Power transfer switch for homes.
/ Power transfer switch for homes. #21
I have the same unit mrmicky has and it has worked out great. Where I live I
lose power a couple times a year and the year before last we lost it for two weeks. I don't remember the install cost because I was adding on a garage at the same time. I know it did not take the electrician very long to install.
I made a dog house for my generator attached to the back if the house. What I also had installed was battery emergency lights so when the power goes out at night I have a light on at the Generator, the cellar and one at the power panel so I'm not carring a light while starting the generator and switching over the power.
/ Power transfer switch for homes. #23
What did this 200 amp manual transfer switch cost installed?
I mounted the switch on the wall, installed the generator outlet and ran the wire and conduit from the generator outlet to the switch myself. The meter needed to be pulled (which requires a permit and informing the utility company) to complete the installation so I hired an electrician to do all the work with the heavy 0000 wire that goes from the meter to the switch and from the switch to the main breaker panel. That aluminum wire is difficult to get through conduit. I needed a longer run of wire coming from the meter box. This meant working in the meter box in close proximity to the live feeds coming from the utility pole. I was not comfortable working with the heavy wire and wrenches only inches from a nearly unlimited current source. One slip of the wrench and toast :shocked:.
In total I probably spent $1300-1400 for all the materials and 5 hours electrician labor. But time and material required will be different for every install. Mine was a little more involved that average because of switch placement issues. I probably saved 4 hours labor installing the generator plug, conduit, wire and mounting the switch myself.
/ Power transfer switch for homes. #24
We installed a 20K Seimens with SE rated automatic transfer switch. Power goes off, 30 seconds later unit starts and stabilizes. Transfer switches to generator in about 45 seconds after power loss. Transfer to grid power takes place when it returns, generator then runs in cool down mode and shuts down. All of this takes place automatically. The unit tests and exercises weekly. It runs on propane, and can run at full load for about 10 days on a 500 gal. tank. Before we had this unit installed, we experienced weather related power outages for a total of 16 days. Mostly ice storms in 07 and 08, and severe t-storms in May of 08. Installed the generator and transfer switch in late summer of 08. Our home is 1800 sf, total electric, heated with wood. To date it's run problem free, maintenance is simple. Highly recommend and happy with the quality. Only thing I'd do different is get a liquid cooled unit that runs at lower rpm. The transfer switch itself is a fairly straight forward installation. Installs between the meter base and main panel. It did require power company to come out and de-energize power at the transformer while installing, and re-energize at completion.
/ Power transfer switch for homes. #25
I guess I'm a little old school. I looked at those interlock plates that you screw onto your breaker panel cover plate and then backfeed the panel through a 220 breaker. I know they meet Code in most areas. I also talked to three different electricians about those plates. The two younger ones said they work great and I'd be foolish to waste my money on a proper whole house transfer switch. The older, more experienced electrician (a personal friend who has retired) agreed they meet Code, but he would never install one. He has seen too many things happen to trust isolation to a breaker in the panel. There is no way to know what can happen to the utility system during a severe storm. Utility lines can get shorted, voltage can go way high momentarily (say a transformer switchyard has a problem) or the neutral leg can get energized.
In other words, things can happen outside the home that a 220 breaker mounted in the panel is not designed to handle. A interlock plate is designed to protect the utility lineman working to restore power. It is not designed to protect your house.
I believe a separate transfer switch panel provides superior isolation between the house and the utility. Throw that switch and I don't care what happens with the utility lines. I'm isolated.
So I did it the old fashioned way, 200 amp manual transfer switch. People have told me I wasted my money. I'm ok with that.
Total Isolation is a bit more complicated than that. I think you will find there remains an electrical path through the grounding system and likely the neutral, in your transfer switch. Don't get me wrong, it is a nice set up, but the only way to develop total isloation is completely separated circuits. The aux. or generator circuits would only operate off the gen set and have totally separate wiring including a different ground. This is the only way to be completely isolated from the utility.
/ Power transfer switch for homes. #26
Amazing how folks just love to spend money cause they don't have a clue. Barnum & Bailey said it best.
Notice the schematic from the site for Generator Interlock that Tommu56 posted ........... looks almost exactly as I described.
That's how I do it. I'm sure it's not the best way but it works fine for me and no laws here saying you can't. I do have an inductive light on the feed coming in from the line so I know when the power has been restored.
With three different buildings to feed power to and a meter that's 300 yards from the house if I wanted to use a transfer switch I would need to make a pad and install a standby genset.
/ Power transfer switch for homes. #27
I paid an electrician $400 to put mine in. I have used the back feed and my brothers still do, but it made me too uncomfortable.
/ Power transfer switch for homes. #28
Electrically speaking, they are exactly the same. Some differences though:
1. The interlock kit prevents both utility and generator mains from being closed.
2. The power inlet eliminates the double-male plug which is used in traditional backfeeding.
I have seen the automatic transfer switches for whole house generators. There is nothing fancy about them, they just re-route the source of power through the main breaker. Smaller manual units also come in various flavors. I currently use a SquareD lug sub panel with two double-pole branch breakers as mains. One is utility main and the other is genny main. There is an interlock kit to prevent both being closed at the same time.
/ Power transfer switch for homes. #29
At the cottage, we have a 17 KW Kohler propane-powered standby generator with an automatic transfer switch. It wasn't cheap, but we get power outages up there all the time (2.5 hours North of Toronto), and we needed a lot of standby power for the outdoor hot tub which we run all winter. Since we are only there intermittently, we needed an automatic standby switch so the generator comes on automatically (it does so within 10 seconds) when the power goes out, and shuts off again when main power is restored.
We avoided having to disconnect the meter during installation by (a) taking all the circuit breakers out of our main panel, (b) installing a single, 100-amp breaker, (c) running a cable out from that breaker to the automatic transfer switch, which then runs out to a brand new panel that we bought, and then (d) putting all the old breakers into the new panel. Note that for this procedure you only need to use a non "service entrance" transfer switch for the standby generator (it is cheaper anyways), which can just be mounted on the wall at a convenient location close to the other panels.
We also left our previous portable generator sub-panel in place (which was just a 60-amp sub-panel with a safety isolator plate and a few critical breakers in it), just in case we wanted to use our portable generator some time (e.g., if power went out in the summer when we were at the cottage and could control everything manually). The reason for this idea was that the big 17 KW propane standby generator uses a LOT of propane, at a cost of about $80-$100 per day. Our portable 5500 W gasoline powered generator, on the other hand, uses regular gasoline at a much cheaper rate.
So, we have the best of both worlds, and safety, too. (I hadn't realized, however, that, as cycle_gator pointed out, you can still get power feeding through your ground and neutral with the little generator sub-panel! Is there a way of perhaps isolating this little panel by running a separate ground wire out of it to a separate grounding rod, and then disconnecting the ground that comes from the main panel? I guess you would have to disconnect the metal conduit between the main panel and the small generator sub-panel, since it also acts as a ground, but then what? Use PVC conduit? But isn't that illegal for interior applications?:confused:)
/ Power transfer switch for homes. #30
Sub panels should have their ground and neutral isolated. In other words, the ground and netural should not be bonded in the sub panel. This prevents current from flowing on the ground between the sub and main panel in normal operation (no fault conditions).
In a case where a generator is connected to a properly installed sub panel, the neutral and ground in the generator should not be bonded. In other words, they should be isolated just like in the sub panel. (Some portable generators have their neutral and ground bonded because they were not originally intended to connect to a house.)
The generator's grounding to earth is achieved by the ground rod connected to the main panel.
If everything is wired correctly, there will be no current backfeeding to the utility -- neutral or otherwise. Regular two-pole breakers that disconnect the "hots" will achieve isolation.
/ Power transfer switch for homes. #31
I have one that runs my 20 KW Briggs and Stratton Generator.
It is installed between the meter and the main breaker box in the house.
When the power goes off, 30 seconds later it switches over automatically, eliminating back feed to the line and the generator fires up.
Once it senses power has been re-established it allows the generator to run 15 minutes to verify line power is stable then it switches over to line power killing the generator.
/ Power transfer switch for homes. #32
If you use a three pole switch you break the neutral along with the two hots and you are totally isolated (because the utility only consists of three conductors). As to the ground, in my area there is no utility ground. The ground is just that, a wire connected to copper rods driven into the ground outside the house. I used three ground rods although only two are required by code here. The genset ground is connected to the same ground as the main panel ground. All grounds in the house must be tied together. It would be against code to have multiple ground paths in my area.
A three pole switch does nothing to help with lightning strikes that travel through the earth, from say a nearby strike. But a three pole switch will fully isolate you from the utility, at least in my area where the incoming utility consists of three conductors, two hots and a neutral.
Unless I'm not understanding your point about the grounds...
EDIT: I did not read rkjobbeman's reply before I typed this. He said it much better than I...:thumbsup:
/ Power transfer switch for homes. #33
A lot of utility companies won't allow you to install the above product. The most commonly items I've seen used come from the following company. There are a variety of options to pick from, and many are sold on eBay.
Reliance Controls Corporation The World's Leading Manufacturer of Transfer Switches for Portable Generators
Big issue with them is you have to decide what you want to run. Also they only handle x amps. What happens if you later get a 200 amp generator?
I just have a 200 amp transfer switch between the panel and the meter. Right next to it is a large 50 amp 4 prong twist lock plug.
Chris
/ Power transfer switch for homes. #34
We did this for about $400. My neighbor is a electrician and I got the switch, Cuttler Hammer, for $300 on sale back then and a 20% off coupon.
200 Amp Generator Manual Transfer Switch
The rest I got at Lowes, some wire, a box, plug, ect.
I do not like the idea of only have 6 circuits energized like some of the small panels do. I have been out of power 8 days at a time and a few 4 day stints and the last thing you want is not having what you need.
By the way I have a Troy Built 8550 Watt Genny and it will run 24 hours on 9 gallons of gas. I keep 3 days fuel on hand and use my 100 gallon boat tank as a backup. Learned that the hard way when I had to drive 100 miles for fuel.
Chris
/ Power transfer switch for homes. #35
Chris
Good Deal! I agree it's nice to be able to pick and choose whatever circuits you want to be energized. I spent more than $400 just on wire and an outlet. 100' of 6 gage (or was it 4?) and another 50' of 0000. I think the 20' drop cord from the generator to the outlet was over $100... Oh Well, whenever I get into electrical it costs me a bundle.
Not that I think about it, when ever I get into anything it costs me a bundle :confused2:
/ Power transfer switch for homes. #36
QUOTE=tsteahr;2165948]If you use a three pole switch you break the neutral along with the two hots and you are totally isolated (because the utility only consists of three conductors). As to the ground, in my area there is no utility ground. The ground is just that, a wire connected to copper rods driven into the ground outside the house. I used three ground rods although only two are required by code here. The genset ground is connected to the same ground as the main panel ground. All grounds in the house must be tied together. It would be against code to have multiple ground paths in my area
There should be a utility ground at each power pole (distribution). This provides a ground grid for the entire system. Not quite sure how your's is set up, but if you connect to the same ground as your main panel which is in turn connected to the incoming ground/neutral from the power co. then you are still connected to their ground.
My incoming line run to a 200A main disconnect then to a 200A transfer switch. The ground/neutral from the meter is connected to a ground rod on the "incomer" side of the transfer switch. There is also a ground rod connection on the generator side of the transfer switch. This totally isolates the load and generator from the power co. system.
/ Power transfer switch for homes. #37
We have 2000 watt Winco belt driven generator mounted to the front on our JD110 garden tractor. It's sole purpose it run the furnace (oil/hot water) in the case of a power outage. We ran a 110 volt dedicated line to a three position toggle switch and then to the furnace. I have a volt meter hooked up to adjust the engine/belt pto speed to around 125 VAC. The 3 position switch is left side Electric Company, middle position is 'no power' and the right side is marked John Deere. Having the middle position 'dead' avoids any possibiliy of feedback.
/ Power transfer switch for homes. #38
Interesting. Around here the neutral is separate from the ground. All the neutrals are electrically separated from the ground. The wood utility poles do not have ground wires. The high tension metal towers are grounded, but that is for emf drain, not part of the electrical circuit. Since there is no ground provided by the utility, the main panel ties all the grounds from the house together and leads them to the ground rods. No current should be carried by the ground (unless something is wrong). It would be against the code here to tie the ground to the neutral. I'm not sure what would happen if you tried, but I don't want to find out. I'm thinking GFCIs would probably trip, since they compare hot to neutral current. I'm thinking if they were tied, some current could flow to the house ground rods, depending on the absolute potential of the local ground compared to the absolute potential of the neutral. I don't think the code wants current in the ground wire, and that's why they are electrically separated.
I'm not sure if around here the neutral is always at exactly ground potential. The neutral may "float" a bit. I also have this vague idea that the absolute potential of ground can vary from place to place as well. This was a reason for the floating neutral, to maintain a consistent balance point between the two hot legs. Even if the absolute potential of the hot legs varies, so long as the difference between the two remains 220 and the neutral is in the middle, all is well. This way the utility does not need to reference everything off the ground. They can control their neutral reference. For example, that way one hot leg could be +122, the other could be -118 and neutral be at +2 all relative to the local ground. 100 miles away the neutral could be at +1 relative to local ground, but that does not matter since having the neutral separate from ground creates a "closed" system for the utility. But electrical is not my thing so I'm really out of my realm, and I don't know if that's true.
/ Power transfer switch for homes. #39
Agree there should be no current in the ground conductor within a building or residence.
Generally, the ground and neutral conductors are only connected at the primary main panel, which is where the connection to earth ground (grounding rod) is also made. From there on out, including sub-panels no connection between the two should exist.
I'm not a lineman. but all our power line poles have grounds as well. The lines down my road consist of three 12,470V lines and one neutral line. Each transformer on the pole connects between a phase line and the neutral on the primary side. The secondary is the 240v with middle tapped ground also connected to the system ground/neutral.
The three (240V line to line, 120V to ground) provide service to the house.
Assuming loads are equally balanced, there would be no current on the neutral back to the system. But if you were drawing 50A on one line and 45A on the other the remaining imbalance (5A) would be returned to the system on the neutral.
/ Power transfer switch for homes. #40
this is wrong
The ground and neutral has to be tied together at the service disconnect.
The service disconnect can be the main panel if it is the first place the main can be opened.
If there is a disconnect prior to the panel this that is were it has to be bonded.
From the bond point you have to run 4 wires. to the next device (assuming 120/240 single phase).
here is a picture
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
10' Container w/ Side Door (Damaged) (A60463)
10' Container w/...
