help with saw purchase.
/ help with saw purchase. #41
Checked the oiler today and it is working fine. Must have been that the chain was to tight??
Possibly. New chains get loose real fast however. When you said it was smoking, I thought you meant the exhaust.Tug on the chain when the saw is cold. You should meet with some resistance but the chain should come along. If the chain won't move, its too tight in my mind. I did know guys who adjusted new sawchain until the chain wouldn't move by hand. Their thought process was that the chain was going to get loose soon anyway so it was one less chain adjustment to make. (In my mind was a good way to hasten clutch burnout) They always poured bar oil all over their bars before starting however.
/ help with saw purchase. #42
3rdgenorange.
Hope the 372 works out well for you, but as others have mentioned - you'll probably buy it a baby brother before long LOL.
Got use the saw again and this time no smoking bar. The ony thing I can figure is that the chain was to tight. This saw is an animal, was cutting through oak like it was butter.
om21braz: it already has a little brother, a 240e, but i did have the 240e first so would that mean it is the 372's older but smaller brother?
/ help with saw purchase. #45
Have you got that 372 broken in yet? It should really start to run good around ten tanks of fuel.
/ help with saw purchase. #46
3rdgenorange -
I thought I would ask how your 372 is working for you? My older brother has the itch to buy a new saw for cutting wood. We are a Stihl family, but he is looking at other brands. I have an older MS 026 (now called MS 260) and a MS 310. My brother has a MS 310 also. We cut a lot of wood every year (20 - 30 cord) to heat 2 homes. The MS 310 is great for sawing up trees into the proper length and it works great for felling small to medium+ trees.
I hope you have enjoyed using the new saw.
/ help with saw purchase. #47
I have the Stihl MS 361 witch has been replaced by the MS 362. that with a 20" bar will do about anything you want, and it will take up to a 25" bar.
Can't go wrong with a Stihl.
/ help with saw purchase. #48
Or save yourself a bunch of money and get a CS600p off Ebay for just over $400, every bit as good as a Stihl 361 or 362. Steve
Still have not used it to much. Probably 4 tank fulls. Had most of the wood already cut. So far I really like the saw, little on the heavy side. Plenty of power and well balanced. Will hopefully get to use it more in a couple of months
Been using the saw more here lately. Recent storm brought down some trees. The more I use the saw the more I like it. It seems to be getting more power (must be breaking in). Overall no regrets on the purchase.
/ help with saw purchase. #51
I've been following this thread, sort of lurking like...because I am in a similar situation looking for a new Husqvarna to either augment or replace my trusty Husqy 257 (with 16"bar). I originally was thinking I would go a bit bigger, maybe a 357XP and get rid of my 257 but that thought made me sad! The 257 has been like a perfect mate, no complaints I have just gotten to the point I feel proficiant enough and flush enough to get something with more power. I don't make my living cutting but 20 or more cords a year plus lots of wind damage on my acreage, especially this year! Now it looks like the only perfect solution is keep my 257 for limbing and overhead work (I know, I know don't tell OSHA) and get the 372XP with a 20" bar for serious wood production. My local guy says the 20" balances the saw nicely...The jump in wgt is signifigant but the trade off seems well worth it. The one thing I did like at the shop was the 357XP was not "Green" which usually means it has not been nuetered in the same way as the "New" 372XP. So, do any of you more expert than me guys think my thinking is faulty?? Learned alot reading here, as usual! Rod
/ help with saw purchase. #52
I would have to put in a vote for the 372. 20" bar is good untill you get into the big stuff. Saw will pull a 20" chain with ease
/ help with saw purchase. #54
rodfatherjr:
I've got both the 357xp & the 372xp, if you already have the 257 I would skip over the 357, you'll be glad you did; especially in 16" & larger wood. The 372 handles great with a 20" bar and I believe it will take up to a 28" if I recall. If you look around you should be able to find the "old style" 372 (non-strato/non x-torque), I haven't tried the new style 372, but it looks like it has a piston/cylinder set-up similar to the K750 cut-off saw I have.
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
iDrive TDS-2010H...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
