3x20 Wiring Question
/ 3x20 Wiring Question #1
UnclePaul
Unionville, Pa
Kubota L39, John Deere z950a, 1965' 110
Today I was hooking up my woods DS96 8' pull type rotary mower on my 3720 with cab and i saw 2 wiring plugs with caps on them right by my 3rd service fits. My question is are they or 1 of them for some type of trailer plug? I really like the 8' mower but I would like to put some flashing lights on it. For the few times i don't get done before dark.:laughing:
/ 3x20 Wiring Question #2
I believe they are for the work lights, they should be powered from the headlight switch...got a voltmeter?
/ 3x20 Wiring Question #3
One of them maybe for the Backup Alarm (H2)
check wire colors backup alarm should be be a 2-way connector with orange and black wires.
/ 3x20 Wiring Question #4
I think you're both right, back up alarm and work lights.
Rob
Thanks guys I have been busy the last two nights and have not had a chance to check them with a test light yet.:D
/ 3x20 Wiring Question #8
The plug drop for the back-up alarm is on the left side. I think the plug drops you are seeing are for the rear work lights
/ 3x20 Wiring Question #9
If I remember the work lights are one black and one purple wire.
Rob
/ 3x20 Wiring Question #10
I used these on my 3320 to wire up some front lights attached to my sun shade. I just bought the lights and wire at a hardware store, the drop is wired to the headlight switch, now I have lights that are not blocked by the FEL.
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
HANFAB HF-60-DG1-SD-R 60" CIRCULAR SAW (A64276)
HANFAB...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
