help with saw purchase.
/ help with saw purchase. #21
Pulled the plug tonight. I went to the local Husky dealer and they had a 372 XP for 670.00. So I bought the last one they had. Looking forward to doing some cutting.
Keep the chain sharp, clean her often, do your bar maintenance and you will have it for decades.:thumbsup: I've had my 266 for 30+ years and still cutting!
/ help with saw purchase. #22
That is a great price! Good advice for magicheater, also make sure you always use the proper fuel mix and whatever you do don't use old mix. Let us know what you think after you run it for the first time.
/ help with saw purchase. #23
Very desirable saw at a good price! You wil love it, give some feedback after you use it awhile.
The weather will not cooperate. Has been raining cannot get out to cut wood
/ help with saw purchase. #25
Excellent price on a great saw. I'm still getting used to hearing the higher rpm of the Husky vs. the Stihl though. Kinda like lawnmowers, there just is'nt one saw for everything - good reason to buy at least two LOL.
/ help with saw purchase. #26
Wow, you should be using the saw to build an ark by now if its's still raining that is (ok, maybe you're on your second ark as fast as that saw cuts). We're still waiting to get a review. Of course if you're ready to throw the saw away, just throw it my way!
So it dried out last week but then the tempatures soared up into the high 80's and low 90's. Hoping to be able to get out soon to try it out. The anticipation is starting to get to me.
/ help with saw purchase. #28
Just saw this post and know you already bought. I would have asked if you were processing the entire tree yourself or cutting from stems delivered. I've used just about every type of saw and the poster who mentioned how quickly one can become a chainsaw junkie is absolutely correct. At least I had the excuse of it being my profession but that would be only an excuse because I love the little beasts. If you were processing the entire tree to start off with, and since you are in the Husky family, I would have recommended the 357 with 18" bar as an all arounder. Your arms will adjust to the weight of the 372 and the 20" bar will act as a counter weight. Of course your age and vitality would have also been a criteria. If you're a youngin (below 45) you'll do fine with the 372.
/ help with saw purchase. #29
For me the best power per weight is the MS260. I have always bought Stihl weed eaters and chainsaws. And I have never bought anything less than their "Pro" series.
/ help with saw purchase. #30
The OP said in the very first post that the saw was going to be for cutting 15-20 cords per year, I think the 357xp is a great saw but for the difference in price & power to weight ratio I think the 372 is a better option for the amount of cutting. The difference in weight is only about 1 to 1.5lbs, and you are gaining a whole horsepower which means you won't be using the weight as long! The MS260 while a good little saw, is way too small for 15-20 cords a year while making decent time doing it.
/ help with saw purchase. #31
I feel there are many considerations than just the amount of wood cut. For years I used both a 262 and a 257 when at the landing. This was producing 4 to 5 cords per day. Not knowing the age or physical and athletic status of the op, nor if he were processing the entire tree or his experience, I felt the 357 may have been applicable. Climbing over limbs and such, a couple more pounds at the end of the day could get dangerous. There is the added weight of the 372 also as a result of more fuel capacity that after 5 or 6 hours of cutting may be an issue. The poster did not tell us much other that the wood production so not knowing many variables , made me suggest the 357 which would handle what he is doing quite nicely. As I stated, people get used to saw weights but I did not know many critical things hence my overall suggestion.
/ help with saw purchase. #32
....... This was producing 4 to 5 cords per day.......Climbing over limbs and such, a couple more pounds at the end of the day could get dangerous. There is the added weight of the 372 also as a result of more fuel capacity that after 5 or 6 hours of cutting may be an issue. The poster did not tell us much other that the wood production so not knowing many variables , made me suggest the 357 which would handle what he is doing quite nicely. As I stated, people get used to saw weights but I did not know many critical things hence my overall suggestion.
I could not produce 4-5 cords of wood per day processing a whole tree or by just cutting from a pile already stacked in 20-30' lengths; that is if you are talking about wood ready to be burned. By the time one or two people cut, carry, split, and stack wood that is being cut in a day's time, 4-5 cords is a real stretch unless of course you also own a wood processor set up with conveyor etc. Now if you're only talking about cutting up rounds to make 4-5 cords in a day, I agree it's possible, but to get what I consider "firewood" cords, I would have to sit back & watch
As far as for throwing in the limbing & processing: from cutting the tree down, limbing, rounding, splitting, moving & stacking, 4-5 cords........:confused: I do know for the limbing I would have recommended the 346xp, not the 372xp, but for production, for me anyway, it's the 372xp.
Some of the guys that cut with me are 65yrs old and all they say when using the 372 is that it is a pleasure to cut with; not full time cutters, just trying to stay warm and help each other out.
As I said, there's nothing wrong with the 357 (or the 262 and the 257 you mention, both close to the same hp family with the 357; 262 a bit more, 257 a bit less), I have one of those too. If I were to have to use only two saws it would most definately be the 372xp & the 346xp for saws of today. For quick cutting of firewood though give me the 372 any day!
Oh, and a few things to make gathering a bit easier:
/ help with saw purchase. #33
My reference was toward the 357 being an all around saw and being able to hold up to the tune of 15-20 cords per year. My suggestion was based on not knowing critical points of the op and him buying one chainsaw. As far as producing the amount of wood I stated, it was indeed firewood. Skidder would drag up stems. Stems were sectioned to 18". Wood was split on a traditional splitter and belted to a stake panel holding 2 -2/12 cord. We would do that twice in one day ( don't get me wrong, we had all the saws and bigger stuff would warrant larger saws for bucking. Another factor as to the saws we would use was which saws were working.) No stacking or leg work. My point being that these smaller saws held up for that kind of production. No wood cutter can make do with one chainsaw. Even if the op needed experience, the 357 would have made a good first saw and then a good limbing saw if he found he needed more hp of the 372. (My saw of choice after the 357 would have been the 385) but I do agree that the 346 and 372 make for a very nice two saw combo and would be all the saws a home ownwer would need for 10 or more cords and for under that, I'd go for the 357 with a 16" and 20" bar for the one all around saw or a saw to gain experience on.
/ help with saw purchase. #34
now that you have it never loan it. never loan out your chain saw, boat, tractor, or wife: all could come back with a rod slung in them.:(
/ help with saw purchase. #35
Talking to local dealer, who sells Stihl and Husqy, he says the Husqy revs faster and you should always use Husqy oil in the mix as it is better than the Stihl oil at such high revs. I am not sure if it is true, just passing it on to OP now he has jumped!
I also agree with all those who say go two saws - I started with an 038 (semi pro) and inherited an 025 (domestic). The lighter weight means I use the 025 95% of the time now.
Finally, again for those reading these posts in the future seeking advice, if you are in a colder climate you may like to see what winterisation options are available. My 038 came with various shrouds and plugs, the 025 came with nothing. A warm handle might even appeal.
J
Finally got to use the 372 tonight. 1st impressions. The thing will definetly throw chips of wood. Seems to have good power. It did seem to smoke some but maybe this is because of it not being broke in?? I noticed the bar seemed to get really warm even with the oiler turned all the way up. At times seemed to cut diagonal which I am guessing is the chain??
/ help with saw purchase. #37
Yes but after 3-5 tanks it should stop. Pay close attention to your oil mix ratio. 2. Run the saw with the tip pointed at and near a surface. You should get oil splatter on that surface if oiling properly. 3. Diagonal cuts happen for several reasons. Most frequent is the blade has nicked the ground w/o you knowing. Examine the chain cutters. if nothing seems noticable,I would try giving the saw to someone else to eliminate a technique you may be bringing to the saw. This is a heavier saw than your last and you may be over compensating in a direction to cause an angle cut. Another predominate reason is that the blade and chain are not matching gauges. The proprietor of the store could have made a mistake when putting saw together. The saw is new so I doubt it is a wear problem of either chain top plate angles,depth gauge heights or bar and chain rails. If you resolve that it is not a cutting technique problem nor a gauge mismatch problem, examine the chain for nicks. If none are found, file only the cutters opposite the direction of the veer. (If saw is veering right, sharpen the left cutters only or vice versa) and see if that doesn't straighten out the problem.
Now I'll explain a far out problem I once witnessed. A coworker was using a chainsaw that was cutting to the right. The chainsaw was new. He'd cut to the right. I picked up the saw and it would cut to the left. To make a long story short, we resolved the fact that the bar was getting no oil. His cutting technique leaned in a direction causing more friction on one side of the unoiled rail, mine had the opposite effect. The conclusion was that a bar with no oil, could cause sufficient friction on a larger saw to actually pull the saw to one side or another depending on the user technique. It was the only time I saw this as a logger in the 30 years in the profession and for that matter in the 20 years out of the profession but still cutting wood and owning and selling a mess of chainsaws. It is possible but I think unlikely this would be relevant to your situation. Check the above stuff in the first paragraph and I think you'll solve the problem.
Is it possible for the chain to be to tight and would this cause the bar to smoke?
/ help with saw purchase. #39
The dealer where you purchased the saw should have run the saw in for you; this would mean they should have set the RPMs by using a Tach, and verified the saw was oiling properly, chain adjusted properly etc. Most dealers set the saws about 500 RPMs below what the saw will ultimately be set to once break-in is complete; the ones around here will also adjust the RPMs to spec free of charge after a few tanks of fuel have been run through the saw. Make sure you are adjusting the oiler in the right direction and if your problems continue, return to the place of purchase and have the dealer make it right; you have a 2 year warranty, let them make it right!
Checked the oiler today and it is working fine. Must have been that the chain was to tight??
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Bush Hog 13414 (A64126)
Bush Hog 13414...
2024 JCB 35Z (A60462)
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
