Welding virgin needs direction ...
/ Welding virgin needs direction ... #61
I have done just a little mig welding so I really cant offer much here. I have stick welded for years no expert mind you but I get by. I have a AC/DC machine and will always have one. Small Hobart buzz box nothing fancy but it gets the job done. Here is a link to the unit I bought. Northern Tool Though I got mine at Tractor Supply.
/ Welding virgin needs direction ... #62
If you do decide to go with a 110v welder make sure you have a good 20 amp (30 amp is better) line with nothing else on it. They are pushing the edge on what a normal 110v circuit can handle. I've used a sp125 and found it a great little machine.
I think any of the 110v machine will weld anything you need to do. Remember you can weld multiple passes, very easy with MIG over flux core since you don't need to clean the weld before welding a second pass.Just use a grinder and angle the steel enough for the first bead to penetrate to the back edge (or center if your welding both sides) and then make a second pass to build it up.
/ Welding virgin needs direction ... #64
Beppington, I think you've started in the right direction. Now I know the buyer should always beware but I got my mig off of Craigslist. A pawn shop posted it. It was brand new in the box. My Lincoln 180 is 220v but I'm sure there's one out there that would accomadate your needs. This one sold new for over $600 and I got it for $400 plus tax. I guys it does pay to shop around.
/ Welding virgin needs direction ... #65
Depending on the size gas bottle, reserve a couple hundred bucks for the bottle if you buy and off course filling it. Rental will probably set you back a deposit and 10-15 bucks a month demerge cost. I find it better to buy the bottle. Larger bottles cost more, but are cheaper per cubic foot of gas to fill (labor to fill eats into the small bottles) and sometimes those pony bottles 35-50 cubic feet will cost as much as the 230 cubic foot to fill. But if you dont weld a lot, 60 cubic feet (standard size C -about 30" tall)is a good size to handle.
/ Welding virgin needs direction ... #66
I too second Craigslist. While owning new and the comfort of a warranty are nice, welders (the name brand ones) are tough critters. If you only plan to weld recreationally I think you will never see the value of a warranty. Maybe you will put 20 or 30 hours on it in the first year. These machines are made for 2000 hours a year...
I guage my craigs purchase by the shop. If it is nice and clean and kept, the guy/gal is probably selling it to make room.
Also, go for a 220 v welder. I thought I would only weld 1//4" but I seem to only be welding 1/2" these days.
Carl
/ Welding virgin needs direction ... #67
Even if you add a wire feed welder later for lighter metals and prettier welds, start with a good quality DC-capable 220V stick welder and 6010 or 6013 rods and an auto-darkening helmet. Your original post said you were interested in farm implement construction and repair, and 1/4" is at the light end of what you'll be doing in that area, with 3/8" being much more common and some 1/2" or even larger being required. I'm self-taught on a Lincoln 225 AC/DC bought from Sam's club 15 years ago, and using 1/16", 3/32", and 1/8" rod sizes it has done everything I need to do, farm-wise. I'd like to add a nice Miller wire feed rig for lightweight tubing and sheet metal, but the prices vs the only occasional frequency of use it would get just haven't been compatible with my wallet so far. But I certainly wouldn't trade my Lincoln AC/DC stick welder for one.
I'm definitely in agreement with those who say go with a 220V AC/DC stick welder to start with (DC capability is important, I run mine 99% on DC vs AC). Don't bother with a stick welder that runs on 120V. Good luck!
/ Welding virgin needs direction ... #68
I'm at the other end of the spectrum, as far as preferences go. I agree that the 220V DC stick and 220V MIG is the ideal combination ( I can't argue much, that's what I have) , but the 110 MIG will be easier for a beginner to use, particularly on light material. There's more to go wrong with the wire feeder, so the warranty isn't a bad idea. I'd be iffy about buying a used one, I had no issue buying a used stick welder.
In an ideal situation, the OP would have 220V 50 amp service ready to go and the budget wouldn't be a concern. If you're going to stay under $1K you're usually buying one newer welder, and if it has to be 110V the MIG outshines the small 110V sticks.
I sold my Miller 135 for $500 to a co-worker, he got a pretty good deal in my opinion, and it gave me some cash to go shopping for other "essentials". I didn't give it away by any standards.
If Beppington is buying a helmet, decent gloves, wire brushes, and gas along with the 110 welder itself, it'll kick the good out of $1K by the time he's done.
There may be a rewire for 20A service too, most household stuff is 15A. It will run ok on 15A, but may trip the breaker at higher settings. Mine was as easy as running 12/2 armored cable to a 20A fuse in my panel, or could be changing a breaker to 20A instead of 15A as long as the existing wire can safely carry 20 amps.
Once he's up and welding with the MIG, there's time to add 220V service and shop for a good used stick, then you've got the best of both worlds. One machine excels at light material and tacking, the other deals with heavier stuff and building up material.
If I hadn't got my 220 MIG for free (another good story) I'd still have the 135 and a used stick, and in reality it's all I'd need, except I added the capability to use a spool gun with the 180 Miller.
My :2cents:
Sean
/ Welding virgin needs direction ... #69
I bought a cheap HF 220v MIG on sale, but the other stuff really adds up quickly. AD helmet (HF), gas tank, gas, clamps, mig pliers, wire, replacement consumables, clamps, cart if you don't have wheels on your welder, grinder, wire wheels, clamps, welding table, leather apron, leather gloves, and did I mention clamps?:laughing:
If you go to weldingweb.com you'll find some long and useful info on usablilty of 120v MIG welders--the consensus is basically that they're good for sheet metal but not so hot for fab. I'd have to agree that a stick welder is the way to go for heavier steel. I used one when I was in my 20s in an auto repair biz and I don't think they're that hard to learn. Sure, wirefeed is easier but if you have an AD helmet and reasonable hand-eye coordination it's not rocket science. As long as you're ok with sound but butt-ugly welds you'll be fine.And you can buy the famous Lincoln tombstone welders on Craigslist for practically nothing all day long. HTH.
Wow more good info! I really want to get a new Millermatic with the Auto Set. I've never been one to have the patience to search for good used stuff or deal with the problems used stuff can have. Too often it seems to turn out, "There's a reason he sold it."
And yes I do still need an AD helmet. And gas bottle of course. Oh Santa ...?!?
My problem right now is figuring out where to weld. My 22x28 barn is full of my boat, & I have real options with that. My 2-car garage is full of a car & my truck.
So, good grief, it seems I need to add on to my barn just to weld!?! :confused2:
I guess I could weld in the driveway right outside my barn :( Maybe make 2 or 3 portable wind-blocker walls.
Question: I do have a 4x8 work table with a roof over it behind my barn. If I slapped a 4x8 piece of steel over the existing plywood work surface, being exposed to the elements, would that steel rust so quickly that it would be useless quickly? I guess I could get maybe a 3'x4' piece of steel & just lay it down out there only when using it? Bring it inside when not in use. I could use 4 bricks to set the steel up off the plywood. And if the worst happend & the whole thing burned down, not the absolute end of the world.
I also have much better access to be able to modify the electrical out there. (I have lites & outlets installed in the table now)
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
Mahindra 3550P (A60462)
Mahindra 3550P...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
