Bottom Plow
/ Bottom Plow #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have concluded that I need either a bottom plow or a tiller to do a better job with food plots. I have good heavy duty Howse 66" Disc but it cannot break through the pasture areas of heavy bermuda and fescue grass.
The price of a tiller, and the thought of moving parts, and the relatively small usage, has led me away from that option. I possibly could be swayed, however.
The idea of a bottom plow to initially turn the soil is appealing. If I go this option what would you recommend for a Kioti CK30 gear? What should I look for? What should I avoid?
/ Bottom Plow #2
I'd suggest a one-bottom plow that the Kioti should be able to handle easily. Either 14 or 16" bottom.
A 2 bottom with 14" plows would possibly work as well.
I agree that your thought of a moldboard plow followed by your Hose disc will work up your planting ground nicely.
I picked up a 60" tiller for $500 and it has been working great for my food plots. I wish the deer liked the "food" better than they apparently do at this time. Three different clovers that came up nicely, but don't seem to interest the deer.
/ Bottom Plow #3
A tiller is not going to break thru sod....need to plow first....even and inexpensive single bottom(Tractor supply ($130.00) some-times called a potatoe plow....THEN TILL with roto-tiller.I do 10 acres a year;works for me.
I have found on small tractors a tiller does a lot better than discs.One pass on plowed ground with a tiller.....4 with a disc.
/ Bottom Plow #4
Either of these plows should workout nicely on that tractor. Both are set up as 2-12 auto trip beams. $495 choice. One is a John Deere and the other is a Oliver. Ken Sweet
/ Bottom Plow #5
I disagree and currently have the garden to prove it. Go slow, adjust the depth on multiple passes, eventually till to full depth. have done this hundreds of times, multiple locations. I put in gardens for friends and family everywhere I have ever lived and have always followed the same process. I have never had my areas plowed before tilling. I've been tilling gardens since I was a kid, and we always did it the same way everytime. Now, for a very large area over several acres, this system will still work but would not be advisable unless you are retired and have nothing better to do. Then I would suggest following nybirdman's advice. I would say an acre or two isn't too large to do my way.
Another idea may be to use the scarifiers on a box blade prior to tilling. IF you have the BB it might save a couple of dollars. I don't know about you, but I don't have a money tree in my backyard.
/ Bottom Plow #6
When I plow, I plow about 8-10 inches deep. Will a tiller work that deep? Ken Sweet
/ Bottom Plow #7
If you have the right tiller and a big enough machine to use it. :laughing:
Probably not going to work for this guy though. :(
/ Bottom Plow #9
not 10 and likely not 8 depending on tiller/angle of tiller. When I till, my soil is like powder when done and I love it. I do a lot of mound planting, so when I mound I have about a foot+ of powder soil I am planting in. I know a plow isn't doing that. IF your good you flip your soil all the way over with a plow, if your not good you ran a hunk of metal 8-10 inches into the ground. at the end of the harvest season, my tiller will outwork any plow for putting under all those plants and reject vegies (in a small area). As they say, economy of scale and all that.
Don't get me wrong, I am not against plows by any means. I am actually still looking for an el cheapo 2 or 3 bottom (remove the third) so that in about another 8 years or so I can bust up the hardpan from the tiller. Until then I am fine.
/ Bottom Plow #10
A Subsoiler would also breakup the hard pan. Ken Sweet
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
(INOP) HYSTER E120XN BEAY DUTY 4 WHEEL FORKLIFT (A59823)
(INOP) HYSTER...
2461 (A58376)
2461 (A58376)
2014 FREIGHTLINER  CASCADIA (A60736)
2014 FREIGHTLINER...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
