15% ethanol!?!?
/ 15% ethanol!?!? #61
That's my point. No small engine manufacturer is going to say it's okay to leave gasoline sitting around for 6 months. Almost all of the problems that occur with small engine fuel systems could be easily avoided if the recommendations were followed.
Ethanol blends, when stated as fine to use by the engine manufacturer, cause very few.....if any....issues.
Poor practices on the part of the end-user on the other hand, cause all sorts of problems. And when those problems crop up, it's easier and more convenient to put the blame elsewhere.
Go to any small engine/marine/motorcycle shop at the beginning of whatever season it is. About 90% of the work they'll be doing is to un-do mistakes made by the owner when it comes to storage. The type of fuel the owner was using has little or nothing to do with whatever their current problem is. Ethanol "attracting moisture" also has little, (or nothing), to do with whatever their current problem is.
Simply stated, if the manuals were read and adhered to, all of those dump-the-old-gas-and-clean-the-carb work orders would be history.
Your correct if we followed the manufacturer recomemdation i think they all say for more than 4 weeks or so tank should be drained.
You still will have people that have that 2 gallons of gas that they bought 8 months ago with no stabil or seafoam in it that they will put into that drained saw or mower to run it and will still get the problems. Again were back to directions, i think they all state "fresh clean fuel" be used.
/ 15% ethanol!?!? #62
OK, I'll admit this comment is off on a tangent, but it ties in.
The new Chevy Volt has a battery with a 40 mile range and a small engine that fires up if you need to exceed the 40 miles. If someone bought one and only commuted to work 10 miles for years on end, the engine would never run. In the meantime it seems like that gas would get pretty rank. Has anyone heard how they plan to get around this issue?
/ 15% ethanol!?!? #63
Despite what some folks think, gasoline lasts a very long time. Two days ago I used some PUL that was 3.5 years old and put it into a nearly empty tank and drove 57 miles on it without so much as a hiccup.
DEWFPO
/ 15% ethanol!?!? #64
I believe corn is food too,also,corn takes alot of nitrogen when it grows also,meaning you got to really fertilize it, takes a good bit of water too,takes a lot of desil fuel too,and thats just the growing part,,,,ethinal as fuel if the government wasn't helping pay for it with our tax money it would cost way more than it does[they wouldn't be making it]now if we run out of oil,than you ain't got much choice,and a gal of fuel would cost maybe 50 bucks or more,again you ain't got no choice[if we ran out of oil],but we ain't ran out of oil yet and won't probably in next 100 years or more. They forced it on us too soon,time we run out of oil,ethinal will be history as well anyways,,just a way,for some companies to get rich off us tax payers,thats all ethinal is at the present[and a pain]...
Field corn is used to make many human food products as well as to feed to animals[which we than eat],we have been eating it for probably thousands of years,,now sugar cane seems like a much better thing to use to make alchol with than corn,why aren't we using that,or beets? politics,thats why.
/ 15% ethanol!?!? #65
So.....how much is the "government helping pay for it with our tax money"?
Any idea how much the petro companies are "helped"?
Infrastructure.
If you figure that amount of feed left when done making corn ethanol, is sugar really any better?
/ 15% ethanol!?!? #66
Has anyone in cold climate regions given any thought to heaters in electric cars? Adding enough electric heating elements to defrost windows and keep the interior warm in sub-zero weather will do wonders for battery life!:eek: Just wondering!:2cents:
/ 15% ethanol!?!? #67
Leave some gas that old in the tank of a small engine, (especially one that gets fed its fuel via gravity), and post back your results.
Or, go to a local small engine/marine/motorcycle shop and ask them what the majority of their workload is at the beginning of the season. There's nothing magical or mysterious going on when folks' stuff won't start or run after sitting for a few weeks or months. Nothing with the engine itself has *changed* since the last time it was operated and ran fine. The techs are simply draining old stale gas, (out of everywhere....lines, carburetor bowls, etc. Not just the tank.), and replacing it with fresh gas. If it sat long enough with bad gas that has congealed and transformed into gunk, then draining it often isn't enough. Jets need to be unclogged and such.
Following the manufacturer's recommendations for storage would eliminate the hassles, but then again....why do that? It's easier to let the fuel go stale and then load the equipment up and haul it in for a $50 and up "spring tune-up".
/ 15% ethanol!?!? #68
Well with having the 15% ethanol here in Oregon for over a year and a half, we are now coming into many of the small engines having a full season of use, storage and attemped use again.
Oregon does NOT serve 15% ethanol. Unless you find a weird station somewhere, they are all 10% just like everywhere else. (the percentage of ethanol must be posted at the pump, and I've never seen one higher than 10%, and that's all the law requires) In Oregon we are required to have it year 'round, as compared to other states or in the past when we only had it in the summer. Not that there are many mom and pop stations left, but this is a reason to choose a big name versus the cheaper stuff.
The biggest problems with ethanol fuel are A) the gas station selling you an incorrect (higher than 10%) mix, and B) it just goes bad faster. If you get fresh E10 fuel and burn it right away it should run fine in most any engine.
That said, I'm currently talking with a local oil company about delivering non alcoholic gas for "off road" use at my shop, more for economy reasons than because I think it's hurting my engines...
/ 15% ethanol!?!? #69
I wonder, if even possible, if anyone is going to make a "ethanol filter" to remove stuff from the fuel?:confused:
It's called "water washing". All you have to do is add water to your gas until the ethanol can no longer absorb anymore. At this point it should sink to the bottom and you can siphon off the "pure" gasoline.
Problem with that is that it can also remove some of the other additives in gas, and, you're throwing away 10% of what you bought. Gas already cost too much!
If you're careful the alcohol/water mix is still flammable once you siphon it off, you could make a heater...or maybe some moonshine. :D
/ 15% ethanol!?!? #70
Oregon does NOT Not that there are many mom and pop stations left, but this is a reason to choose a big name versus the cheaper stuff.
Around here the smaller stations, the privitly (non chain) owned ones are the ones that still sell pure 100% gas. These are the places i go when i want REAL fuel. Yea they may be .10-.20 cents higher a gallon but you get 10% more gas per gallon too.
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
