Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #961
leonz said:
The more I see of the bolted hangers the better I like the spring tensioned shakles on my lawn genie-
leonz:thumbsup:
Can you post a photo and measurements?
As noted a while ago, Alamo HD forged knives from flailmaster are exact duplicates of the Caroni B knives at half price but we are still stuck buying the ?metric clevis from Agrisupply at $6 each.
/ Let's talk flail mowers #962
Yes I can do that as soon as I get in front of it tommorow, if the weather has not taken a total dump in the turd hearse-raining and raining now and I only mowed four days ago. Thank goodness I got the trimming done on the five acres.
Would it bother you guys if I asked you to to support my dealer here by buying the shackles and parts -springs/washers nuts from them?
If thats something you are all interested in doing? They are great folks with a family farm with a parts and service business as well as farm supplies, small feed mill.
They accept master card and visa and ship ups when required.
leonz
FYI the smaller spring shackle has a nine sixteenth nut(Box end wrench size/spanner size) to lock it in place.
Oh and the larger grass and shredder knives have the same type of spring tension shackle and I will get those sizes too
/ Let's talk flail mowers #963
Just bought my first a few months back. I love it.
Ah, one of THE Worlds best kept secrets! once you own and use one
there isn't any return to the dark side of rotary mowers.
LOL, HeeHeeHee!
Snicker, LOL
Steve
87 pages about an implement?????! :confused2: :laughing:
/ Let's talk flail mowers #964
LOL, HeeHeeHee!
Snicker, LOL
Steve
My dad has one now that I've used. You're right, it's great!
Edit: I've since changed my settings & see "only" 25 pages :laughing:
/ Let's talk flail mowers #965
If any of you has a minute to yourselves could you measure and post the size of the knife hangers for the Caroni F rotor
weldment height
weldment length across the flat
space between weldments
distance from inside hood edge to the first hanger
whoopsie - I forgot to ask for the metric hanger hole diameter
metric measurement length is fine
thanks much
leon
/ Let's talk flail mowers #966
Flail mower saga continues
LOL, HeeHeeHee!
Snicker, LOL
Steve
You know whats even funnier steve? an Alamo salesman telling me towed motorised flailmowers are unsafe. I will not be buying any of the chinese flail
motorised mowers or the PTO flail mowers offered by Northerntool- no way No way in HE** would I allow those things on my property.
/ Let's talk flail mowers #968
I remember what he was blatting saying someone carrying a passenger on an ATV could fall off and go under the mower.
The statement rang hollow with me for sure.:thumbsup:
/ Let's talk flail mowers #969
Yes... I think he would have a better chance catching his tie in the office paper shredder while he bent over to pick up his winning lottery ticket...
/ Let's talk flail mowers #970
I've read most/ all of this thread over the past few months but can't remember if anyone has successfully changed out their Caroni TM1900's OEM knives for hammers?
If so, where did you get the materials (hammers, shackles, bolts, nuts, anything else)?
And, how did it work out?
I noticed in Land Pride's catalog their smaller/ lighter flails have knives, & only their biggest flail has hammers. This would seem to imply that high(er) HP is needed for hammers? (I have 40.5 HP total/ 31.5 PTO HP)
I'm not looking to cut anything larger than the OEM knives can cut, just looking for an even smoother lawn cut. It's pretty darn good as-is, but it would seem that hammers, with their horizontal blade, would cut more uniformly than the angled OEM knives.
/ Let's talk flail mowers #971
You mean cup knives I think and you need shackles
as they are shorter in total length.
Nothing short of a new (P) rotor and shackle hangers;
How fast is your engine speed while mowing?
Is the engine running at a high RPM to maintain a
very high rotor speed?
The rotor speed may surpass 100 MPH at 540 RPM
with no lugging.
Do you or overlap while mowing? you can reduce your
forward speed to get a finer cut.
Have you looked at the knives to see if they need to be
flipped if you have twin knife edges.
/ Let's talk flail mowers #972
Ah, OK, then has anybody successfully changed to those?
There are no hammers or cup knives that can be swapped onto the Caroni OEM rotor?
2550 RPM
Is the engine running at a high RPM to maintain a very high rotor speed?
I run the engine at 2550 RPM in order to achieve a PTO speed of 540 RPM, as instructed by my tractor's manual.
Do you or overlap while mowing? you can reduce your forward speed to get a finer cut.
I overlap by probably a foot or so just to be thorough, but I don't usually purposely mow the entire area twice. And I mow at a relatively slow speed, IMO. I don't know the actual speed but will check it next time.
Have you looked at the knives to see if they need to be flipped if you have twin knife edges.
The knives are new & look just fine. I just think the horizontal blade angle of cups or hammers, running level to the ground, makes more sense than the OEM knives running at an angle to the ground. It does a very good job as-is, I just think it would be even better with the cutting edges running parallel to the ground.
/ Let's talk flail mowers #973
flail mower saga continues
Not the F rotor unless you plan on a modified shackle sans connecting chain link that is long enough to pass through and swing and then still screw the lock link together.
Plus I dont know if the guage roller would raise the mower hood enough to allow it to work properly.
About the cup knives:
They may ding up bit faster and will wear a bit faster and thats the only issue with the cutting edge; but having enough lacing width for the knives and hangers will be an issue due to the cutting width possibly leaving stripes with an F rotor-whoopsie:laughing:
Dont forget the grass slicer knives are an airfoil and the Y part will be nearly flat if I remember the aerodynamics of the cutting surface, as the lower flat part at the bend becomes near level due the leading edge aerodynamics of the area of the cutting edge while educing its resistance and creating the wing and flat cut effect.
I think thats how it goes anyway as the individual knive blade is also resisting the air mass and air volume under the hood of the mower, until the leading cutting edge encounters the oncoming air pressure gradient created by the rotation speed of the rotor weldment and knives.
Thats the nice thing about the 3 inch tapered knives as they cut faster with less air resistance the suction the staggered rotor creates is huge-If i get ambitious I will see about borrowing an airflow meter and Hg. gauge.
leonz
/ Let's talk flail mowers #974
I posted the following in another thread: (see bottom of post for a review of todays mowing)
I recently bought a used 78" cut John Deere 25A flail mower for $500. I put all new finish cut blades (the ones that look like a ducks foot), hangers, clevis, etc on it. I also replaced both rotor bearings and one roller bearing. Painted it, and put on new decals. All told, I have around $900 (and about 20-30 hours) in it and looks like new again. Out of curiosity I priced a new one (it's still in production) on the JD website....$4700!
So how did it perform? I love this thing! It sounds like a giant vacuum cleaner (much quieter than our brush hog), the cut quality is amazing. In moderately tall grass it looks like it was mowed with a riding mower, but without any clumps or winrows. The cut quality in short grass looks pretty good, but not as clean as taller grass. I have not tried it out in some of the brushy areas, as I don't want to damage the new blades (yet).
The mower is used with a Kubota L3830 (38hp). Even in dense 12" grass going up a steep hill, my RPMs barely dropped.
For mowing large areas of dense grass and LIGHT brush, I can't think of anything better. This has been one of best purchases I've made.
Todays mowing:
Tall, thick field grasses - WOW, nice finish cut, much faster than the old 4' BH
Shorter (5"-8") "lawn" area - decent finish, just looks different than when I use the riding mower, obviously faster, ROPS trimmed a few trees for me.
Overgrown area with some small brush (less than 1" diam) - chewed everything to bits, mower sounds like a dryer filled with shot putt but didn't even slow down. Made me rather nervous about damaging those shiny new blades, but they looked fine afterwards.
6" log in tall weeds that I didn't see - this made HORRIBLE sounds, mower kept chewing away until I managed to collect my thoughts and kill the pto, change underwear, inspect mower for damage....none found.
Overall, I'm still very impressed. I will definitely reserve the brush cutting for the brush hog. For mowing tall unkept grassy areas...the flail mower will never get a days rest.
/ Let's talk flail mowers #975
Maybe look into these Ford 917 knives/blades.
170357d1278268119-lets-talk-flail-mowers-
/ Let's talk flail mowers #976
Noticed that from time to time there's questions regarding flail cut so as I mowed today I figured I'd post something of a before and after pic.
In the attached pic you can see where I was mowing today. It used to look like the area to the right outside the fence. Not too bad for former cane field turned pasture.
/ Let's talk flail mowers #977
"Dont forget the grass slicer knives are an airfoil and the Y part will be nearly flat if I remember the aerodynamics of the cutting surface, as the lower flat part at the bend becomes near level due the leading edge aerodynamics of the area of the cutting edge while educing its resistance and creating the wing and flat cut effect.
I think thats how it goes anyway as the individual knive blade is also resisting the air mass and air volume under the hood of the mower, until the leading cutting edge encounters the oncoming air pressure gradient created by the rotation speed of the rotor weldment and knives. "
The centrifugal force developed at 540 rpm is much, much greater than any aerodynamic resistance. If you have the Y blades, and look back after cutting, you will clearly see the Y shape in the grass. They do not cut flat.
Ken
/ Let's talk flail mowers #978
Ken
Hello Ken,
do you have a 2 row or a 4 row rotor?
Yes you are right about the aerodynamics of the mower knives.
My 4 row staggered knive rotor cuts absolutely flat with the tapered knives
all the time even in brush.
I always laugh when people tell me a zero turn mower cuts better than any other mower; I just walk away smiling because my turf is better and not damaged by blades that tear and shock the grass at 18,500 rpm.
/ Let's talk flail mowers #979
The dolly I made for my dad's Caroni TM1900. Two ~82"-long 4x4's connected with two short pieces of 4x6's I had leftover laying around. Piece of 2x8 as a back-stop to set the roller against. Two short 2x8 pieces under the front corners, to keep the flail level & keep it from rolling forward. The level my dad has his roller set at takes a two-by (1.5") under the front corners to just about perfectly level the unit (front-to-back).
attachment.php
attachment.php
/ Let's talk flail mowers #980
leonz,
The number you quoted for rpm, should be the fps number, otherwise, velocity in feet per second. You can not get that high a bld tip velocity or rpm using a flail mower. There are some finish mower flails that will cut as good as any mower that is using sharp blades.
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
2010 GREAT DANE SUP-1114-11053 53X102 REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
