Not enough tractor or bad strategy?
/ Not enough tractor or bad strategy? #1
Gio
Nebraska
Massey Ferguson gc2400
Had my first real snow and I failed to get out of my 1/4 mile lane. We had about 8 inches come down, I cleared that ok..then the wind came in. Overnight some parts of my lane piled up to 20-25 inches. I worked at it for about 4 hours and by time i got one spot clear the wind would cover it back up in a few hours. I had a hard time getting up my hill to try blading on the way down. After the wind died down I went back out and had a heck of a time. In the end I was bailed out by my neighbor with his Deere 8300 and massive rear bucket. It was very emasculating. Sitting there on my GC I felt like I just walked out of an NFL locker room shower.
I have a Massey GC2400 with an FEL and 4ft rear blade. The Blade would load up with snow and stop the tractor, the FEL was ok but I had nowhere to pivot and dump. I admit it, I am a city boy who just moved to the country and i have no idea what i am doing but I am willing to learn.
What am i doing wrong? Any advice would be greatly appreciated. Should I switch to a blower set up? Should I get a bigger tractor? Should I bribe my Neighbor with my excellent cooking?
HELP!!
/ Not enough tractor or bad strategy? #2
you might have better luck with a snow blower.That way you can shoot it with the wind
/ Not enough tractor or bad strategy? #3
Tire chains give you the traction needed to handle deep snow with a back blade. Also try running with the blade at an angle so that the snow does not pile up in front of it.
If your neighbor has a pickup with a plow on the front, that is the best option. Bribery almost always works!
Lou Braun
/ Not enough tractor or bad strategy? #4
HELP!!
So which way do you prefer to plow with the snowblower? Going forward? Or backing up?
If you don't mind backing up to plow, the blower can attach to your 3 pt hitch and run off your pto. No modifications needed for your tractor.
If you want to plow going forward, you need to get a skid steer quick attach adapter for your FEL and a hydraulic power pack hanging on your 3pt hitch and run off the pto. Looks expensive to me.
If you want to get a blade for your FEL so you can plow going forward, then you'll need the skid steer QA setup for the blade and for your FEL bucket so you can swap them on the FEL arms. The QA setup on my Mahindra 5525 tractor with the ML250 FEL (6ft bucket) cost about $1K installed.
Good luck.
/ Not enough tractor or bad strategy? #5
'I see a bigger tractor in your future..'
Edit: 'no, wait.. A house in Florida..'
/ Not enough tractor or bad strategy? #6
To be really, really honest, a subcut, armed with a 4' rear blade and a loader isn't much of a match against snow drifts, in open country like that. I can see from your one photo that you did indeed have your blade tilted to the max?
You DO need to blade very wide upon cleaning a drive. A blade wider, on either side, more than your normal "two track" drive width. Gotta strategize that you'll need to make it really wide, while you still can, early on.
You said you had it all cleaned, but overnight the wind drifted it back in?
Unless you were willing to go out every 3 hours during the night and re-clean in 3"-5" bits, there wasn't much hope. Yup, that was too much for your tractor.
Nebraska means winds and drifting. Go Big Red!! :)
/ Not enough tractor or bad strategy? #7
True enough, so don't feel bad about not being able to complete the job.
I ran into the same scenario once while trying to bail a friend out of a jamb.
His was probably a little less than a half mile but was a winding driveway. At the time I had no blower, just my JD 790 with FEL and a ballast box. Stuff just drifts in too hard sometimes. I did a lot of wheel spinning and bucket maneuvering but only got about a quarter of it done before I quit.
Should have known better, since an old tractor with a 7 foot blower tried before me and had to quit due to mechanical failure on the blower.
/ Not enough tractor or bad strategy? #8
Listen you received some good advice here now I'm going to tell you what you need to do. You have two options, one buy either a front or a rear pto snowblower,they will take care of almost all drifts. But as others have said front snowblower is $$$,Rear blower will work just fine but you need to be half turned in seat to see where your blowing snow.Second option would be a larger tractor, but even whith a large tractor and fel or plow you have banks of snow. That could work for you if you bank on the prevailing wind side, it would act like a snow fence. Hope this helps youj decide?
DevilDog
/ Not enough tractor or bad strategy? #9
Looks like to me you need at least a blower. If you have the property space; I would also start planting some type of tall shrub like forsythia or burning bushes. To act as a natural wind break. I just wouldn't want to put up a snow fence that long every year is all.
/ Not enough tractor or bad strategy? #10
No, you don't need a bigger tractor. Get a 3PH snowblower. Mine really clears the snow, was chugging through 24 inches of 'reblown' snow today. Second season, and I remain impressed with the Puma. Reblown snow is what you get when you don't have room to toss it right here, so you blow it in front of you until you get past the side of the house. One foot quickly piles up to two or more.
The small tractor fits into places a bigger one couldn't go. I must say, the cab and heater make it almost too nice. And the electric twist-n-tilt spout are working great!
Yeah, blowing backward is not ideal, but I can spin around and dig with the bucket when I need to. Still my first choice in setups.
/ Not enough tractor or bad strategy? #11
That is quite a lane for a small tractor, and Nebraska is known to get some serious winter weather. A snowblower and/or some larger equipment may be in your future, but there are also some observations to be made. Here's some thoughts from a guy who no longer lives in snow country but grew up and plowed snow up north.
Just looking at your pictures (great looking place, by the way), you made your initial windrows on the upwind side just before the wind started and that set up the opportunity for drifting. Having seen where it drifts, try to remove snow the next time so your windrows and piles are on the prevailing downwind side and as far from the lane as possible. That may involve a lot of jockeying around with a small tractor and a blade. A snowblower is somewhat better because it can throw the snow away from your lane and you can aim it downwind and well out of the way. A 4x4 plow truck would be much quicker, but no matter what kind of equipment you have, leaving snow piles upwind of the road is an invitation for drifting. Snowfencing upwind of the places prone to drifting would also help.
/ Not enough tractor or bad strategy? #12
With that driveway and in that location, I would think a front blower and chains ought to do it. NE can have way more snow that that tho, right?
/ Not enough tractor or bad strategy? #13
Spent my college years in Nebraska. My wife and I made our first home there. Those of us who live in snow belts from Michigan to Maine understand snow, but unless you've lived on the northern Great Plains, it is honestly, really hard to imagine what drifting is. 4 foot drifts can form in an hour. Snow can only be a foot, but the drifting can do you in.
Coupled with a sky so big it seems endless. 50 mph winds are a calm day. In over 4 years in Nebraska, I cannot honestly recall a calm day. :)
1/4 mile drive? Major snow fencing next year, right? :)
Still, I too see a better solution to your plowing in the future. It won't likely include your present subcut; snow blower or no snow blower. FWIW
/ Not enough tractor or bad strategy? #14
Gio,
I was born, raised, and spent most of my life in Wyoming. When you talk about wind and snow in Nebraska, I know what you're dealing with.
The bad part of plowing in windy country is that you sometimes make things worse. I've seen plowed roads with drifts several feet deep plugging them, while much of the surrounding prairie is blown fairly clear. Each time you plow, it creates a place to catch more snow and the drifts just get deeper.
My advice to keep the plowing to a bare minimum. From your pictures, it looks like you could pick a winter road around the worst spots. You may have places, such as an autogate or along a fence, that will fill up and need to be plowed out, but driving around bad places will help to get you in and out.
Many years ago, I worked for a county road department. Some ranches were fifty or more miles off the paved road and didn't see much outside traffic. During bad weather, we rarely plowed an entire route. We took care of the really bad spots and left the rest alone. The ranchers preferred it that way.
Good luck!
/ Not enough tractor or bad strategy? #15
I have basically the same tractor, with a front 6' plow blade mounted on the FEL arms, no chains, turf tires, 320' of gravel drive, that occasionally gets massive drifts, and I have no problem plowing it. It is however, pretty much flat land.
It defiantly looks like you could have really benefited from some properly installed, and placed, snow fence.
In my opinion, a snow blower without a cab, is not, a good way to go.
/ Not enough tractor or bad strategy? #16
Three ideas:
1. Keep the blade:
a. Turn your blade around, angle it as much as possible and back into the drifts at an angle so as to push less snow at a time.
b. As others have said, push it downwind so that it doesn't drift back into the driveway
c. Cut a wider path so that the snow has a place to drift a little before it plugs your road
2. Get a snowblower. I would go with one that is at least 6" wider than your wheel width.
3. Bribe the neighbor (at least this winter) and keep an eye out for a 3 point snowblower cheap on Craigslist.
In the long run, I think that you will need a snowblower if you want to keep your driveway clear yourself.
If you get a snowblower, look into getting a cab. That will make your snow clearing experience much more enjoyable (even if it is just a golf cart canopy on a PCV frame)
Aaron Z
THANKS EVERYONE. And thanks for the nice comments about the house. If you are ever in Murdock, NE stop by (not in the winter unless you bring your tractor:laughing:)
Seems like we learn something new everyday since we moved to the country. We were cleaning out one of the outbuildings in the summer when we first moved in and we found rolls and rolls of old wooden snow fence. I shrugged it off and said "they must have hard winters back then". Well "they" now "us" still have hard winters it seems. Next year we will be putting up fencing as soon as the corn comes down.
This is what the place looks like minus the snow. Thank you again for all the advice.
Gio
/ Not enough tractor or bad strategy? #18
Unlike what some people have said I think it can be done with the equipment you have. It just might take longer. We used to move snow with nothing but a loader in our RV park. Start by pushing with the loader down and level, continue to push until you see a good amount of snow coming over the top of the bucket. Then turn to the downwind side(The south or east around here) you may need to lift the bucket slightly, when you have pushed a couple of feet off the roadway lift and dump the bucket, then backup and repeat all the way to the end of your driveway. Then on the way back down use the rear blade(you might need a little bit wider blade) to pull off the bank of upwind side of the road widening the opening. Make more passes moving the spoils all the way to the downwind side, and widening the drive as you desire.
I have done this alot before we got the plow truck. I know what you mean about the drifts too, we got one 8" snowfall and have plowed 3 days in a row. Finally have everything pretty well crusted over and staying put but it looks like more snow on the way. It is piling up pretty quick.
/ Not enough tractor or bad strategy? #19
A beautiful place to live on the prairie.
If possible a half dozen rows of corn remaining on each side of the drive on that hill side set back a few feet like snow fence would save you a bunch of work and you could probably keep the equipment you have. Even better would be two rows of asparagus on each side where the 4 ft. tall ferns remain until spring. They would be there each year for a long long time.
/ Not enough tractor or bad strategy? #20
Good luck.
If you want to snow blow forward you need to get a Massey ferguson 2360 snow blower. It will run off your mid mount pto and from what I have seen on YouTube, it will really fling the snow. They offered me a free one with my tractor, but I turned it down :(. I just don't get enough snow to justify it over the $1,000 discount One new will cost you about $3,000. I think it might be worth it with that drive. Massey doesn't offer the QA bucket setup for that loader. Tried to have one put on mine, but it got complicated. A rear PTO driven unit sounds like the cheapest way, let me know if you go that route. I would be interested in knowing what that setup would cost.
You can also get a MF 2340 blade for the front of your tractor with hydraulic angling and lift. That setup will cost you about $1600. Tried together my dealer to trade me one for a Snowblower, but he really didn't want to, probably would have if I pushed the subject though.
I think if I was you. I would pull out my welder and fab up my own version of a county plow for that road. Think if you made it light enough you might be able to use it on that tractor. Connect with your inner B. A. Baracus!
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2022 EZ-GO ELITE...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
