Power transfer switch for homes.
/ Power transfer switch for homes. #41
this is wrong
The ground and neutral has to be tied together at the service disconnect.
The service disconnect can be the main panel if it is the first place the main can be opened.
If there is a disconnect prior to the panel this that is were it has to be bonded.
From the bond point you have to run 4 wires. to the next device (assuming 120/240 single phase).
here is a picture
Ok. Thank you for straighenting that out. I have obviously misunderstood what I have been told by electricians I know.
What I don't understand is if a three pole disconned switch is used, say between the meter and the panel, how does that not fully and compleatly isolate the house from the incomming utility? Are we talking about current traveling through the earth, entering the house ground rods and thereby energizing the house neutral?
I'm confused :confused2:
/ Power transfer switch for homes. #43
Well, this is all very surprising to hear. I have never heard of connecting the neutral to the ground wire. Is this a Texas thing? Here we always separate them.
In MD - in MAIN panel the neutral bus is bonded to ground bus. In subpanels the neutral bus is separate from ground bus. I'm fairly certain this is a National Electrical Code thing...
Mike
/ Power transfer switch for homes. #44
This bonding of the neutral and ground makes no sense to me at all, and I've never seen it nor heard of it before. Will have to do some reading, but in the meantime, since the neutral and ground at our cottage setup with the standby generator are completely separate, am I safe in assuming there can be NO possibility of feedback to the utility and/or a linesman when my generator is running? (See my earlier post on this thread.)
/ Power transfer switch for homes. #45
Mike
Mike it is a code thing now previously you could run 3 wires and bond each sub panel but that changed quite a few years ago (it seems like yesterday).
tom
/ Power transfer switch for homes. #46
During the 2003 hurricane season, here in FL we lost power several times for a couple days at a time. Even though comforts like A/C, fridge, lights, & computer were out, I enjoyed the change, the piece & quiet, the time off from work, going out checking the damage, etc. We just accepted being warmer than usual, eating whole foods, sleeping when it's dark, no internet, etc. It worked out fine. It was not terrible. Gave us stories to tell.
I'm not sure I'll ever bother with a backup generator, but maybe that's the young whupper-snapper in me talkin'.
/ Power transfer switch for homes. #47
We lost power for about a week three years ago due to an ice storm and without our backup generator, we would have been out thousands of dollars on frozen pipes and other such things. We also don't have water without electricity and after a short time, well it gets pretty grim. In the summertime it is not too bad and on more than one occasion, I have "taken a shower" in my back yard when power was out due to thunderstorms, one of the advantages to living in the country.:thumbsup:
/ Power transfer switch for homes. #48
tsteahr:
"If you use a three pole switch you break the neutral along with the two hots and you are totally isolated (because the utility only consists of three conductors). As to the ground, in my area there is no utility ground. The ground is just that, a wire connected to copper rods driven into the ground outside the house. I used three ground rods although only two are required by code here. The genset ground is connected to the same ground as the main panel ground. All grounds in the house must be tied together. It would be against code to have multiple ground paths in my area."
You are correct, I had overlooked that as a possibility as it is very rare, although isolation of the "grounded conductor" or neutral is a requirement in only a few places. So assuming this switch is placed between the transformer and the service entrance appliance and that no grounding path exisits betwwen the cabinent of the transfer switch and the transformer, then it is possible to achieve isolation from the utility. The multiple ground I was referring to in my e-mail is a reference to the fact that in most cases (other than the one I just mentioned) the ground is bonded to the neutral. If the utlility neutral somehow gets energized, the ground is also energized, so isolation is not achieved in that case. By the way, in the case of a commercial emergency power backup, the genset often does carry its own ground, by code. However, you are also correct in that in most situations, not all, multiple grounds are a no-no.
As to the matter of bonding the neutral and the ground mentioned in several posts (not yours tsteahr), the 2008 NEC is crystal clear, the neutral and ground are bonded once within the service entrance applicance, in all subsequent panels they are to be isolated. Theoretically this provides a fully redundant fault path to ground. It is correct that in all subsequent subpanels the ground and the neutral (now called the "grounded conductor" in the NEC) are to be fully isolated from each other.
Few of the ATS devices discussed in this thread are triple pole to allow the neutral to be isolated from the utility. If for some reason the neutral from the utility becomes energized, so does the neutral throughout the circuit system, except that it should be driven to ground through the bond in the service disconnect panel. To be clear here, that event does not cause a potential harm to a lineman from someone running a generator. A fault that is not grounded through a proper neutral/ground bonding system however, could be a hazard to a lineman.
I recently installed a fully interlocked transfer switch in my house. Like many posts here I formerly back fed the panel through a 30 amp breaker and turned off the main breaker. I trust myself to do that correctly and not put anyone at risk. I used a special set of wires and recepticles to avoid any charged male prongs, not good. However, I am now travelling alot. Last two times I have been on the road we lost power. Wife did not know how to set up portable geenrator. So I have since cured that problem with a safe, foolproof, fully interlocked, up to code system so that when the power goes out she can fire up the gen set (I even bought a new one that is electirc start) and have power in the house. I have 11 circuits in total that can be operated from this subpanel either with utility power, or the genset. Works like a charm, as I had to use it three days last week when we lost our power. I have one more enhancement to add and that is an indicator light on the utility line to make it easy to tell if power is back on.
I wish I knew how much it actually costed me to install. Good heavens copper wire is nearly as valuable as gold. Cheaper by the spool, especially if you have future use for the surplus, which I do. But $235 for 500' of AWG 6/19 is just plain crazy!
This has been a really good thread and I hope information here encourages people to install safe gen transfer switches. I do not know about anyone else, but I could never forgive myself if I accidently eloctrocuted a lineman trying to restore power to my neighborhood.
/ Power transfer switch for homes. #49
Why is everyone concerned about "neutral" unbalance and power going back on the neutral to the grid and hurting someone ?? :confused: If someone has a transfer setup that breaks the incoming hot conductors there is no way power can go back onto the grid.. Think about for a minute... If a lineman were to lift the neutral on the transformer outside your house while you are running your generator there would be no load coming to him from your unbalanced load,, This unbalance exists only between your generator lines and your neutral in your panel..
/ Power transfer switch for homes. #50
The utility actually consist from four wires. The fourth is the ground. If the lineman is staying on the ground he could get electric shock from the neutral.
2022 Horizon Trailer (A55973)
2022 Horizon...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
