Front Axle Pumpkin Vent
/ Front Axle Pumpkin Vent #41
That's why I have a pnumatic grease gun.
That's a good solution.
I don't have "bearing buddies" on my trailer, but I am very careful about
never driving in water that can get into the wheel bearings. In the old
days, I would drive my 4x4 PU through rivers in the desert, but also
knew that I had to repack the hubs when I got home....about 8-oz of
grease in each front hub.
Sorry for the delay. Didn't know I'd be partying all night. :D
An interesting development in the axle pivot bushings......
I started drilling the pivot and was expecting it to get real painful real quick when all of a sudden I had a hole all the way through. And it took less than twenty seconds. Hmm, strange. Then I noticed this grey-ish dust. Hmm, stranger still.
See if you can figure it out from the pictures before reading the next post.
The bushing isn't hardened steel at all!!!! Must be carbon fiber or kevlar! Didn't see that coming... did you?
So how come I couldn't tell before? You can see the petrified grease I removed with every swipe of the towel for ten to twelve swipes per bushing. There was no sign of the fiber pattern until the muck was gone.
You can also see the burrs lefts by drilling. I used my el cheapo $5.99 HF rotary tool to clean it up and chamfer the hole. (I finally found something this thing is actually capable of doing without bogging down under mild pressure.)
At this point I was debating whether or not I even wanted to add a grease fitting to the other pivot. But in the end my thought process went like this: I don't know how fiber bushings wear in comparison to steel ones, Deere greased it from the factory, Deere added seals intending for the grease to stay there, and it would still be easier to grease via a fitting then the alternative.
The pictures are of the installed fittings. They came out very well, I think.
[And yes, that is an orange tractor bucket there. Had to use the neighbor's tractor to carry all the stuff to his shop and back. Wowsers.... the fit, finish, NHV, and ergonomics are terrible in comparison to my 4200.]
/ Front Axle Pumpkin Vent #45
Looks good!
I'd like to see the Deere parts exploded view. Are those fiber bushing replaceable?
Rob
Rob, the parts breakdown is the PDF on page two. I'll have to investigate whether the bushings are inside the pivots or on the axle housing. I'm guessing its the pivots as they look replaceable (middle picture in post #44). I'll clean the axle in the next day or two and know for sure.
/ Front Axle Pumpkin Vent #47
First lesson learned: no way is the power steering cylinder not going to move while removing the axle with the wheels still on. I'm thinking there is no way not to move it no matter how you get the ends off. The fluid shot out like out of a cannon. Its wasn't under much pressure but it did a good job drenching most of the underside of the tractor. Sigh. Good thing I have plenty of kitty litter. Next time... drain the steering cylinder before removing the axle.
Also some pictures of the wife holding the removed axle and the tractor ready for narrow row crop duty.
I aways plug/cap lines, hoses, fittings, etc. Mainly to keep dirt out, but also the fluid in.
Time for some updates....
I cleaned out the axle housing and applied Ultra Black RTV to the pumpkin mating surface. Gotta make sure the side bolt holes get RTV all around as they penetrate the housing (unlike the top and bottom holes which are enclosed).
Cleaned the pumpkin mating surface really well too. Again, you can see how nice the gear wear pattern is.
Next I installed the rear axle pivot bracket. I lubed it well. I lubed the axle housing pivots well too. You can see the new seal too. Its also well lubed. Theres a running theme here. :D
I installed the rear bracket on two bolts only. I tilted it down some and pushed the axle into it. Then titled everything back up and positioned the front axle pivot bracket in place. Positioned is putting it kindly. I had to gently sledge hammer the bracket to make it squeeze between the frame rails.
The pivot adjusting bolt must be removed for installation. Otherwise you're compressing air and the bracket won't fully seat on the axle housing pivot. You can see the excess grease getting pushed out. You can see the sledge hammer marks too. And you can see how nicely the installation of the grease zerks came out.
There is no torque spec for the axle pivot bracket bolts. I should have searched better as there are 22 of these bolts installed on the frame. I'm sure the rest have torque specs. So I stupidly chose 215 ft-lbs based on the stronger bolts holding the spindle housing to the axle housing. Unrelated parts, unrelated bolts, unrelated problem created.
The first one torqued to 215 ft-lbs. The second one was taking an awful long time to get there. As I was thinking, "wow this is taking way too long," the bolt snapped in half.
Turning it out with a screw extractor wasn't working well because of the Loctite but it was slowly coming out. My neighbor wanted me to try his "new style" extractors. So I did. Those didn't have any elasticity at all and wham, a little too much torque and it broke off in the hole. So out came the axle pivot. Grrr.
I cut a slit in the bolt and welded a flat-head screwdriver bit into the slit. Then I ratcheted out the broken bolt.
Those bolts happen to be $4.57 each at Deere. At least they stock them. I chose 120 ft-lbs as the new torque spec. No problem there.
Lesson learned: Black & Decker isn't better quality than Harbor Freight.
Back to actual assembly. Again, RTV on the spindle housing mounting surface. You can see it getting squeezed out.
And RTV one more time on the steering cylinder mounting surfaces. These bolt holes go right through the axle housing so they need sealant all the way around.
Normally I would use Loctite on these bolts but I've found that RTV works really well as a blue Loctite (as in, is prevents bolts from loosening due to vibration).
Some random pics. I liked dfkrug's pic of the fill plug inside the axle so much I took my own. I'm still shocked by how much fluid goes inside this axle. Still, as we learned from Sam Marsh... you'd better keep the fluid in there or you will destroy the portal gears.
Next a pic of the new square end spindle housing drain plugs. Easier to destroy, but also easier to removed when destroyed.
And finally the cleaned up tie rod. My one tie rod was all messed up. The threads were hose-monkeyed and the nut was cross-threaded. It actually looked like it was cross-threaded twice in its life! I can only guess the problem was air tools from the previous owner. Which is why I don't use them for any installations.
I didn't take any pics but it took me two days to selectively grind away the bad threads without removing too much to make it entirely useless. Very painful.
I removed the tie-rod boot in the process of figuring out what was wrong. Very easy to remove. Near impossible to put back on. I do not recommend EVER removing this boot to anyone. I can pretty much guarantee I will be replacing this tie-rod in the near future thanks to there being a poor seal on the reinstalled boot which will push out all the grease every time I use the tractor.
I'll have pictures of the vent hose and it all sewn up shortly.
/ Front Axle Pumpkin Vent #53
Nice pivot zerks, ARRABIL!
I would have used a square-headed drain plug like you did, but I had
already bought a replacement. Yours is superior to the OEM socket-
headed plug because even if you hit it with a rock, you can still grab
it to remove it.
Now everyone....go out an check your axle pivots!
Thank you. I lifted the front end by the pumpkin and pumped some grease in today. Worked like a charm.
Thats no joke. With 1000 hours on mine, the pivots were just at the wrong end of shot. The fiber was fraying, the lube was gone, the seals were useless. Another couple hundred hours and it would have been loose and then the problems start at the driveshaft, the pinion shaft, the pinion bearings, the tie rods, etc. And who knows how much side force the driveshaft connection in the rear of the tractor can take.
For anyone who is concerned.... the seals tell the tale. Get a flashlight and some kind of poker that isn't sharp and see what the seals look like. One on each side, they'll be the rubber pieces closest to the axle housing. Post #49 has one good picture and (kind of) one installed picture of the rear side. If they're cracked or frayed all around, dry-rotted, missing, etc., I'd be concerned enough to do something about it. You can remove the axle pivot slack bolt at the front of the forward pivot to give yourself some room (but only if you lift the front off the ground so the axle can move freely). If you don't move the locking nut touching the pivot bracket, you can put it back exactly how you found it.
/ Front Axle Pumpkin Vent #55
Good grief, that's quite a project!
And another picture of the old girl ready for narrow row crop duty. I can't get over how silly she looks.
Reminds me of that TV deodorant commercial where the mountain biker has his front wheel come off, and he chases after it riding solely on the rear wheel. Or you could take it to the drag strip and do wheelie exhibitions.
I have one of these little torque charts that comes in handy for situations where the manufacturer didn't post a torque value in the shop manual.
McMaster-Carr
McMaster part number 90662A050
The axle pivot grease fittings aren't all that much work. The rest would go faster if I didn't spend half the time opening beer.
I like it! Probably need to supercharge the engine first though.
Yeah, they even have one in the Deere tech manual and about ten other manuals I got in the garage. I thought about it but wound up over-thinking it.
/ Front Axle Pumpkin Vent #57
Nice job Arrabil, thanks for the pics.
Rob
And the final installation pictures....
/ Front Axle Pumpkin Vent #60
Looks good!
I noticed a couple things in your last photo.
Is that an add-on device to hold the FEL hoses (A in the photo)? I have
not seen one on any 4300, and it would come in handy.
B in the photo looks like your fuel overflow drain tube. I hope it is not
getting pinched between the valve cover and the intake hose....that's
what destroyed my engine.
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
