
That's good to know. What was your operating weight when plowing with the JD650? I'm at 5000 pounds now. I'm sure a dry 2 feet would be no problem at all. But I don't know about the wet stuff. Were you doing 2 feet of dry snow or wet? I guess time will tell! ;)
/ Not enough tractor or bad strategy? #62
Well could be worse, just saw an Amish plowing his drive with a horse and a homemade v plow. :)
Nothing wrong with that.
Probably knows what he is doing, as well as why he is doing it that way (-:
/ Not enough tractor or bad strategy? #63
That is a long drive to not have something out front to clear snow fast with.
:laughing: With those winds he better have something fast or he may find himself out at the main road drifted out. And we've always heard of being drifted in.:laughing::laughing:
/ Not enough tractor or bad strategy? #64
Short of raising the road about four or five feet, I can't see how a blade could cope efficiently with a succession of storms like that ...only chains and a blower ...3ph is fine and cheaper, and you still have the use of the FEL.
I have an 8' fully hydraulic rear blade and an 8' plow blade on a QA, but for snow like that I'd put on my blower.
Depending on how many such storms you get in succession, even a plow truck would be challenged once the snow banks are as high as the blade ...unless (a) you have a wing, or (b) you have good enough footing the shoulders so you can plow really wide, or (c) you redesign your road in a series of zigzags so you can push the snow straight ahead of each road segment.
In a windy clime like yours, a single storm is the equivalent of several (as you found out) because you create a catchment for the snow. To mix metaphors, you will be moving all the snow from your windward field to your lee ...and that's a lot of snow because you have such long "fetches". As several have noted, windbreaks are the proven answer ...or, an elevated roadbed where the wind is your friend.
Finally, get to know your neighbors and find out what they have found to be successful ...this board has a lot of advice, mostly good, but local practitioners may give you the best advice.
/ Not enough tractor or bad strategy? #65
Regardless of whether you get a blower or not, your going to need chains. No way you are going to be able to blow up that hill with R4's alone. Once you get the chain, if the drive is gravel, you will be unstoppable. I think you did an amazing job looking at the uphill picture but to get a car through, you will need to scrape down to the hard surface.
A blower will always be the slower option (over a proper snow blade not a scraper blade) but I suspect your only option. I made up a hinged assembly that I used to use to break trail. It bolted to my front bucket and I could do 18 inches with my 1200lb Kubota (four tire chains). Once I had a path created I would go back and move the banks back with 1/2 of the V. This V-blade was 2ft tall
/ Not enough tractor or bad strategy? #66
As a note, I contract to the plow truck operators who do driveways like that. Every few storms they have to hire me to remove the banks with the blower.
/ Not enough tractor or bad strategy? #68
Having lived in ND for 11 years and 6 of them was in a payloader trying to keep roads clear, there is many things to be done.
Fall preventative...
When fall hits, mow every bit of standing grass 15-20 feet away from the drive. mow it short. one small clump of of grass will have snow will stick to it and create a snow drift 5' tall. Watching the ND highway prep the ditches- all were mowed clean, often the snow drifts would start at sign posts.
Get the fences up.
After the snow hits, push it way away from the road, sometimes making a snow bank snow fence. As said before, you have to make it as wide and flat as possabile, this prevents the drifts from building-the snow blows on past.
That hill with the bank looks to be the worst area. get the snow pushed back and clean, small "snowballs" can start the next drift
Steve
/ Not enough tractor or bad strategy? #69
Good one!
/ Not enough tractor or bad strategy? #70
5000lbs! No where near that but would guess under 3000 lbs. Rule of thumb I have, if the snow is deeper than the plow height you are in for real work. Learned the hard way (as always). Years back got 30 inches of the real wet stuff and could not get the tractor out of the barn. My wife kept saying I should go out and plow and me being a MAN said nah tractor can handle it. The real issue was I had pulled the tractor in the barn instead of backing it in and had to back out of the barn (front plow blade), what a mess. It's the initial pass that gets ya. Wife said "told ya so". I love being married to a smart women.:thumbsup:
/ Not enough tractor or bad strategy? #71
Did you have chains. I can't put chains on the rear because of clearance issues. I do have chains for the front but I avoid using them as much as possible because of garage floor damage and possible stress to the front axle shafts. We've only had 6 inches at a time since I got the front blade and that I can plow in 2wd. I hope we get a storm that at leasts tests the set-up so I know what it can do... But I know... be careful what you wish for! :confused2:
/ Not enough tractor or bad strategy? #72
Another rule of thumb I have, always ensure your front tires can spin before your rear tires and the front axle and drive train should work out fine with no problems or damage. I run rear chains year round and front chains only when it gets icy. You will never stop all the tire spin while moving snow, just live with it. With these smaller tractors just when you think it to be impossible to spin your tires and your tractor is unstoppable something will break. If you become obsessed with total ground engagement or traction on snow buy a bigger tractor.
Wow..I have learned an amazing amount of information. Thank you all.
I few things I learned:
Corn goes down, Fence goes up!
Stay very friendly with my neighbor and his JD 8300
Understand that sometimes I just won't make it to work and that is OK
Use all these pages of info to sell my boss (wife) on buying some new equipment. Still thinking but maybe a blower/blade/cab or bigger rig if I catch her on a glass of wine or two.
Keep working on my strategy and know that I may never nail it down
Mother nature is always more powerful then Diesel.
Most importantly I learned this Forum is an excellent source of info and filled with good people willing to help out.
Thanks again
Gio
/ Not enough tractor or bad strategy? #74
I'm with the front snowblower crew on this one,
I would put my X585 with blower, curtis cab, chains
and loaded tires out there and have a blast blowing the
snow and seeing it go go go gone!
then when i got done, i'd blow all that bank on the
windy side and make that gone too!
i have a tendency to widen the driveway where it drifts,
back as far as i can, if i have time, to reduce the bank
near the driveway that catches the snow. if you can get it
right, the wind can be your friend, look at a large portion of
your driveway that would blow clean if it weren't for the banks.
/ Not enough tractor or bad strategy? #75
I have a quarter mile long driveway also. When drifted in I have used a loader and filled and turned to dump. I also kept the loader low enough to push a little snow when turning. Then used the a rear blade to clean it up. This would take 2-3 hours.
I currently use an old truck with a plow, but think that in the long run a new plow on one of my newer trucks will be the solution. The truck also is used to clear a couple of rental driveways and a commercial property. The truck cleans it out quickly plus I can drive over to take care of the other properties. The downside is that the truck sits for long periods of time and requires maintenance and repairs.
In your situation, I would use the snow fence, and chains for the tractor. Try pushing forward with the loader to break through. The rear blade will work better for clean up.
/ Not enough tractor or bad strategy? #76
Wow..
Gio
After you get that bigger better equipment and get the drive cleared you can go back to the house, stoke the fire and spend a day or two on TBN.:D.
If your rural counties are average they only have a couple or so maintainers to clear all the east/west roads. Or maybe you have all north/south roads to get to work.:laughing:
The funny thing is, the Main road that runs East/West in front of my house and leads me to rt80 (5 miles away) is clear and dry as a bone. It is an emergency route and they keep it in great shape.
The day i was Snowed in I could watch cars flying down the main road. When I called in to work they thought I was joking. I had to send them pics to believe me.
/ Not enough tractor or bad strategy? #78
North south roads are usually drifted over, prevailing westerly winds do that.
I have a similar situation now, a driveway I clear has drifting problems. Rule of thumb is never put any snow on the upwind side that you don't have to, otherwise the wind will use it to dump fresh snow behind in the lee.
A rear blade will only deal with so much snow, anything more than 12" you need serious weight and power to deal with. My L3400 is quite a bit bigger than the 2400 you have, and it struggles with deep snow at times. Tire chains, ice chains in particular, are a very good investment.
A blower is your best bet if you have enough power to drive a good sized one. The 5 HP per foot rule applies if you're not in a hurry.
Invest in some good snow fence in the short term, a hedgerow is a good long-term strategy. What you'll save in fuel will pay for the snow fence in a couple years.
Sean
/ Not enough tractor or bad strategy? #79
Snow fence and call a plow truck. You can pay him for many years while you drink coffee in the warm kitchen for what you will will pay for a bigger tractor and equipment. Or if you've got the bread buy a 4wd pickup if you don't already have one and a homeowner or used plow setup. Use your tractor to clean up around the house. Forget plowing that open road with a tractor in that wind unless you get a big one with a cab and what a waste of money unless you are going to use it for a lot of other farm type stuff.
I'm a tough guy and work outside in the winter here in Maine but I wouldn't sit on my butt plowing on an open tractor in that wind. Crazy.
Nice place, it's got a nice feel at least from the photos and I love the way that open country looks. Nice house with real character and carpentry too, like the ones here in Maine.
/ Not enough tractor or bad strategy? #80
In the missile fields of ND, the main equipment they gave us was a payloader.
It was adequate. big snows you worked longer but it would do the job. It would have helped if they had given us a snow bucket, or a blade to angle.
Just before i left they gave us Bobcats with a blower. These were nice too. The nice advantage was one pass and the road was clear with left over; but it was a bit easier to get stuck.
Long term I would think a blower attachment would do you OK, I would just save for that myself...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
